Team Losi JRXS
Old 12-18-2005, 08:22 PM
  #9646
The Evicerator
Because you asked for me by name here are my suggestions
Skuba Steve setup?
0.030" sway bars
Raise the rear suspension mounts from low to high...
Steve Weiss is offline
Old 12-18-2005, 09:04 PM
  #9647
Matt Howard's Avatar
for those wanting a starting point on springs and oil with the new arms I basically ran craigx's setup with 30lb springs, 56 pistons and 50 wt in the front, and 17.5lb springs, 56 pistons and 35 wt oil in the rear and my car was pretty good today.
Matt Howard is offline
Old 12-18-2005, 09:50 PM
  #9648
POOKYT's Avatar
Originally Posted by DirtyDog3375
Hey Pooky,
Don't pay any attention to 2-bad, as he has trouble with other cars on the track......like driving them off the road!!!
As he would put it "it wasn't my fault, they were in the way or taking a slow line!"
Not to mention he never sent the plane tickets for me and JRXSBill! LOL
On your car, I would either put sway bars on it or go up 1 step on spring rates. Either should quicken your left to right transitions. Honestly though, if it were me I would leave the springs alone and take out 1 of the .050 spacers and replace it with a .030 for a total of .080 under the front blocks. Every time I have run the .100 under the blocks I really needed more steering and the .080 seems to be the ticket. Sway bars should not hurt you on a rough surface like increasing the spring rates will. I am afraid if you increase the rates or add sway bars you wil quicken the transition side to side but will loose steering and maybe rear traction. This is just a hunch so you may want to try lowering your front roll center first. I hope this helps
Brant
POOKYT is offline
Old 12-18-2005, 09:54 PM
  #9649
POOKYT's Avatar
How close did this feel to the set-up with the old arms and springs?
Brant
POOKYT is offline
Old 12-18-2005, 10:02 PM
  #9650
POOKYT's Avatar
Skuba Steve setup?
0.030" sway bars
Scuba Steve--Please don't wait untill your called by name to give us your opinion on stuff. All info and help is very appreciated.
Brant
POOKYT is offline
Old 12-18-2005, 10:58 PM
  #9651
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Skuba Steve setup?
0.030" sway bars
Once again Steve (aka Evicerator or Skuba Steve and any other aliases you go by ), you have been a very helpful. Much appreciated mate.
DirtyDog3375 is offline
Old 12-19-2005, 01:29 AM
  #9652
Trader Rating: 22 (100%+)
A tribute to JRXS and jrxs.com custom painted body by Shop UFO the master of all paint!
5thscaleracer is offline
Old 12-19-2005, 07:06 AM
  #9653
Brant
I only got a chance to run the car one time with the stock arms before I got the new ones so I won't be the best person to compare them back to back but the car felt more stable and easier to drive hard.
Old 12-19-2005, 10:07 AM
  #9654
Mike Haynes's Avatar
Brant
I also got the new arms this past weekend.
stuff that changed when i went to them:
60 to 30 front springs, kept 20's on back
cut down all 4 chock eyelets
took off both 050 sway bars i had on
raised rear inner camber link to long /middle..#4 from #7
added 1 degree of toe...3 total from 2
got rid of my prosquat, went to level
added 2mm rear droop
I also ran front tires all around to get steering, as my car pushed signifigantly.
The main difference i found is the chasis stayed flatter, and yeilded more cornerspeed and consitency. I though the car was more abrupt them my normal setup thogh, and had to run more rear droop to get the feel i liked.
BTW this is on very very high bite carpet, like glue when you walk.
Mike Haynes is offline
Old 12-19-2005, 11:16 AM
  #9655
mjcxtreme's Avatar
Hey Mike H, I finally got sick of my fttc4 and bought a jrxs. what a diff in handling. From a car that pushes on power with any thing you do to it, to a car that steers right out of the box. Sorry couldn't make it down to L.I. yesterday will positively go to the next trophy race you guy have. Matt C
mjcxtreme is offline
Old 12-19-2005, 11:20 AM
  #9656
Matt, glad to hear it...
When you come down i have a setup for you, maybe you can hook me up with somehting that works at madness, since my car obviously didn't last time. You guys missed a nice event this time, place was packed.
May just be the driver to..
Old 12-19-2005, 11:57 AM
  #9657
mjcxtreme's Avatar
Mike H, yesterday at Madness I used Paul Lemuix setup from the indoor champs. I ran 19t w/atlas motor 39/128 56.5 tires. I added bump out to the front .030 in 2nd qual helped with mid and on power steering. Qual 3rd behind mike d and mark s. In the main made a few mistakes ended upjust getting beat by Carrisa for third. Tried the long front camber link in the main. It just made the car very loose mid corner and push on power. Car was very twitchy.Just got the new front arms waiting for the rear ones to come in, then i will try the sfter spring setup. Very pleased with the response of the car to changes made. Matt C
Old 12-19-2005, 12:01 PM
  #9658
JRXS_chris's Avatar
Has anyone tried trimming the excess carbon fibre off that is around the electronics?
JRXS_chris is offline
Old 12-19-2005, 12:07 PM
  #9659
When i was there i just had push and that was it...ran hybrids all around and it was decent, looking back i see what i did wrong...o well... should have ditched my sway bars
I run 4 .030 washers worth of bump, and similar to pauls 2nd setup, i hated the long front link, and took it back off when i was there.
Wish i had the new arms then, just put them on my car last week and its much better at everything now.
Old 12-19-2005, 12:31 PM
  #9660
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
Originally Posted by CIVIC91
I don't even like oval, but I have to admit that's pretty cool.
I liked the colors in the car. Does anyone know if that company makes towers and other pieces for the stock jrx-s?
roadrashracing is offline
