Team Losi JRXS
Old 02-07-2006, 01:05 PM
  #10306
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by DirtyDog3375
Good OLD 2-bad is more than past that age. He is about to but put down and laid to rest. He's got no hair, no eyesight and definately no skill or talent!!!
OMG Dogbreath .... Then if this is all true, how embarrassing it must be when I keep betting you....
Dont encourage him Pookyt , hes turned to the Darkside and running a Shuie now Hes a lost cause and riddled in Evil
2-Bad is offline
Old 02-07-2006, 01:11 PM
  #10307
2-Bad's Avatar
Originally Posted by Trakside Trucke
So whats the point of the centre one way then, if you have to use the front one way then
Mr Truckie, if I'm wrong Brant will correct....
Centre one-way on its own, reduces steering (slightly) and improves efficiency of the drivetrain. So if adding the one-way diff is too aggressive then adding the pulley smooths that aggression out a bit.
Is that right "Master Pook"
2-Bad is offline
Old 02-07-2006, 02:15 PM
  #10308
TheCoolCanFanMan's Avatar
Cheers for dat 2Bad
Its just I NEVER see anyone mention the centre one way, so cant see the point of it being there really, other than what you have said, but no one seems to use it
Cheers Malc THE CAN MAN
TheCoolCanFanMan is offline
Old 02-07-2006, 02:17 PM
  #10309
Anyone know how to send mail to futureal
Old 02-07-2006, 03:35 PM
  #10310
vabroom's Avatar
Does anybody remember where to get a link to the pics of Todd's green car he ran in Eurpoe? Somebody? Anybody? Todd? Thanks
Brant
Pookyt, here's the link to Todd's green hornet.
http://worldcup.rcworld.ch/live_friday.asp?id=3
vabroom is offline
Old 02-07-2006, 03:46 PM
  #10311
Trader Rating: 17 (100%+)
Does someone know what size tap you have to use to thread the tierods in the part of the upper arm to make the camber mod work?
Kave is offline
Old 02-07-2006, 05:20 PM
  #10312
POOKYT's Avatar
LOL....I used my 4-40 because its smaller than the tierod threads. It does take a little effort to thread in the tierod but it fits nice and tight. Good Luck
Brant
POOKYT is offline
Old 02-07-2006, 07:20 PM
  #10313
i just drilled a small hole and basically forced it in
R/C Anonymous is offline
Old 02-07-2006, 08:26 PM
  #10314
POOKYT's Avatar
Cheers for that Brant, much apreciated.
Wont be using the centre one way this Friday then
To use the front one-way is freeing up the drive train. So if your using the front one-way then to fully free it and the belt drive to it go ahead and use the center one-way as well. Let us know how it turns out.
Brant
POOKYT is offline
Old 02-07-2006, 08:28 PM
  #10315
OSherman's Avatar
What is this camber mod supposed to 'do'?..
OSherman is offline
Old 02-07-2006, 08:29 PM
  #10316
POOKYT's Avatar
Yes, you will loose that little bit of drag from the center spool upon entering a turn if you use the center one-way. But if you run the front one-way then you should also run the center unit to fully gain its benefits. Hope this makes sense to you guys.
Brant
POOKYT is offline
Old 02-07-2006, 08:31 PM
  #10317
POOKYT's Avatar
It keeps the front end flatter during cornering and transitions and seems to really increase the total amount of steering. When I first used the mod I had to raise my rear roll center one shim to keep the rear end from washing out. Once I did this, the car seemed to turn in smoothly and consistantly from begining to exit.
Brant
POOKYT is offline
Old 02-07-2006, 08:36 PM
  #10318
POOKYT's Avatar
SOOO...............DirtyDog has been running around behind our backs now cheat'n on us huh?? Just as I was thinking you guys would be the start of the JRXS domination Down Under!! Looks like you've got it to your self then!!! LMAO Iz airight DityDog......Losi is like a big family.........no matter how bad you screw up we will always let you back in!!!! Now......we will always mess with you and make fun of you at all the family gatherings but hey! LOL J/K
Brant
POOKYT is offline
Old 02-07-2006, 08:46 PM
  #10319
POOKYT's Avatar
Thank you sir!
Brant
POOKYT is offline
Old 02-07-2006, 11:43 PM
  #10320
Originally Posted by T. Hodge
We should have some new stuff there....keep an eye on the photos from the race to see.
Anyone got any shots yet?
Kave is offline
