Team Losi JRXS
#9184
Originally Posted by Dasupacat1
Quick question. On the Numan setup. For the front suspension is it .050" shims on just the front pivot or both the front & the rear pivot blocks.
Brant
#9185
I finally got my alu big battery tray. Now I'm paranoid that it will short out my batteries. Is this a real problem and is there anything I should do as a precaution?
Ira
Ira
#9188
#9189
R/C Tech Elite Member
Ira
Ira
#9190
Originally Posted by Josh Numan
Its exactly how Pookie said it was. Thanks Pookie!!
Brant
#9192
Just a note here on the Numan set-up. When I used the camber mod with the Numan set-up I had to change to 1 .050 front shim and use one of the thin shims under the rear blocks. The camber mod gave a lot of total steering and the change in roll center made my car the best it has ever handled all year. Thought you should know.
Brant
#9193
Originally Posted by dasdaman
Guys,
I know the front arms are labelled left and right, but if you turn the left arm upsidedown is it the same as a right? and can it be placed on the right side that way? Or do I have to buy a set just to get the right arm.
#9195
Originally Posted by Matt Howard
Well I finally got a chance to run my jrxs last night after looking at it for 3 weeks, LOL. There was only a stock class so I had to go buy a stock motor but I ended up beating the track record by 6 seconds and taking home the win. So far so good.
