Team Losi JRXS
#9886
Registered User
Originally Posted by Greg Sharpe
Sounds like some portion of the thrust bearing/washer assembly isn't doing it's job. Take that thing apart again, looking for signs of abnormal wear or mis-assembly.
#9887
Originally Posted by losirunner
Thanks.... will do.
Brant
#9889
i have been having problems with the front diff loosening every run. I have rebuilt it a few times, but still every time it loosens.... what do i do>
when you take it apart check the outdrive for any type of fractures or any white discolorations of the plastic cracking or deforming this could be a fractured or broken diff half too.
#9890
Anyone in here going to the Snowbird (inter-?)Nationals? It'd be really helpfull if we knew one another were down there to share setup info and bounce new ideas around.
So who's going?
So who's going?
Il cya there, anyone know if the hotel has wireless?
#9891
New Jersey, short for Englishtown. Sadly, this track that many of us grew up at closed down after more than twenty years of racing. Since the days when slot cars were bigger than R/C, that place had some of the best action on the east coast.
#9894
Originally Posted by patrick
Hey guys, does anyone know of any on-line hobby shops that have the new rear arms in stock? Thanks.
#9896
Originally Posted by 5thscaleracer
this might sound retarded but....
1. make sure the belt(s) track correctly nothing binding or any thign on it's path.
2. make sure your diff is not shifting left or right. the gray plastic tube has a tendency to shift slightly left and right easy fix is that tiny 2-56 buttom screw mount them on the inside rather than the out side. This will hold that tube in place and prevent it from shifting
3. Check the belt teeth make sure they are perfectly uniform (not too perfect but they all should be uniform)
4. check the pullies make sure there is nothing wedge in the coggs causing the belt to skip or make sure that the side walls of the pully is not portruding or pinching the belt.
5. belt tension is the key but i think your drive train is shifting around on you.
I had the front and rear diff shift around almost 1mm of play my center shaft has 1mm of paly right now i have sinced shimmed it all out.
hope this helps.
hope this helps.
And good luck to Team Losi at the Novak Race!
#9897
Brant
#9898
what exactly are the advantages to the new arms? From what i read on the losi site it seems to be changes for the asphalt racers? What improvements will I see with my car on carpet with them? Thanks.
#9899
whats up
im new to rc tech and ihave to say that the jrxs is my best that i have ever had
#9900
Basically, they're good shit, put them on your car and chicks will go flippin silly over your crazy on-track skillz. I swear!
