Old 11-20-2005, 02:37 PM   #9121
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Randy Caster
A spool gets around the track really well, but I do think the 1-way has a slight advantage on most the layouts. I mostly always run the double 1-way setup when I do chose to go that route.
Yes I agree that one-ways can be a lot quicker if your drive on your own.
If the track you running on has a couple of hairpin turns or at least very tight turns then I would imagine the spool would be better during a race, because you can defend your corner and/or attack it with the braking & exit acceleration advantage of the spool. The one-way can be a distinct advantage "if know one is pressuring you from behind" as you would need to sweep a lot of these types of corners.
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 11-20-2005, 03:57 PM   #9122
Send a message via AIM to R/C Anonymous
a one way was always faster on my TC3 when i ran it over a diff on rubber carpet...i never ran a spool on the TC3 so i cant compare it too that
on the JRXS i run the spool and imgonna try the one-way soon to see the difference in lap times with adjustments
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 11-20-2005, 07:57 PM   #9123
Hey guys, just need some quick advise. Ive put a full numan setup on my car and took it for a drive. It either had way too much steering and the back end was all over the place or there was no grip in the rear. I tryed with some sorex 36s on the front and rp30s on the rear and I had not much steering at all. I then tryed the rp30s on the front and yokomo 138gs on the rear which was only slightly better than the rps all round. Im racing on a short tight high grip track, running a 12t motor. Any suggestions anyone???
Floss_LUC is offline   Reply With Quote
Old 11-20-2005, 08:07 PM   #9124
Still Bill's Avatar
For asphalt, I always have used the same rubber on front and back on my JRX-S.
Usually is:
Cold...CS22 or Sorex24
Cool...RP30
Warm...CS27 or Sorex28
Warmer...T32
Hot...Sorex 36
For Carpet: CS27 (front)/CS22 (rear) or Sorex28/Sorex24
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 11-20-2005, 08:08 PM   #9125
Still Bill's Avatar
How much droop in the rear?
Old 11-20-2005, 08:17 PM   #9126
4mm - 4.5mm
Old 11-20-2005, 08:28 PM   #9127
Still Bill's Avatar
4mm - 4.5mm
Matt Francis had me jump from 3mm to 5mm at the rear for similar reasons.
Old 11-20-2005, 08:41 PM   #9128
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Unfortunately I didnt TQ last night, and with Numan and Weiss in front of me, the 1 way was definately the way to go. With a 1 way or a spool, once you get in the lead you just have to use the same lines you would as if you were driving on your own, it can be harder under pressure, but it will be nearly impossible to get a clean pass in from the guy behind you.
Old 11-20-2005, 08:47 PM   #9129
Thanks, will try that.
Old 11-20-2005, 08:48 PM   #9130
my car pushed going in and the rear eand came around rather quickly upon acceleration...i was running CS27 tires on carpet with the Numan setup....to calm the backend down i lengthened the camber links on the rear to the longest and flatest possible setting and gained .3 a lap...i think the car like the rear end planted like my 'Cuda R2 did
Geoff C.
Old 11-21-2005, 03:33 AM   #9131
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Originally Posted by Dasupacat1
Well just got my brackets from 5thscale' (THANX). Now do I have to cut down the shock ends? Looks like I should but dunno... If so how much should I take off?
Anybody??
Dasupacat1 is offline   Reply With Quote
Old 11-21-2005, 03:37 AM   #9132
Fatboy Joe's Avatar
Anybody??
1/8" from the shock ends.
Fatboy Joe is offline   Reply With Quote
Old 11-21-2005, 03:55 AM   #9133
Timmy_G's Avatar
Send a message via MSN to Timmy_G
For the first time since I bought my JRX-S in May 05, I've finally got this car working. I raced in the South Australian Titles here in "down under" on the weekend just passed. JRX-S took out 4th, 7th and 9th in Modified Touring Car A-Mains in a field of predominantly fully sponsored drivers (none of which raced Losi). JRX-S was most strongly represented in Mod TC of any manufacturer.
Losi, JR Propo ,Spektrum, Novarossi, AT Racing Fuels
Timmy_G is offline   Reply With Quote
Old 11-21-2005, 06:47 AM   #9134
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Glad to hear that you got your car working. I also race in Australia (Brisbane, QLD) and besides my car there is only one other JRXS at the moment.......but it looks like we might have a few more now, time will only tell.
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 11-21-2005, 06:49 AM   #9135
Just wondering when the new arms will be available???
(LOSA9739a and LOSA9861a)
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
