Old 12-01-2005, 07:27 PM   #9331
Send a message via AIM to R/C Anonymous
Originally Posted by CraigX
The kit setup is to have the plate above the bellcranks, studs pointing down. I have never used it below(studs pointing up) but the reasoning behind all the bump steer washers under the steering knuckle stud was for more bump-out. Which I feel, gives the car more initial steering.
sweet this is something i just might have to try
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 12-01-2005, 07:27 PM   #9332
Matt Howard's Avatar
Craig is my hero
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-01-2005, 07:40 PM   #9333
@ Kinwald:
on your setup sheet it says you have high and low roll center...can u explain that a little bit please...this is a setup i would like to try and what would you recommend changing going from your setup to a stock motor?
Geoff C.
Old 12-01-2005, 08:10 PM   #9334
rayhuang's Avatar
Craig-thanks. I looked at my set-up sheets and realized mine is above too-duh!!
As for the bump-for what its worth I run 0.06 on the drag link and a short ballstud and 0.090" on the steering knuckle with a short ballstud. Pre-Champs I took out all the shims on the steering knuckle and I picked up a ton of cut and in long corners car just kept steering. I put it back to raised 0.090" on knuckle. It was crazy steering.
Ray
Old 12-01-2005, 08:11 PM   #9335
Still Bill's Avatar
Originally Posted by DIRT
If any of you get bored This is my SoCal setup..On the droop and uptravel settings...10mm droop,,means when the chassis is 10mm off the ground,,the tires just touch...3mm uptravel means when the chassis is bottomed out,,you can still pull the tire up 3mm
  • TTSO,,,YES,,And no ,,,it's just easier to drive
Thanks Brian.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 12-01-2005, 08:16 PM   #9336
RussB's Avatar
Send a message via MSN to RussB
n00b question, i don't check this thread very often (last time i did it was only around 200 pages)... are the new a-arms out yet?
RussB is offline   Reply With Quote
Old 12-01-2005, 08:32 PM   #9337
Still Bill's Avatar
Maybe in another two hundred pages...
Old 12-01-2005, 08:56 PM   #9338
Soon!
RCTech #361
Old 12-01-2005, 09:00 PM   #9339
Trader Rating: 22 (100%+)
Send a message via AIM to 5thscaleracer
ok guys... i have a legit question for a change.....
how can you increase onpower steering. Powering out of a turn and steering farily tight corners back to back. Will running more caster in the front help this?
Thank you in advance guys...
5thscaleracer is offline   Reply With Quote
Old 12-01-2005, 09:31 PM   #9340
Originally Posted by mr. losi
brian,
cool set up sheet you have all the cool stuff
will you be at the novak race this year???
Matt
"Thanks"...I sure hope so..
DIRT is offline   Reply With Quote
Old 12-01-2005, 09:36 PM   #9341
use a spool will increase it...lessen caster...standing the rear shocks up a touch might help...maybe im wrong...correct me if i am
Geoff C.
Old 12-01-2005, 09:40 PM   #9342
RussB's Avatar
Originally Posted by Matt Howard
Soon!
:rotfl: just wanted to make sure my car is still current, it has been a few weeks since i looked at it.
Old 12-01-2005, 09:41 PM   #9343
Originally Posted by rayhuang
Whats the change in steering feel when going from the drag link below the steering levers to above? I also notice quite a bit of shimming to adjust bump. Would Dirt or Xavier wish to elaborate?
Thanks,
Ray
It really doesn't matter where you mount the bar,,up or down..the important thing is the angle between the ballstud on the rack and on the spindle..The higher the ball on the spindle in relation to the ball on the rack,,the more bump out you will have,,typically this will make the car get in to the corner harder,,"but not always"..On this car i like a lot of bump out..
Old 12-01-2005, 09:43 PM   #9344
biker's Avatar
Hey guys, new jrxs owner here....
Anyone have recommendations for identifying Losi springs that have had the tags removed? Is there a chart that would outline the different weights by dia of the coils?
Any advice is appreciated...
biker is offline   Reply With Quote
Old 12-01-2005, 09:44 PM   #9345
Randy Caster's Avatar
Trader Rating: 46 (100%+)
If you're trying to get it at SoCal, use the JR link on the front end, it felt like it had a lot more on-power steering to me. To get the initial turn in back into the car, try .030 of anti-dive.
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
