Old 11-09-2005, 11:17 PM   #8926
POOKYT's Avatar
Originally Posted by ottoman
I am looking for a set of JRXS shocks... does Losi sell a shock kit or will I have to buy all the parts separately?
Right now the shock kits are reported to be due out after the first of the year. This is from the Horizon web site.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 11-10-2005, 02:51 AM   #8927
Originally Posted by T. Hodge
Part numbers for new BK bracket arms
Front is LOSA9739A
Rear is LOSA9861A
Todd,
This is great news, thanks. Will we need any additional parts to use these brackets? I noticed on my JRXS that when putting the front shocks on the innner hole on the upper shock mount, they rubbed against the outdrives unless I added several spacers to push the top mount further towards the front of the car. So, for example, will I need to find some more spacers (any anything else) to get everything to fit the new arms in the "Numan" setup?
Thanks,
Ira
iblumberg is offline   Reply With Quote
Old 11-10-2005, 06:53 AM   #8928
Trader Rating: 22 (100%+)
Send a message via AIM to 5thscaleracer
Originally Posted by iblumberg
Todd,
Thanks,
Ira
these are a direct bolt on it's actually a complete suspension arm and not bracket extensions like the ones i have. But the spacing your talking about on the top will be required still i have been forced to do this as well since the spring would hit the outdrive and rub.
5thscaleracer is offline   Reply With Quote
Old 11-10-2005, 06:54 AM   #8929
Brant
so your talking a minimum of "8 weeks" Sweet... much better than "2 LOOOONG weeks"
Old 11-10-2005, 07:49 AM   #8930
TLRacing
Todd Hodge's Avatar
Where did you get that nice design for your brackets?
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 11-10-2005, 07:50 AM   #8931
TLRacing
Todd Hodge's Avatar
Originally Posted by EAMotorsports
I got an extra radio...come on over....Im sure we can put that losi in its place...The B main!! LOL
EA
WOW....
Todd Hodge
Old 11-10-2005, 07:51 AM   #8932
TLRacing
Todd Hodge's Avatar
Originally Posted by highwayman
what would you guys recommend as good hop-ups for the JRX... does haorizon carry them? thanks- jason
The biggest thing is the big battery tray. Part number LOSA4309.
Todd Hodge
Old 11-10-2005, 07:52 AM   #8933
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
WOW....
I guess I should have stated that "Put Pooky where you belong....In the B main" Not Losi....
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 11-10-2005, 07:54 AM   #8934
TLRacing
Todd Hodge's Avatar
Originally Posted by TCR
Maybe someone can clarify somthing for me
the kit comes with, 0 1 and 2 degree pivot blocks
I'm running 2 in the back and 0 in the front
If I want the alum. mounts to replace what I'm running, which ones do I buy
Do I get
0 & -2
why is there a +1 and +2?
Does this give you options not avalible at all with the stock mounts?
Can Todd or someone clarify the optional mounts.
Todd I'm glad these are finally avalible, nice work
If you want the aluminum mounts you will want to buy the 0 and 2 degree mount. There is a -1 and -2 mount for other options. For a while we were running a -1 front mount to get more steering. However right now we are on hold for making the -1 and -2 mounts until we get all the regular mounts and pivots made.
Todd Hodge
Old 11-10-2005, 07:55 AM   #8935
TLRacing
Todd Hodge's Avatar
Originally Posted by WD40
I wonder how much people are willing to pay for one of these new battery trays. I have one but don't have any cells larger than 3300 so I guess I don't need my new aluminum battery tray.
I use this tray with 3300's also.
Todd Hodge
Old 11-10-2005, 07:57 AM   #8936
TLRacing
Todd Hodge's Avatar
Originally Posted by EricF
Pookty... is a Twinky... I don't think I'd admit to that on WWW let alone this thread. DOH!!
Mr. Hodge
Are you going to make it the SIGP?
E
No, Matt Francis, and Gil Losi Jr are doing some testing at our carpet test track for the next 3 days in preperation for Cleveland.
Todd Hodge
Old 11-10-2005, 08:02 AM   #8937
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
3x8 thrusts with carbide balls on special at www.axiommotors.com if anyone is interested.
dgullickson is offline   Reply With Quote
Old 11-10-2005, 08:05 AM   #8938
Still Bill's Avatar
If you have a 6-pack of 3300 cells built normally (cells tightly positioned side-by-side), they tend to sit awkwardly in the aluminum tray.
Making a slight gap between each of the 3300 cells in a pack allows them to settle into the expanded slots of the aluminum tray. This emulates the wider spacing of 3700/3800 cells.
When will the new arms be available?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 11-10-2005, 08:06 AM   #8939
Still Bill's Avatar
Gilroy or Stockton? he, he...
Does that include Saturday?
Old 11-10-2005, 09:24 AM   #8940
weliin's Avatar
So does the -1 and -2 mounts add toe-out the inner hinge pins so the setup would be similar to that of the XXX-S on the front?
Also what would be the difference in running #2 pivot pivot mount in the rear with 1/2 deg offset carriers turned backwards for 1.5 deg of toe-in vs running #1 pivot mount in the rear with 1/2 deg offset carriers mounted normally for 1.5 deg of toe-in?
weliin is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
