Old 01-09-2006, 05:33 PM   #9991
ttso - thanks for the pointer. #250 is kind of another pic.
rainblows is offline   Reply With Quote
Old 01-09-2006, 08:21 PM   #9992
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Novak race is one of the BEST races in the US. Anything Scotty is involved with is top notch. He outdid himself for this novak race as well.
I'll post the setup I used here in a few days....It was pretty good for only running the car for 2 weeks before on low bite. Car carried pretty good corner speed but was a little edgy at times....Still got to work that out but I think most of it was due to the traction. The traction there was crazy high!! I seen all kinds of stuff stuck to tires when taking cars off the track (Body clips, set screws, eclips, tire chunks, etc) it was gooooooie to say the least.
Thanks to the Losi Team.....they were great answering questions and looking over everything all week...Very easy to talk to and get help from. I even seen MF take a printer out of his bag and PRINT off a setup sheet for a local racer...Now thats tha shiznit!!
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 01-09-2006, 08:52 PM   #9993
dawgmeat's Avatar
Originally Posted by RCevolution
Hey dawgmeat,
Does Speedzone have parts for the JRXS? I might take a run up there in the next few weeks.
Thanks!
speedzone has parts for Losi, X-ray, Ass. and Corally
dawgmeat is offline   Reply With Quote
Old 01-10-2006, 11:18 AM   #9994
rayhuang's Avatar
Default Brushless set-up
Hey all,
I had a mixed weekend at the Novak. When I ran 4 deg caster-car was a dream to drive. Just about anyone would have loved it-from a driveability standpoint. But when I ran 6 deg caster-car was a lot faster, but mine could be crazy looose too. I ended up with 6 deg caster, LRC and 0.032" shim for antidive.
My set-up I think is a Trackside-Jack only set-up, but here it is if anyone wants to try it. Its basically the way it is because my car had so much steering and rotation that it needed to be toned down, while still having a lot of steering. Sounds crazy-but I guess you had to be there. I was VERY happy with this set-up every run, though it was loose some runs (like a tweak) to the right one run, to the left another run and perfect other runs. I need to take car apart to find out why!!
Front
#60, 60 wt Losi oil, 60 spring.
Standard arm, in on tower.
6-deg caster.
0.08" shims on swing rack and on steering hubs for bump steer.
Camber link lowest hole on tower.
1-deg front hingepin block low
LRC rear hingepin block raised 0.032"
1mm uptravel
Parma Cyan 2.15" 1-deg camber.
Rear
#56, 50 wt oil, 17.5 lb spring. Cut shock bottom 2mm
BK arm, 4th in on tower.
Camber link bottom middle on tower, b on hub.
1-deg hingepin block low. Flat pins.
1-deg standard hubs (NOT offset).
1.5mm uptravel
Parma Magenta 2.15" 2-deg camber.
Parma Alfa mounted a little forward.
Turning circle 6'.
GTB #1 setting, no drag brake, 4300 motor. Rollout 1.15 to 1.21".
Old 01-10-2006, 12:23 PM   #9995
RCGaryK's Avatar
Damn Ray, you were running springs that stiff up front? You were running the BK arms, right?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 01-10-2006, 12:29 PM   #9996
rayhuang's Avatar
Gary,
Nah-it was with standard arms. On my stock/foam car I ran BK arms, #57 pistons, 50 wt oil and 30lb springs.
Ray
Old 01-10-2006, 03:28 PM   #9997
Mike Ellis's Avatar
reference to ray's coments about last weekends race, i know what you are feeling out of the car. it seems that every set up i come up with for carpet foam,if the lap times are in the hunt, the car is very edgy. when i tone it down, the lap times drop off. i can't help but think it's because of the front to rear weight ratio. this mainly due to battery location. our local track is tight with good bite. the edgy handling makes it easier to make mistakes, like hitting things that isn't out of the ordinary for me at times anyway. i have a set up i will post for someone to try and feed back their oppinion of it.
where's my conversion kit?
Mike Ellis is offline   Reply With Quote
Old 01-10-2006, 07:28 PM   #9998
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
For the few races that I ran my JRXS I had this very same feeling. My car was qquick but always felt on the edge and I don't like that feeling and I can't drive it smooth when my cars feel like that. The car does seem to really transition fast from left to right and I like how the car always seems to run flat around the corners. Might have to get another one and give it a longer try sometime.
ST Racing Concepts (STRC)
wyd is online now   Reply With Quote
Old 01-10-2006, 09:18 PM   #9999
Mike Ellis's Avatar
Edited version;
try this setup and tell me how it works;
Front-
tow 1 out
6 caster link in 1
1.5 neg camber
60w ae,shock mounted 2/std
60 piston
50 spring
1 oring above
42/42, diff, height low
0 pivot
ack. 1, .090 drag link
bump .030
arms forward
AE hex
1 mm below ride height
Rear-
toe 2 in
1 offset hub, arms center
2.0 neg camber
40w ae
60 piston
15 spring
2 oring above
link b hole and 7 hole
shock bk hole and 2 hole
sway bar .025 .190 in
diff high
rear pivot 2
AE hex
1.8mm below ride height
shock towers and roll centers low, Brood Atlas 19T-126/38 brood 3800
GQ red/maj front maj rear at 57.5mm to start
Alfa slightly under 130mm
sorry i dont have an operational scanner at this time, i know it's a weird way to post a set up.
ride height 4.5
See Ya Mike
Old 01-10-2006, 09:21 PM   #10000
Mike Ellis's Avatar
sorry that's not how i had it arranged, i'll find someone to scan it in for me, who the hell could read that mess!
Mike
Old 01-11-2006, 05:56 AM   #10001
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Ok guys. I'm thinking of running stock foam this weekend for a big race. Normally my car is set up for 19t/rubbers with updated arms. What setup should I use? I kinda have an idea where to start (Paul C. stock setup), but what springs should I use? Should I take the spring that Losi recommends with the arms and go up one rating?
Dasupacat1 is offline   Reply With Quote
Old 01-11-2006, 10:50 AM   #10002
ttso's Avatar
You mean this one?
http://www.rc50.com/modules.php?name...451&fullsize=1
No this is the first rear motor proto, the one with servo in centerline, motor in very rear end.
The one I found (http://www.rc50.com/modules.php?name...422&fullsize=1) is servo on right side, battery & motor moved forward, with empty space behind the motor (I guess it move battery and motor about 15~20mm forward).
Now I just wonder which one Losi gonna release as JRX-S2? (or JRX-SR?)
edit: unless.. you mean the one under.. that's the mid-rear motor JRX-S.
I guess it would be easier to say original as mid-forward motor, 1st rear proto as rear motor, and 2nd rear proto as mid-rear motor.....
ttso is offline   Reply With Quote
Old 01-11-2006, 01:34 PM   #10003
Registered User
losirunner's Avatar
Send a message via AIM to losirunner Send a message via MSN to losirunner Send a message via Yahoo to losirunner
any idea when the conversion kit will be released....
losirunner is offline   Reply With Quote
Old 01-11-2006, 01:35 PM   #10004
rayhuang's Avatar
I found this shot of my JRXS on rcscoring pro!!
Old 01-11-2006, 02:08 PM   #10005
Mike Ellis's Avatar
I BET IT'S NOT IN 2 WEEKS!
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
