Old 01-02-2006, 12:13 AM   #9871
Juan Valdez's Avatar
In case anyone's interested, I poseted my latest rubber tire carpet set up on the JRXS rubber tire carpet thread. I don't see much rubber tire carpet talk on here, so I thought I would try to spark the discussion. The set up is definitly a work in progress, so if anyone tries it, I'd welcome feedback.
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05 | Exotek F1R3
Juan Valdez is offline   Reply With Quote
Old 01-02-2006, 09:15 AM   #9872
Send a message via AIM to R/C Anonymous
i'd post mine but im too lazy
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 01-02-2006, 09:48 AM   #9873
Matt Howard's Avatar
I ran my setup again but this time at a really small and tight carpet track and it worked great again. I redid it so it's easier to read this time for anyone that wants to try it.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-02-2006, 11:51 AM   #9874
POOKYT's Avatar
Thanks Matt!!!! I can actually read this one without my binoculars!! LOL
I will give it a shot next week.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 01-02-2006, 12:10 PM   #9875
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Matt- AE oil!? Are you kidding me!!!!???? heheheh
Those of you who are posting your sheets here should definitely add your setups sheets to the JRXS.com site, if you haven't already....
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 01-02-2006, 12:14 PM   #9876
POOKYT's Avatar
Speaking of JRXS.com--Where's gearhead been lately? Any sightings?
Brant
Old 01-02-2006, 12:52 PM   #9877
Hey, that's all I had
I don't think I've bought a bottle of shock oil in years, these TC's use so little oil and don't need to be rebuilt that often.
RCTech #361
Old 01-02-2006, 01:29 PM   #9878
Has anyone else had a problem with belts flipping inside out (teeth out, smooth side on the pulleys) during a run? My rear belt has done it a few times, and I can't figure out why. I tightened it up, and it seemed to help for a while, but Saturday it flipped on me again. It doesn't seem to hurt the car when it happens (running rubber tire stock at least), but it can't be good for the belt. Any one else have this happen? Any ideas to prevent it from occuring?
Old 01-02-2006, 01:38 PM   #9879
Only thing I can think of is either your belt is too loose or something is rubbing against it. You should only have a little bit of play in your belts
RCTech #361
Old 01-02-2006, 06:51 PM   #9880
Trader Rating: 22 (100%+)
Send a message via AIM to 5thscaleracer
this might sound retarded but....
1. make sure the belt(s) track correctly nothing binding or any thign on it's path.
2. make sure your diff is not shifting left or right. the gray plastic tube has a tendency to shift slightly left and right easy fix is that tiny 2-56 buttom screw mount them on the inside rather than the out side. This will hold that tube in place and prevent it from shifting
3. Check the belt teeth make sure they are perfectly uniform (not too perfect but they all should be uniform)
4. check the pullies make sure there is nothing wedge in the coggs causing the belt to skip or make sure that the side walls of the pully is not portruding or pinching the belt.
5. belt tension is the key but i think your drive train is shifting around on you.
I had the front and rear diff shift around almost 1mm of play my center shaft has 1mm of paly right now i have sinced shimmed it all out.
hope this helps.
5thscaleracer is offline   Reply With Quote
Old 01-02-2006, 08:12 PM   #9881
Greg Sharpe's Avatar
Default Teamwork? Holly moly!
Anyone in here going to the Snowbird (inter-?)Nationals? It'd be really helpfull if we knew one another were down there to share setup info and bounce new ideas around.
So who's going?
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 01-02-2006, 08:55 PM   #9882
wish I could go....I think it would be awosme. BTW where is E-town Greg.
runnin rc10 is offline   Reply With Quote
Old 01-02-2006, 09:15 PM   #9883
Registered User
losirunner's Avatar
Send a message via AIM to losirunner Send a message via MSN to losirunner Send a message via Yahoo to losirunner
i have been having problems with the front diff loosening every run. I have rebuilt it a few times, but still every time it loosens.... what do i do>
losirunner is offline   Reply With Quote
Old 01-02-2006, 09:15 PM   #9884
New Jersey, short for Englishtown. Sadly, this track that many of us grew up at closed down after more than twenty years of racing. Since the days when slot cars were bigger than R/C, that place had some of the best action on the east coast.
Old 01-02-2006, 09:17 PM   #9885
Sounds like some portion of the thrust bearing/washer assembly isn't doing it's job. Take that thing apart again, looking for signs of abnormal wear or mis-assembly.
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
