Old 12-06-2005, 08:55 PM   #9466
RCGaryK's Avatar
Ray, stupid question...6 degrees caster, all at the c-hub or is there kick up under the suspension mounts AND the C-hub?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 12-06-2005, 09:01 PM   #9467
rayhuang's Avatar
6-deg c-hub with anti-dive. So ts really about 4.5 to 5 degrees.
Old 12-06-2005, 09:03 PM   #9468
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
Does anyone any front a-arms that hey would like to sell? Are trade for some rear?
roadrashracing is offline   Reply With Quote
Old 12-06-2005, 09:04 PM   #9469
rayhuang's Avatar
Originally Posted by roadrashracing
I am going try that set up at road rage tomarrow I'll let you guys know how well it works.
Cool-I never ran it-mind you-but ti TQ'd and won the All Star rubber class so I assume its good.
CraigX-I got your set-up on my car. Last three questions:
1. How big of a turning circle to start?
2. Any changes for 19t?
3. Why the o-ring in the back shock?
Thanks in advance,
Ray
Old 12-06-2005, 09:05 PM   #9470
RCGaryK's Avatar
thanks Ray-Ray
HorizonHobby.Com
Old 12-06-2005, 09:12 PM   #9471
rayhuang's Avatar
thanks Ray-Ray
One change-front hinge pin block is 1 deg, not 0. Noticed that when converting the car to Xaviers set-up.
Old 12-06-2005, 09:29 PM   #9472
RCGaryK's Avatar
so the front arms are swept out a bit then?
HorizonHobby.Com
Old 12-06-2005, 10:59 PM   #9473
CraigX's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to CraigX
At cleveland I could just barely make a u-turn on the straight of the track but I usually run less d/r than most I think
I ran the same exact setup in 19t and it worked just as well
Not exactly sure, just built the shocks like that, I don't really mess with the o-rings. I'm guessing a second o-ring would result in more rebound which may help the car transition quicker. With no o-ring doing the opposite?
Let me know how the setup works for you.
RC America, Xray, Hudy, Sanwa, Motiv RC, Gravity RC, Max Power America, Protoform, Avid, EA Motorsports, TQ Wire, Prolevel RC, Ulti, 5 Nines
CraigX is offline   Reply With Quote
Old 12-07-2005, 07:44 AM   #9474
rayhuang's Avatar
yes.
Craig, thanks for the info. I was theorizing that your car had a big turning circle judging from the set-up. It was so smooth to watch, yet this set-up looks like an aggressive mod set-up with the 50 lb springs and 6 deg caster with flat pins. I cannot wait to try it tonight.
Old 12-07-2005, 12:37 PM   #9475
E2
Guys,
Just got my JRXS and I'm putting the Ciccarello carpet set-up on it. Does any one have the part number for the -1 rear pivot blocks?
I also want to double check that the ball studs on the steering rack point toward the floor and that there is really .060" of washer under each.
Thanks,
Eric
E2 is offline   Reply With Quote
Old 12-07-2005, 01:12 PM   #9476
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by E2
Guys,
Thanks,
Eric
Hi Eric,
The -1 is supposed to be a +1 I messed up on the sheet. Which setup are you using the first one or the second one? Both are good you just have a few options for different tracks. Here are the links to both setups:
www.parmapse.com/jrx.jpg
www.parmapse.com/jrx2.jpg
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 12-07-2005, 01:51 PM   #9477
E2
Paul,
A response from the man himself, now that's service! lol
I am using the first setup initially but will try #2 as well.
Thanks,
Eric
Old 12-07-2005, 01:59 PM   #9478
The Evicerator
Chica-Chica-Chicarello-arello!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 12-07-2005, 02:22 PM   #9479
MadBrushRacing's Avatar
Hi all
Has anyone got a good starting setup for racing in the cold in tarmac in sunny England!!!!!! I don't have the BK brackets.
MadBrushRacing is offline   Reply With Quote
Old 12-07-2005, 09:20 PM   #9480
rayhuang's Avatar
CRaig,
Thanks for posting that set-up. It has a ton of steering,epecially initial steering. I thought it was very reactive in transition. This was in 19t. When I installed the Novak Brushless with 5800 motor and geared it up the car got even better. I think this has serious mod potential. Easier to drive in mod than 19t and seemed like it had plenty of steering. And-I was running 2.14 tires. A fresh set of 2.20" and I am thinking how awesome it would be.
Ray
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
