Old 04-05-2006, 12:13 AM   #11311
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by 5thscaleracer
yup all done at socal... 1 was because he was using Ti screws and the flat head didn't fill up the hole compleatly it was slightly undersized so it ripped the bulk head right out of the holes during impact. The other time he had the standard screws but he has fractured some and others compelatly taco style.
I'd suggest Lunsford screws, super strong, and has the widest head and still flush with the bottom of the chassis.
Old 04-05-2006, 12:26 AM   #11312
Trader Rating: 22 (100%+)
Send a message via AIM to 5thscaleracer
i didn't know they made screws i will look into it??? but to tell you the truth the JRXS is on the light weight side compared to the rest of the bunch. Last year @ the Vegas race the car met minimum weight requirements with 3300mah batteries. the 3800mah secured the weight factor so it's not required to go lighter.
But yeah i will let him know if he is still willing to run TI screws.
Thanks for the TIP!
5thscaleracer is offline   Reply With Quote
Old 04-05-2006, 02:33 AM   #11313
Thanks for the TIP!
I run all ti and aluminum screws on my cars, reason being is because I can add the lead weight wherever I want it, and as low as I can get it.
Old 04-05-2006, 09:19 AM   #11314
JRXS_chris's Avatar
Originally Posted by TheCoolCanFanMan
Chris
The Ben Rayments set-up is on page 366
I to run nineteen turn and you will want to run Ben's set-up for Southend and run 6/7 mm ride hieght or you will muller your chassis especialy at the extreme rear corners where the locating pin sits in the chassis, you may want to go as far as I did, and that is to cover the bottom of the chassis with duct tape
This is Ben's set-up just take a look at what I did it may help too
Front:
50wt Oil
15lb Spring
56 Piston
White bladder
2 O-rings above bladder
2mm droop
4 degree caster
1 degree camber
41T spool
.100" shim under high roll center
diff high
middle hole on shock tower
position 5 on camber link - JR Camber link mod, rear tower on the front see:
http://www.rctech.net/forum/showpos...postcount=10792
and
http://www.rctech.net/forum/showpos...postcount=10354
Rear:
35wt Oil
12.5lb spring
56 piston
White bladder
3mm droop
1.5 degree camber
.040" shim under low roll center
diff high
2 degree inboard toe-in
hole 2 on shock tower
hole 5 camber link
any ballast weight at rear of car (as close to the diff centre line as poss.)
Cheers Malc THE CAN MAN
Ta for that one. One last question, was he running BK arms/brackets?
JRXS_chris is offline   Reply With Quote
Old 04-05-2006, 09:30 AM   #11315
i didn't think of it that way.... another good tip
Old 04-05-2006, 10:31 AM   #11316
vabroom's Avatar
I use the kit screws on the bottom (motor mounts, servo mounts, etc) and use ti and alum screws anywhere above the bottom chassis plate.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 04-05-2006, 01:50 PM   #11317
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Hello all!
Been a few since I posted.
Just wanted to pass along the good news that my car was pretty dialed last weekend at the Canadian Indoor Champs In St Catherines Ontario- Canada.
I ran 19t and stock. I wanted to run mod as well but I only have one car currently and that would have been overwhelming.
In both classes my car was on rails. Stock I ended up blowing a TQ run in the 4th round BUT Tom Furshing was able to put his JRXS on the pole! I ended up qualifying 3rd and the cream of this JRXS oreo was Mark Frechette.. with his RDX. The main was less than desireable, as Mark got a nice lead after the first turn adn in the end, i got 2nd, and Tom got 3rd.. here is the printout=
http://home.cogeco.ca/~szekeres1/04-...ock_A_Main.htm
19T was the money class.. there were a ton of fast guys in this and if not for being DQed for ride height, I would have qualified 2nd. I ended up qualifying 4th and getting CORNHOLED in the first turn. Look at the lap times.. LMAO.. after lap 1 I was dead last. I faught up to 3rd with a car that was badly tweaked, and with a chunked tire only to get too agressive and then wait for 3rd to regain the position.
http://home.cogeco.ca/~szekeres1/04-...urn_A_Main.htm
Still running the same setup as posted on PG 351, with the exception of the JR link and 25lbs front spring..
Cheers~
OUT
Keith Billanti is offline   Reply With Quote
Old 04-05-2006, 01:58 PM   #11318
2-Bad's Avatar
Trader Rating: 24 (100%+)
Keith,
What 19t are you using? And what did you gear it at?
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 04-05-2006, 01:58 PM   #11319
After this run last night, I came off the drivers stand laughing... 3'rd all the way up to the last couple laps. http://www.socalrc.com/raceresults/o...04-04-2006.txt
Patience pays off
Old 04-05-2006, 02:02 PM   #11320
Originally Posted by 2-Bad
Keith,
I used an EA Motorsports C2 and Monster.
Both motors are OLD.. My 19T was my motor from the Halloween classic, and the monster was actually my handout from Vegas..LMAO..
Com sizes were both right around 268-270... F Brushes.
Tire size was around 55.5mm- maybe 55.75mm. and gear for stock was 34/128 and in 19T 37/126
Keith
OUT
Old 04-05-2006, 03:03 PM   #11321
TheCoolCanFanMan's Avatar
He was, and I was
Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 04-06-2006, 05:37 AM   #11322
JRXS_chris's Avatar
Keith
Just wondering Keith, have you tried the tower mod with rubbers indoors?
Old 04-06-2006, 06:05 AM   #11323
I have Chris
It seemed to carry more corner speed, and was using Ben's setup, other than the rear hubs were 1 degree, as I thought it maybe a bit tail happy but will be trying it tomorrow night at the Ware club, with 0 degrees as i have left it as it was at southend (yea tea yea Ive heard them all before lol) Were's that club then
Old 04-06-2006, 06:47 AM   #11324
Sorry, no I havnt. I will be running some rubber soon though.
OUT
Old 04-06-2006, 06:59 AM   #11325
JRXS_chris's Avatar
I have Chris
Brilliant stuff, I think I'll give it a go too, doesnt seem a difficult conversion to make.
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
