Old 12-07-2005, 10:23 PM   #9481
Bink's Avatar
Originally Posted by chicky03
Hi Eric,
The -1 is supposed to be a +1 I messed up on the sheet. Which setup are you using the first one or the second one? Both are good you just have a few options for different tracks. Here are the links to both setups:
www.parmapse.com/jrx.jpg
www.parmapse.com/jrx2.jpg
Paul
Paul - on your second set-up you moved the bell crank plate below the steering levers. Why and how does this effect the feel of the car? Also, when would you suggest set-up 1 versus set-up 2?
Thanks!
Bink is offline   Reply With Quote
Old 12-08-2005, 08:26 AM   #9482
rayhuang's Avatar
Bink-thats a typo-he runs the drag link above with ballstuds pointing down.
OH-CRap-I just looked at the Craig set-up sheet to make some notes and realized I ran flat pins in back, not 0.050" pro-squat. That will take away some initial and add mid and on-power steering. Bummer-oh well, theres always the next practice night.....
Old 12-08-2005, 09:34 AM   #9483
chicky03's Avatar
Send a message via AIM to chicky03
Thanks!
I orginally typoed the secind setup but it is updated and the bell crank plate is above the balls with the balls facing down.
The first setup is better for higher grip. That setup will push more initially but have more on power steering. The second setup seems to work for both high and low traction.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 12-08-2005, 10:35 AM   #9484
RCGaryK's Avatar
Originally Posted by rayhuang
CRaig,
Thanks for posting that set-up. It has a ton of steering,epecially initial steering. I thought it was very reactive in transition. This was in 19t. When I installed the Novak Brushless with 5800 motor and geared it up the car got even better. I think this has serious mod potential. Easier to drive in mod than 19t and seemed like it had plenty of steering. And-I was running 2.14 tires. A fresh set of 2.20" and I am thinking how awesome it would be.
Ray
What setup were you running Ray?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 12-08-2005, 10:45 AM   #9485
rayhuang's Avatar
Originally Posted by CraigX
This is the setup I used for the US Indoor Champs in the stock class. Finished 4th. The car was insanely easy to drive, I was able to put the car wherever I wanted and turned lap times on par with anyone else in the class.
Gary-this post. Sorry too dumb to know how to post a link to the attachment.
p.310 post #9292
Ray
Old 12-08-2005, 11:37 AM   #9486
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Here ya go Ray.
http://www.rctech.net/forum/showpost...postcount=9292
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 12-08-2005, 12:51 PM   #9487
CraigX's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to CraigX
Glad to see the setup is working for you. Every change I made to my car at Cleveland was to try and gain more initial steering. Like you felt, seems like the changes did their job.
RC America, Xray, Hudy, Sanwa, Motiv RC, Gravity RC, Max Power America, Protoform, Avid, EA Motorsports, TQ Wire, Prolevel RC, Ulti, 5 Nines
CraigX is offline   Reply With Quote
Old 12-08-2005, 05:19 PM   #9488
Tornado_Racing's Avatar
I have a few questions:
1. Where do you guys get the 2 degree rear hubs and negative rear toe blocks? Alot of the on-line setups, the Team guys are using a zero or -1 degree rear block with a 2 degree hub.
2. Because the JRX-S one-way front diff is on back order (2 weeks) I purchased all of the parts to build a complete one. Where do the o-rings go as listed in this Picture?
I think the 2 smaller ones go in the one-way Plastic Outdrives but not sure where the single larger one goes? Does it go on the opposite side of the pulley (in the groove) next to the bearing?
Any and all info with part number or links would be great.
Tony Moffre
PRS Customer Service
PRS - Hyperdrive - EA Motorsports - Corally USA - Parma/Faskolor - SMC - Killer Koncepts - MSA - Finishline - IRS - Lunsford - Trinity - Guarantee Graphix - RC4Less
Tornado_Racing is offline   Reply With Quote
Old 12-08-2005, 06:54 PM   #9489
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Hey Craig X, you have a PM Buddy!!..........
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 12-08-2005, 09:15 PM   #9490
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
Default help with motors
I have been racing for about a 4 weeks now. I was just wondering if there I was any place that I could go that would give me information on rebuilding, what springs to use, brushes etc. I don't know much about motors. I am running 27 turn. I am about 1.5 sec behind and tring to find some time. anything will help thank you!
roadrashracing is offline   Reply With Quote
Old 12-08-2005, 10:05 PM   #9491
Moderator
Another thing, I have heard of people putting bearings in the front drive, I was just wondering if an had a pick of what it looked like.
Old 12-08-2005, 10:59 PM   #9492
POOKYT's Avatar
For motor help click on my signature line for EA Motorsports. He is the man!
As for the "BK Bones" or bearings pressed on the pins you need the small steering bearings from the XX,XXX,XXT,XXXT vehicles. Once you have these bearings you need to take a Dremel( hold your applause people! ) with a light grinding stone and run this around each pin to reduce their size just a tad so the bearings can be pressed on. The LCD's need more taken off for the bearings to fit but the CVD's will only need a little. My opinion is that if you run a spool then I would NOT use the BK Bones on the LCD's. With a spool the front drive train takes a lot of abuse and the bearings won't hold up. If your front drive is a diff or one-way then you will be fine. I have run the BK bones on my rear CVD's all season with no trouble. I hope this answers your questions. Good Luck!
Brant
P.S. once the bearings are pressed on the pins you should make sure they are close to the dog bone but not in a bind. WARNING!!!!! These little bearings don't like to be pressed very hard or tapped on very much! I know first hand! LOL
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 12-08-2005, 11:06 PM   #9493
POOKYT's Avatar
Check JRXS.com to see pics of what the bearings look like on the dog bones. I believe the very first pic we got a look at of the LCD's were a set out of MF's car and they had the bearings on them.
Brant
Old 12-09-2005, 12:16 PM   #9494
Moderator
Brant
Is there a difference of using the bearings or using the smaller slot on the out drives? I have the bearings laying around but my car has little play with the smaller slot.
Old 12-09-2005, 02:42 PM   #9495
RCknight's Avatar
Default Deep private thoughts by POOKYT....
"Humm....I know I want one of the Xray T2s, but I told people that this car's sooo great, what do I do....how do I get out without anyone knowing....humm....oh....jeesh...."
RCknight is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
