Old 03-14-2006, 03:09 AM   #10981
TheCoolCanFanMan's Avatar
Originally Posted by J A M I N
I managed a 17 lapper in the 3rd qually, and was quite close in two of the three finals..
I've never raced on carpet, sorry.
Well done Ben, sorry was only looking at the finals and did not realise you done a 17 I was talking with to Nathan Parker, he holds the lap record there with a 17 in 12 with a XXX-S but is his Local track to-boot
I will try your set up if I get time before Friday as ive bought Keith (the bald eagle) JRX-S off him and am re-building it.
What length do you make your shocks? and what does the 2 white O rings give you at the top of the shock bladder. When building your shocks do you have the shaft push out of the body on its own, or do you push the shaft in with NO rebound? (hope this makes sense Ben)
Cheers Malc THE CAN MAN
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 03-14-2006, 04:13 AM   #10982
Bald Eagle!? LMFAO!!
I am not sure about my shock length, I'll have to check and let u know.
The 2 o-rings help the shock to rebound quicker, which answers the last question, I always make sure the shaft rebounds all the way back out.
Team Losi XXX-CR | XXXT-CR | JRXS-R | JRXS | XX-CR | XXT | XXT-CR G+ | Mini-8ight | TLR22 | TLR 22T
J A M I N is offline   Reply With Quote
Old 03-14-2006, 04:59 AM   #10983
Thought you might like that one funny he (The Bald Eagle) should sell his JRX-S to me and go for the Corally as my time with a 19t was 3 seconds quicker than Keith and Dave and they were running modified then he is 52 years young and im 3 years younger
When you say 'I always make sure the shaft rebounds all the way back out' is that after you build them on the bench, in other words you depress them by hand and they come all the way back out?
Cheers again Malc THE CAN MAN
Old 03-14-2006, 05:10 AM   #10984
Hehehee...
Yup they rebound all the way out when depressed by hand.
Old 03-14-2006, 07:27 AM   #10985
Default Building diff with brown grease
When building the front diff on the JRXS with the LOSI brown grease do you use the brown grease on the thrust balls and the diff balls?
Shad
shadp is offline   Reply With Quote
Old 03-14-2006, 07:38 AM   #10986
Mike Haynes's Avatar
Just in the gear area.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 03-14-2006, 08:44 AM   #10987
Any setup info for Rubber carpet.
The car right now is setup for Foam carpet and te local track is starting a stock rubber class. Does anyone have a setup sheet they could post of send me for stock (27t) Rubber class. The tires that we are going to use are RP take off 27's, The carpet is high bite Ozite. I have looked for a setup sheet and can not find one. Please let me know, thanks a lot for any help
Chris R
DR.FeelGood is offline   Reply With Quote
Old 03-14-2006, 09:24 AM   #10988
Originally Posted by 2-Bad
Jamin (or anyone),
what effect does putting the rear shock tower on the front give you?
This is how i have the front of my car set up right now. I had tried the JR link before with a stock tower, and i felt it made the car "screw" itself into the corners, and was just too long. With the shorter setup pictured, my car feels much more consitent then with the standard ballcups setup.
Note- the outer 3 shock positions are stock, the extra inside hole is just to try out, and you can still see one of the body mount holes i forgot to fill in. My shocks are in the regular inner mounting location, with the BK arms of course.
Old 03-14-2006, 12:52 PM   #10989
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Hmmm... weird.
When I went to the JR link again, I felt it made my car push like a bus. The car was more consistant but lacked the precision it had without it. I dropped the front spring from 30 to 25 and the car was as agressive as needed, but more consistant.
I am running the middle hole on the new tower (which I am 99% sure is the same as the inner hole on the old one) The camber link is low and long... (LOL couldnt resist)
KB
OUT
Keith Billanti is offline   Reply With Quote
Old 03-14-2006, 05:06 PM   #10990
Keith- are you still running the rear shocks on the front of the shock tower?
hobbyman_7 is offline   Reply With Quote
Old 03-14-2006, 05:47 PM   #10991
Absolutly
OUT
Old 03-14-2006, 06:03 PM   #10992
whats the difference between the front and rear shocks then
Old 03-14-2006, 06:07 PM   #10993
Originally Posted by Keith Billanti
Absolutly
I thought they were the same front and rear I have black and white pistons in my shocks, and peeps have been mentioning 56 pistons what colour are these please ANYONE
Old 03-14-2006, 06:12 PM   #10994
thachowman's Avatar
Trader Rating: 28 (100%+)
Hi guys just wondering if anyone has any setup tips for running rubber tires on ashphalt ( 27t stock , long track with a few tight turns) , At the moment I am still runnung the stock kit setup but with foam tires but am switching to foam tires and am still relativly new to the car, so any tips at all would be appreciated. oh and this is my first post on RC tech.
Cheers
Andrew "Chow" Clough
_____________________________________________
Fraser Coast RC Car Club/FCRCCC :President
Yokomo - Futaba - LRP - Paint Made Special - Muchmore
thachowman is offline   Reply With Quote
Old 03-14-2006, 06:38 PM   #10995
POOKYT's Avatar
No, what they mean is that KB has been running the rear shock tower mounted to the inside of the bulkheads. He drilled a new holle for the BK bracket on the front side of the arm and now runs his shocks on the front side of the rear arm.
From here on out I proclaim we call it the KB Shock Mod!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
