Old 02-16-2006, 10:31 PM   #10546
POOKYT's Avatar
Originally Posted by JRX-S Bill
If you read above...What should I do to free the rear end up?
Lower the rear roll center 1 shim or go full low if your not using any shims. Try that.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 02-16-2006, 10:32 PM   #10547
POOKYT's Avatar
BTW--What is the #3 set-up? Can you post it?
Brant
Old 02-16-2006, 10:48 PM   #10548
Still Bill's Avatar
Brant
I am already there...
Harder rubber in the rear?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 02-16-2006, 11:24 PM   #10549
2-Bad's Avatar
Trader Rating: 24 (100%+)
Jaco 2 Stage foams likes larger sized tires being in the 58-60 cm range. And "overdrive" sizing of tires appears to be very promising for the JRX-S.
You ain't kidding... it must look like a Monster Truck with that size on them...
Must be hard to fit it on your pit-table as well...
(Sorry Bill, I couldn't resist poking fun at your metric conversion )
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 02-16-2006, 11:31 PM   #10550
POOKYT's Avatar
You'll have to excuse Bill..........He got a deal on some calipers off of Ebay and I guess they are not such a deal after all !!!! LMAO And.....just because everybody else on the planet uses the metric system, I think you guys should convert all of your numbers over to our standard system.
" Why Yes My Dear!!!!!!................That really IS 12 inches!!!!" hehehe sorry--its late--and I need to go to bed!
Brant
Old 02-16-2006, 11:37 PM   #10551
POOKYT's Avatar
I dunno really. Maybe lower the front a bit to gain steering and loosen it up or shorten and lower your rear camber link. I'm not sure.......Maybe Randy can help us out. Keith B.!!!!!!! What do you think??????
Brant
Old 02-16-2006, 11:47 PM   #10552
Still Bill's Avatar
Gotta think that Matt F will be at Stockton on Saturday...
And I like the shock mod idea.
Old 02-16-2006, 11:55 PM   #10553
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by Keith Billanti
LMAO.. thats good.
Randy= Cant wait. Cyrul says it gives more traction... and i think I agree.. but at the same time, it made the car have more steering. I think this is due to faster weight transfer front to rear.. Cant wait to hear what you find..
KB
Just got back from the track, I ran the shocks in front of the arms for about 10 packs. It took me about 3 packs to get used to how the car felt, and I'm still a little unsure if I like it or not. Felt like it wanted to rotate a lot harder out of the corners, but was very stable going in. The problem is SoCal raceway is so much different early on than it is later on in the day, that it's hard to get results by laptimes. I'm going to try it back to back with the normal settings on Sat and will post more conclusive results.
Old 02-16-2006, 11:56 PM   #10554
Still Bill's Avatar
Oops! My bad...mm not cm.
But, I think I got something good with the overdrive setup via tire sizing.
Old 02-17-2006, 12:00 AM   #10555
Easy way to tune is with camber, generally more negitive = more traction, less negitive = less traction. Maybe less toe-in as well.
Old 02-17-2006, 05:09 AM   #10556
POOKYT's Avatar
Cool Randy--Thanks for the update.
Bill--Sounds like this shock mod may be what your looking for too.
Have a great day guys! Later
Brant
Old 02-17-2006, 06:45 AM   #10557
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Randy= I knew that would be your reply. This mod gave the car a ton of rotation, on carpet where traction is easy to obtain.. On asphalt.. Im betting other stuff would need to be tweakd.. did you run the high rear roll center?
JRXSBill- story of my life What to do to free the rear end up? Honestly, i think that is not the way to look at this car. On foam anyway. I would be looking to make the front end work more. For this, i definately say high rear roll center, and my shock mod. Shock mod puts more weight to the front end faster, and the roll center forces the front end to "give up" first. It should give you all the corner rotation you could want.. without sacraficing rear bite.
unfortunately I am working this weekend.. but next weekend is the final leg of the CRL.. hopefully I can have the same car I had last weekend again and then I will claim that series.
KB
OUT
Keith Billanti is offline   Reply With Quote
Old 02-17-2006, 08:00 AM   #10558
Still Bill's Avatar
Thanks for all the input guys.
Old 02-17-2006, 01:09 PM   #10559
Josh Numan's Avatar
I ran high roll, with .030 pro-squat.
edit: this is Randy, forgot I'm on Josh's computer lol.
Josh Numan is offline   Reply With Quote
Old 02-17-2006, 04:14 PM   #10560
brad996's Avatar
Default checkpoint
Randy where can I pick up a checkpoint 19 turn because great plains does not have them in stock and I would like to get one before March 10th
SIRCS, Asylum Xtreme
TLR 22 4.0, TLR 22 3.0 lay down, TLR 22-4 2.0 Yokomo BD8/SV, Yokomo YR10F
brad996 is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
