Team Losi JRXS
Old 12-18-2005, 02:53 AM
  #9631
Josh Numan's Avatar
Trader Rating: 24 (100%+)
Ok, someone needs to post a link to where they see Todd as Tied for TQ. Cause the results that i see his best finish is a 7th.......where do you get the updated results?? If thats true Congrats. But from what i see its not true....
Josh Numan is offline
Old 12-18-2005, 06:15 AM
  #9632
Trader Rating: 29 (100%+)
http://worldcup.rcworld.ch/live.asp
after 3 rds he had 2 wins and a 7th and has added a 3rd and 4th now I think.....
Mdoc is offline
Old 12-18-2005, 06:19 AM
  #9633
Scotty Ernst as announcer those of you who never been to one of his announced races you are truly missing out on what announcing should be like
R/C Anonymous is offline
Old 12-18-2005, 06:26 AM
  #9634
with 5 rds finished its Mark R in first, Jilles G in second, Martin H in third....Todd H is in sixth...and Billy E in 14th.....one round left.......
Mdoc is offline
Old 12-18-2005, 08:09 AM
  #9635
Tornado_Racing's Avatar
Here is a pic of my 90% completed JRX-S Touring Oval chassis. Let me know what you guys think.
Options installed:
Xtreme Red CF Oval Chassis Kit
PRS Red Spur Gear Adapter
Losi Ti Ball Studs
Losi Sway Bars
Losi Ti Sway Bar Tie-rods
Losi CVD's (front)
Losi BK CVD Bearings
Losi Sway Bar Tie-rod Ends
Losi BK Arms Front/Rear
Losi Zero Degree Off-set Rear Hubs
Losi XXX-S Body Mounts
Parma Bumper
Fasteners-Express Red Aluminum Screws, Locknuts, Washers
All White and Grey plastic dyed black
Items to be installed this week:
Lunsford Ti Screws
Lunsford Ti Upper Shock Mounts
Lunsford Ti Hinge Pins
Dual Cooling Fans
Tornado_Racing is offline
Old 12-18-2005, 08:27 AM
  #9636
Core Creations's Avatar
Trader Rating: 99 (100%+)
I don't even like oval, but I have to admit that's pretty cool.
Options installed:
Losi Ti Ball Studs
Losi Sway Bars
Losi CVD's (front)
Parma Bumper
Lunsford Ti Screws
Dual Cooling Fans
Core Creations is offline
Old 12-18-2005, 10:01 AM
  #9637
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
Does any one know of someone that sells a thicker pan. Mine will not stay straight. I undid all the screws and tighten them up one a flat surface. I had the ride high set for 6mm on the front and rear yet it would not clear 5mm in the middle.
roadrashracing is offline
Old 12-18-2005, 01:47 PM
  #9638
  #9639
  #9640
a thicker chassis wont help you with that...u need to bore the pin holes and screw holes out a touch because the top deck is a bit off
Old 12-18-2005, 03:26 PM
  #9641
POOKYT's Avatar
Originally Posted by 2-Bad
Stop running into walls.....
I was on a perfectly tight line and the wall JUMPED out in front of me!!!! Uh......urrr......Something like that! LOL
Brant
POOKYT is offline
Old 12-18-2005, 07:22 PM
  #9642
Team EAM
Trader Rating: 79 (100%+)
Take your motor mount loose and make sure that when you put the pin of the motor mount in the chassis it sits flush. Mine had some flashing around it and it would bow the chassis when you tightened the motor mount screws. Filed the pin around the base and its perfect now.
EA
EAMotorsports is offline
Old 12-18-2005, 07:52 PM
  #9643
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Brant
Hey Pooky,
Don't pay any attention to 2-bad, as he has trouble with other cars on the track......like driving them off the road!!!
As he would put it "it wasn't my fault, they were in the way or taking a slow line!"
DirtyDog3375 is offline
Old 12-18-2005, 08:00 PM
  #9644
Need some advice on how to make the car transistion faster (from left to right and vice versa).
I am using the Josh Numan setup and race on an outdoor, concrete track that varies in elevation (downhill and uphill side - where all the corners are) using rubbers (sorex 36 with xenon black inserts).
I need to be able to change direction better in the left right left right corners going uphill. It seems to understeer during that part of the track, or not seem to be able to carry any corner speed through that section (compared with the local fast guys).
They (local fast guys) have suggested that I try putting sway bars on the car, but since the track is extremely bumpy and has varying elevations I am a bit reluctant to use them. Any ideas or suggestions??? As our racing season is now over, and I'm on holidays for 6 weeks - plenty of testing time.
Please help anyone......Todd, Josh, Steve, and even Pooky???
Thanks in advance.
Old 12-18-2005, 08:12 PM
  #9645
Team EAM
Thanks in advance.
Are you running the exact Numan setup?
EA
