Old 03-28-2006, 03:17 PM   #11221
berger's Avatar
R/C Tech Charter Subscriber
Originally Posted by JRXS_chris
They are definately something I need to try. Maybe after I purchase a set for the BRCA I'll use them at the club track (phoenix raceway, macctrack, excuse the plug).
Karl, what are you doing in the Losi forum??? You're not part of the elite!
Hawr, busting in on you! You can try my VTECs on saturday if you like, they are fairly well worn though. I want to try a few tyre combinations on saturday, have you any RP24 premounts i could try? I think the best tyre was the CS27, but i can only afford one new set (so need to buy the right ones)because i blew all my money on diesel and stuff... (not drugs).
What time are you going down on the saturday, i believe ste and ali are meeting at half 9 at the truck stop, but im not sure, might set off at half 9 from my house, its about 75 minutes or so drive. See what the weather is doing on friday.
berger is offline   Reply With Quote
Old 03-28-2006, 06:27 PM   #11222
POOKYT's Avatar
Originally Posted by Tony Vega
LOSA9686 Aluminum .165"w (Stk) Wheel Hexes (2) $ 11.99
LOSA9687 Aluminum .195"w (+.030) Wheel Hexes (2) $ 11.99
LOSA9688 Aluminum .225"w (+.060) Wheel Hexes (2) $ 11.99
How'd Ja Do that????
Is this on Horizon's website?
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 03-28-2006, 06:49 PM   #11223
rezalb8891's Avatar
heres a pic of my front end mod i used TC3 parts seeing that the caster block was flatter and i had a lot more of there are and it seemed like they are thinner and cheaper im going to try it out this weekend
rezalb8891 is offline   Reply With Quote
Old 03-28-2006, 07:05 PM   #11224
POOKYT's Avatar
It looks good man!!! You should be fine with it! Let us know how you like it after this weekend.
Brant
Old 03-28-2006, 07:25 PM   #11225
Tim W.'s Avatar
LOOKS REALLY GOOD
Mugen Seiki, AKA, Werks Racing USA, Flashpoint, Upgrade
Tim W. is offline   Reply With Quote
Old 03-28-2006, 07:40 PM   #11226
rezalb8891's Avatar
only put one hole in my finger in the process
Old 03-28-2006, 07:48 PM   #11227
POOKYT's Avatar
LMAO If its only 1 then I would say you did OK! LOL Ever notice that you only seem to cut yourself with an Xacto knife just after you change the blade or buy a new knife? hehehe
And you should be proud that you actually put some TC3 parts to a GOOD use!! LOL
Brant
Old 03-29-2006, 06:20 AM   #11228
2-Bad's Avatar
Trader Rating: 24 (100%+)
Default 19t gearing
Guys.... need help,
I'm thinking about trying some 19t, but need help in gearing it. What is the approximate recommended gearing required for a Checkpoint (either final drive ratio or mm/rev).
This will be on a fairly large open asphalt gas car track (approx. 45 meter straight) Iíve heard gearing from 28t to 45t pinion/128t spur . Iíve also heard that the largest gear you can fit on the Losi with the standard spur adaptor is 38t pinion/118t spur . Other then bolting on a PRS Spur gear adaptor, is there any other options if it is needed to go that high?
Thanks,
Peter
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 03-29-2006, 09:25 AM   #11229
Originally Posted by 2-Bad
Guys.... need help,
Thanks,
Peter
i can fit 47/128 so you should be able to fit a 38/118 no problem without the PRS gear adaptor.
Niall is offline   Reply With Quote
Old 03-29-2006, 10:54 AM   #11230
Mike Haynes's Avatar
Guys.... need help,
Thanks,
Peter
Usually the place where guys run into problems is that the motor will hit the servo saver...if you choose to use one. You could use AE mounts and it will pull the servo more foward and give a little more space. I have the AE mounts and a straight ofna aluminum arm.... I can fit up to 130/47 and that is where the screws will actually run out of room in the slots on the bulkhead. With the 118 you should have NO problem what so ever gearing the car high enough.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 03-29-2006, 10:56 AM   #11231
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Might have to try using the TC3 arms for my spare pair of camber link mod. Looks like they are little thinner and might require me to do less dremel work. Looks a nice job. Guess I will have to try it out.
ST Racing Concepts (STRC)
Old 03-29-2006, 11:59 AM   #11232
For my JR link set i used the losi block, and a tc3 arm...i redrilled the tc3 arm hindge pin to give it less dept and fit a bit better, then cut the end off so it is like a U. I was having trouble with it hitting everything.
Old 03-29-2006, 12:56 PM   #11233
2-Bad's Avatar
Thanks Niall & rcracing.....
I'll have to try the AE stuff if it fouls the servo as the Hitec servo mount taps are further back then most and I'm running a Kimbrough med servo saver as well.
But what about the gearing for a 19t?
Old 03-29-2006, 01:26 PM   #11234
wyd
Tech Legend
wyd's Avatar
[QUOTE=rcracingkid]For my JR link set i used the losi block, and a tc3 arm...i redrilled the tc3 arm hindge pin to give it less dept and fit a bit better, then cut the end off so it is like a U. I was having trouble with it hitting everything. [/QUOTE Yeah Mike mine hit everything as well. I had my grinder working hard. It looks nice but if I can do it and grind less that would be nice, especially if I need to make a spare at the track.
Old 03-29-2006, 01:28 PM   #11235
What motor / size track? Rubber or foam?
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
