Team Losi JRXS
Old 03-19-2006, 01:43 AM
  #11056
Trader Rating: 22 (100%+)
hmm good point!!! i didn't notice that...
5thscaleracer is offline
Old 03-19-2006, 01:46 AM
  #11057
POOKYT's Avatar
But we both forgot that the body mounts will still work so..........I guess were even!
Brant
POOKYT is offline
Old 03-19-2006, 12:16 PM
  #11058
JRXS_chris's Avatar
One thing that gets me about those new diffs is how it all works on the pulley half... Is there a shorter drive shaft or something?
JRXS_chris is offline
Old 03-19-2006, 01:52 PM
  #11059
POOKYT's Avatar
Nope, the CVD's or dogbones extend into the diff tube. They are actually longer than what we run now. This is to help free up the drive train through the corners. If you take your cvd now and place it in the diff tube into the splines you will see they fit. Very tight but they do. I don't really know how the pulley side works but we shall see. Hopefully soon!!
Brant
POOKYT is offline
Old 03-19-2006, 02:06 PM
  #11060
JRXS_chris's Avatar
Default JRXS_chris
Yeah I got that Pook, tis a mystery on the other side. Maybe Keith can pictorialise?
I wonder if these XXXS shafts will fit....
Old 03-19-2006, 05:34 PM
  #11061
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Same length dogbones on each side... it's super trick, you kinda have to see it to believe it.
Randy Caster is offline
Old 03-19-2006, 08:55 PM
  #11062
POOKYT's Avatar
How did you end up this weekend Randy?
Brant
POOKYT is offline
Old 03-20-2006, 01:52 AM
  #11063
Brant
Well since I only finished 1 19 turn qualifier, and we were running on qualpoints (2 best of 4 rounds) I was in a lower main, got the lead in the first few laps and I believe I ended up lapping the field..
My last mod qualifier was going really well, was on a super fast pace but I dumped at 4:30 and crept around the track for my last couple laps, still managed to take 12'th for that round, but only had an 18 to back it up with, so I CQ'd. Got a couple second lead and a comfortable pace, took a turn too tight, bounced into a pipe head first and got stuck, went back to 3'rd place, 4'th bumped me, went all the way back in the pack, and managed to climb back up and finish 2'nd to Jimmy Jacobson.
lol kinda a hurting experience, I'm stoked to get to put the rubber tires back on the car, I think I'm actually going to go wrench tomorrow and try to come up with a good spool setup, practice time for Reedy.
Old 03-20-2006, 03:44 AM
  #11064
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
HAHA... im not "A list".. i dont have anything aside from the new tower
XXXS shafts, no. The "ball" is much larger that the TC3/4... small ball is needed to fit.
KB
Keith Billanti is offline
Old 03-20-2006, 04:27 AM
  #11065
thachowman's Avatar
Trader Rating: 28 (100%+)
Just a quick question, Today I ran my car for the first time with rubbers on, (I still have the stock setup as it was working really good for me, and with foams on ( 40 shore I think ) but with the centre oneway, normally) and switched to a set of take off 27 with medium inserts still with the stock setup and it was really loose and tail happy, then I swapped out the centre oneway to the spool and it was a bit better, but I need to keep the rubber tires for an up comming event, is there any suggestions that will help the rear of my car to stick. turn in is great on and off power just comming out of high speed turns is like a drift race, so I need to work the throttle. I am running a co27 stock motor.
thachowman is offline
Old 03-20-2006, 05:23 AM
  #11066
How much droop are you running? Try running more rear droop, around 4mm rear about 2-3mm front. Rubber tires need more droop than foams. Tighten the front diff a little more than you would foam. See how that does.
bigdog xxx-s is offline
Old 03-20-2006, 12:00 PM
  #11067
2-Bad's Avatar
Trader Rating: 24 (100%+)
Try the Numan Setup off the Losi website.....
http://www.teamlosi.com/jrxs-page/asphalt%20index.htm
The only changes I made from this was 12.5lb rear spring and going to 6-B for the rear camber link......
2-Bad is offline
Old 03-20-2006, 12:33 PM
  #11068
rayhuang's Avatar
Come on Hodge-release that rear motor car already!!! I'm ready to buy it if your ready to sell it
rayhuang is offline
Old 03-20-2006, 01:26 PM
  #11069
TLRacing
Todd Hodge's Avatar
TRUST ME....I am working on it.
Todd Hodge is offline
Old 03-20-2006, 01:37 PM
  #11070
TheCoolCanFanMan's Avatar
Todd
When will it be ready........................... yea yea yea I know in two weeks. beat you to that one Brant
Cheers THE- CAN MAN
TheCoolCanFanMan is offline
