Old 01-11-2006, 02:59 PM   #10006
Default Tire Diameter
Guys,
I am running foam tires and out of the package I believe they have a 63 mm diameter. Does it matter or should I true them down to a smaller diameter? What is standard practice? What are the advantages by making them smaller? Or the disadvantages running them with the larger diameter.
Thanks!
dasdaman is offline   Reply With Quote
Old 01-11-2006, 03:14 PM   #10007
Matt Howard's Avatar
bigger tires will chunk easier and not handle as well. I start mine at 60mm and most still consider that kinda big.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-11-2006, 03:30 PM   #10008
Mike Haynes's Avatar
It depends on the brand of tire you want to run, most have slightly different rim sizes, of if you use Jaco Wraps they have another band that takes up space and can't be run on.
For my SpeedMinds i stat off about 57mm. I feel that 57 to 55 is about the sweet spot for most tracks i have run on.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 01-11-2006, 04:14 PM   #10009
A_Stratus's Avatar
I've been using Jacos with my JRXS and I've been truing them down to about 58mm to start with. I also have been CA'ing the edges and the only chunks I get are from body clips on the track and such...
Team Express Motorsports
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
A_Stratus is offline   Reply With Quote
Old 01-11-2006, 08:20 PM   #10010
Aaron are you laying the snack down on Rick ? I trust you will be at Fastcats.
Chris Reilly is offline   Reply With Quote
Old 01-11-2006, 09:11 PM   #10011
A_Stratus's Avatar
What do you mean? lol
Yes, I will be at Magma Going to be one hell of a race
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
Old 01-11-2006, 11:48 PM   #10012
POOKYT's Avatar
Originally Posted by MIKE ELLIS
I BET IT'S NOT IN 2 WEEKS!
LMAO!!!!!!!! Ditto!!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 01-12-2006, 01:12 AM   #10013
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by dasdaman
Guys,
Thanks!
Foam tyres will not chuck if you round off the side walls, but yes it is considered that between 55-57mm dia tyres perform better then 64mm dia tyres. Having said that, I run them from new during club meetings and only at competition I true them down to an appropriate size. I feel that for the average racer, there is only a slight difference to performance from large to small foam tyres.
Regards,
Peter
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 01-12-2006, 03:14 AM   #10014
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Originally Posted by Dasupacat1
Ok guys. I'm thinking of running stock foam this weekend for a big race. Normally my car is set up for 19t/rubbers with updated arms. What setup should I use? I kinda have an idea where to start (Paul C. stock setup), but what springs should I use? Should I take the spring that Losi recommends with the arms and go up one rating?
Anybody?
Dasupacat1 is offline   Reply With Quote
Old 01-12-2006, 05:06 AM   #10015
Rick Worth's Avatar
I would use Pauls setup for BK arms (setup# 3) & start the tires at 2.30". If you run tires much bigger, they can make the car too stuck & traction roll. Use 20 in the rear & 25-35 in the rear like Pauls setup.
Rick Worth is offline   Reply With Quote
Old 01-12-2006, 09:43 AM   #10016
Did you mean 20 in the front and 25-35 in the rear like Paul's set-up ?
Old 01-12-2006, 01:36 PM   #10017
Rick Worth's Avatar
20 springs in the rear & 25-35 in the front. R.W.
Old 01-12-2006, 11:09 PM   #10018
Originally Posted by losirunner
any idea when the conversion kit will be released....
until you pay for the tray you don't need to worry about conversion kits. pay me. now. check northwest for sale thread if you think i'm joking.
Turtlemaster is offline   Reply With Quote
Old 01-13-2006, 01:56 AM   #10019
RCknight's Avatar
Originally Posted by ttso
I'm surfing on RC50.com for Novak's photo. Something new catch my eye...
http://www.rc50.com/modules.php?name...422&fullsize=1
It apears to be similar with rear motor proto, but the servo is moved away from centerline, to free space for battery/motor to be moved forward. Quite interesting design as I think it probably be more balanced than rear motor proto.
The photo resized and attached, from RC50.com
3 upper decks??? It's like a monster garage project with Jesse James.
RCknight is offline   Reply With Quote
Old 01-13-2006, 08:18 AM   #10020
Send a message via AIM to R/C Anonymous
the normal JRXS has 3 upper decks too
Geoff C.
R/C Anonymous is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
