Old 11-15-2005, 05:45 PM   #9046
POOKYT's Avatar
Originally Posted by dstyles
hey brian,
i've noticed that after running with a spool, one of the front LCD's develops more 'play' in it than the other. i've rebuilt them with the kit and still found this slop. it was solved only after buying completely new LCD's. is there any way to prevent this or is it an expected outcome of using a spool.
thanks.
I recently rebuilt mine after most of this past season. I found the same slop too after the rebuild. The only slop I can find now is in the axel itself. Hope this helps.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 11-15-2005, 05:48 PM   #9047
POOKYT's Avatar
Originally Posted by JRX-S Bill
Don't you ever go to bed???
And......Yes! Not enough but hey!!!!! I'll sleep when I'm dead!
Brant
Old 11-15-2005, 08:06 PM   #9048
Still Bill's Avatar
Default Thanks
Brian,
Thanks for the post on how you do your shocks.
Was close; but, will definitely try YOUR way.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 11-16-2005, 06:48 AM   #9049
chicky03's Avatar
Send a message via AIM to chicky03
Default Carpet setup
Hey guys,
Here is the current setup that I have been using and the fast stock guys at The Gate have been using. I forgot the front camber link hole is in the #1 position. You can also try 70wt oil in the front.
http://www.parmapse.com/jrx2.jpg
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 11-16-2005, 07:56 AM   #9050
Still Bill's Avatar
Originally Posted by chicky03
Hey guys,
Paul
Hi Paul,
So this setup is without the new arms or BK shock brackets (ala Numan setup)?
Thanks.
Bill
Old 11-16-2005, 08:08 AM   #9051
chicky03's Avatar
Hi Paul,
Thanks.
Bill
Correct. If you want to try the BK/new arms in the rear I would start with 15-20 springs and 55 pistons with 40 weight.
Paul
Old 11-16-2005, 08:34 AM   #9052
rayhuang's Avatar
Hey guys,
Paul
This set-up SUCKS!! Anyone running the Champs, dont do it Cause then youll be a lot faster-DARN you Chicky!!
Old 11-16-2005, 11:00 AM   #9053
weliin's Avatar
Hey guys,
Paul
Did you test the 2 deg pivot wtih 0 deg hub with this setup? Supposivly having the toe-in all in the hub will create a bit less initial steering on corner entrance than with all the toe in the inner pivot point.
Thanks for sharing. Your last setup was very well balanced. I'll give this one a try either tonight or Saturday.
Best of luck to the JRXS owners at the Champs.
weliin is offline   Reply With Quote
Old 11-16-2005, 11:20 AM   #9054
chicky03's Avatar
I have tested it but that was when the car first came out. I can't really say how much of a difference there is since it was so long ago.
Paul
Old 11-16-2005, 04:11 PM   #9055
Mike Haynes's Avatar
Paul,
This setup is for the rear motor correct? Do you know if it will feel good on the mid motor?
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 11-16-2005, 06:14 PM   #9056
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Good question!!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 11-16-2005, 06:20 PM   #9057
Originally Posted by rcracingkid
Paul,
One more thing, are you using the funky long front camber links?
Thankx
Old 11-16-2005, 07:46 PM   #9058
Hey guys,
Paul
Hey Paul, do you have a good setup for rubber tires?
outlandr91 is offline   Reply With Quote
Old 11-16-2005, 09:25 PM   #9059
where can i get BK brackets?
Nevada is offline   Reply With Quote
Old 11-16-2005, 11:12 PM   #9060
TCR
Default Brackets
From here::
Click here for your Bk / TH Brackets
TCR is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
