Old 03-13-2006, 03:05 PM   #10966
TheCoolCanFanMan's Avatar
Originally Posted by 2-Bad
Jamin (or anyone),
what effect does putting the rear shock tower on the front give you?
Hi
I tried this yesterday, and was on a realy bumpy track and made me go a lap slower, so that gives you some idea when NOT to use it. Will try it on carpet this Friday and give more feed back
Cheers Malc THE CAN MAN
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 03-13-2006, 04:07 PM   #10967
Originally Posted by J A M I N
Tim, this is my latest tarmac setup, worth a try....
Front:
50wt Oil
15lb Spring
56 Piston
White bladder
2 O-rings above bladder
2mm droop
4 degree caster
1 degree camber
41T spool
.100" shim under high roll center
diff high
middle hole on shock tower
position 5 on camber link - JR Camber link mod, rear tower on the front see:
http://www.rctech.net/forum/showpost...ostcount=10792
and
http://www.rctech.net/forum/showpost...ostcount=10354
Rear:
35wt Oil
12.5lb spring
56 piston
White bladder
3mm droop
1.5 degree camber
.040" shim under low roll center
diff high
2 degree inboard toe-in
hole 2 on shock tower
hole 5 camber link
any ballast weight at rear of car (as close to the diff centre line as poss.)
If I've missed anything, pm or email me.
I s this you Ben from Yesterday at Southend ? coz that don't arf look like the setup I was looking at yesterday If this is you ben, you forgot to mention that you also run the B/K arms
Old 03-13-2006, 04:15 PM   #10968
Jamin (or anyone),
It gives you a few more options compared to the stock tower. With the JR camber link mod, the car is better (IMO) with a shorter link, using the rear shock tower is the easiest way to get this. I did originally order a sheet of carbon to make my own, but after measuring the rear tower, i found that this was the easiest option.
I have tried both the inner most hole and the middle hole so far, with the longer link, the car tended to dive less in the corner, but was alot less responsive.
Note that I drilled the shock tower holes to match that of the front tower - the shock angle remains the same.
Team Losi XXX-CR | XXXT-CR | JRXS-R | JRXS | XX-CR | XXT | XXT-CR G+ | Mini-8ight | TLR22 | TLR 22T
J A M I N is offline   Reply With Quote
Old 03-13-2006, 04:17 PM   #10969
Yup, its me!!
Ooops! BK brackets!!! I thought that was a given!! Heheheheeee
Old 03-13-2006, 04:28 PM   #10970
Yup, its me!!
Great
Your car was on the money yesterday Ben, Well done for winning the A, and well impressed as you lapped me my set up was sooooooo far away from you, but was happy to get into the A, with the big boys, (not saying im skinnyy or anything ) even if it was only 10th but would of been about 6th if i had not flipped the car on my last qualifier and corally plug came out of the cells DOH
Would you use that setup at West London do you think, or have you not been there as I know your local track is Ipswich, again would you use it there to
Old 03-13-2006, 04:50 PM   #10971
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by POOKYT
Well.......Some of us need the extra protection of the P-Dub bumper!!! Maybe its for the uh.......uh......Other guys who hit us. Yea-Thats the ticket!! LOL
Brant
Damn those other drivers!!! lol
Old 03-13-2006, 04:50 PM   #10972
Its a good starting point, I've tried it at two tracks, Ipswich and Southend, both of which are technical twisty tarmac tracks.
Oh, and the motor is at the front!
Sorry Ben Just seen this one about what tracks youve tried it on, BUT WILL IT WORK AT WEST LONDON?
Old 03-13-2006, 04:55 PM   #10973
Hi
What were your average laptimes with and without the mod, and what did it do differently as far as feel? Did you try to correct the "problem" with any tuning? Just wondering so I know.
Old 03-13-2006, 05:39 PM   #10974
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by Kwikvdub
You can't have your car back Bro!! ...................
Damn!!!!!!!!!!!!!! Its all good. I will see you at the Express race for sure. I'm already starting to make plans.
ST Racing Concepts (STRC)
Old 03-13-2006, 06:35 PM   #10975
Greenbandit's Avatar
Sorry if this has been covered, but do the new updated suspension arms have a mount that is similar to where the BK brackets would place the shock?
Todd Daly
Greenbandit is offline   Reply With Quote
Old 03-13-2006, 07:14 PM   #10976
Send a message via AIM to R/C Anonymous
yes
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 03-14-2006, 01:21 AM   #10977
Originally Posted by wyd
Did you find that running the Numan setup with the stiffer oil and springs keeps the car driving flatter in the corners.
Yeah thats right, it also gives loads of steering but not to much!!
srhand is offline   Reply With Quote
Old 03-14-2006, 02:00 AM   #10978
Great
Cheers Malcolm, I've been working hard on getting the car sorted, hopefully I can carry that pace to the next round.
You did well to grab that last place in the A, at least you could only improve from there!
I think there was 3 JRXS' in the 'A' , so a good showing really.
As for W/L, I would use it as a starting point, it may need tweaking a little for that long first right hander. I am sure it would be fine through the twisty sections though. I haven't actually raced my JRXS there - I used the XXX-S in round 1 of the STCC there last year, which, suprisingly, I won!!
Old 03-14-2006, 02:41 AM   #10979
Your welcome Ben
I should have grabed 5th/6th if I hadn't rolled it on my last lap and the marshal could not see that my plug had come out of the cells to complete my 16th lap, at least I got a 16 on the 2nd run, but you nearly got a 17 Your right about the 3 JRX-S in the A, but with all totally different set ups, just goes to prove the car can be on it in many hands whether it be old (ME) or young like your good self.
Do you think its a good setup for carpet on V-TEC 24's or have you not tried it?
PS, were you running a dif in the front?
Old 03-14-2006, 02:46 AM   #10980
Your welcome Ben
I managed a 17 lapper in the 3rd qually, and was quite close in two of the three finals..
I've never raced on carpet, sorry.
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
