Old 04-08-2006, 03:42 PM   #11356
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Bigger Brother
Can someone remind me the distance between the 2 holes on a set of brackets.
7 mm
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 04-08-2006, 04:53 PM   #11357
Send a message via MSN to Bigger Brother
Thanks!
Oli
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 04-08-2006, 05:36 PM   #11358
POOKYT's Avatar
Originally Posted by 2-Bad
7 mm
NOPE!!! Its .275 inch!!! LMAO
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 04-08-2006, 05:56 PM   #11359
Tornado_Racing's Avatar
Josh told me at the Birds in 05' he was running 48 pitch because he was ripping teeth off 64's under heavy braking.
Tony Moffre
PRS Customer Service
PRS - Hyperdrive - EA Motorsports - Corally USA - Parma/Faskolor - SMC - Killer Koncepts - MSA - Finishline - IRS - Lunsford - Trinity - Guarantee Graphix - RC4Less
Tornado_Racing is offline   Reply With Quote
Old 04-08-2006, 06:04 PM   #11360
POOKYT's Avatar
Hey Tony!!!! When ever the rear motor car is released, I'm going to convert my front motor car to oval. You gonna hook a brother up with the hot roundy-round set up? Later man.
Brant
Old 04-08-2006, 06:41 PM   #11361
Just let me know what color! [email protected]
Tony Moffre
Old 04-09-2006, 03:28 PM   #11362
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
The JRXS ran great again last night. Had speedo problems in the mian but it was on rails on super high bite asphalt. Need a tick more steering but I think if I compound the whole front tire it will be about perfect. Just running a modified Numan setup with some little changes to meet the condidtions of are track. Car is just getting better. I was really surprised last night with my car.
I did run the front camber mod and found that it didn't change the car alot other than it was just smoother overall to drive fast and consistant. I also raised the rear camber link to #3 position. It seemed to let the rear end come around a little better.
ST Racing Concepts (STRC)
Old 04-09-2006, 04:27 PM   #11363
POOKYT's Avatar
Since it was high bite and you needed a lil more steering, you might try standing the front shocks up 1 hole or running 1 weight higher on your shocks. Every time I have been in a high bite track, my car seemed to need to roll just a touch less to get my steering back. Good Run and good luck next time. Keep us posted!
Brant
Old 04-09-2006, 05:52 PM   #11364
wyd
Tech Legend
wyd's Avatar
Brant
Next time I go back I will try moving the shock out one and see what happens. Some good ideas you gave me to try. I was trying stuff every round thats for sure.
I did try running a 2 degree front pivot block to sweep the arms back some and that also made the car alot better going in for me but with the camber link mod it still kept my car smooth. I did go faster overall than I did last week. I went about 5 seconds faster or so which stepped me up a lap. In the 3rd round I was going even faster but my speedo went bad ( thought it was my motor but out after the main is was the speedo) when I would of ran another few seconds faster. Good thing is the car is repsonding to my changes good/bad I see a differance every run.
Old 04-09-2006, 06:08 PM   #11365
POOKYT's Avatar
If you make the shock change and its better but not much or you lean the shocks in 1 hole and get the same results, then I would remove one of the thick roll center shims and replace it with the thinner one. If you need steering overall then drop the front roll center. If the front is fine and the rear is loose then raise the rear roll center. Once you get it close then you can fine tune with the shock angles and camber links. LOL Sounds like you has a full day with the adjustments and some electric troubles. Hang in there and it will get better.
Brant
Old 04-09-2006, 06:27 PM   #11366
2-Bad's Avatar
I only run Modified as well and I know a lot like the JR Mod but I've had it in & out several times now, and I think I prefer it out . The car in the standard front camber link setup just seems more agile and responsive... and has improved low speed steering......
Old 04-09-2006, 06:31 PM   #11367
Mike Haynes's Avatar
Not sure if anyone is in need of a rubber tire high bite setup or not now, but here is 1 that worked very well for me after a few race days.
It is for high bite carpet, Stock motor with either cs 22/ rp 24/ or cs27 it works fine.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 04-09-2006, 06:32 PM   #11368
POOKYT's Avatar
WELL !!!!! Thats just 2-Bad isn't it??!! LMAO
What tires are you guys running over there??
Brant
Old 04-09-2006, 06:33 PM   #11369
I did not like the mod at all untill i made a rear shock tower camber location setup to acompany it. With the link really long to the normal mounts i just hated the feel, with the shortest hole from the rear tower, i liked #6, it seemed to work very well for me.
Old 04-09-2006, 06:34 PM   #11370
POOKYT's Avatar
That looks good! It also looks like a eally good asphalt set-up too. Did you run Vegas this year? I'm hoping to go and I want to run rubber tires. This looks like a good starting point. Thanks for the post
Brant
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
