Old 11-06-2005, 06:14 PM   #8836
Default Jim, Pooky and 5th scale
Thanks, Guys. from all of your replies it seems like I should lose the one-way so I'll try that first.Thanks again.
outlandr91 is offline   Reply With Quote
Old 11-06-2005, 08:25 PM   #8837
weliin's Avatar
Has anyone tired cutting every other tooth off the belts on this car. I know I tried that with the XXX4 I had and it worked great. This belt system seems much more free though in comparison. Just wondered if anyone has tried it and if there was any noticable benifets on the track.
Also my front belt runs right next to the pully wall/guides. My rear belt runs smack dead in the center of the pully. I tired shiming the front diff a bit to combinsate but the belt simply wants to ride on the guildes. With the XXX4/XXXS adjusting the how the belt rode was pretty easy to do with shimming the bearings with layers of glue. This car there doesn't seem to be a good way to make that adjustment. Maybe I'm overlooking something. Any suggestions?
weliin is offline   Reply With Quote
Old 11-06-2005, 09:29 PM   #8838
WD40's Avatar
For me the Numan set-up gave up no steering over the kit set-up. It settled the car down and allowed for me to make more of the fast lap times that I could hit with the kit set-up. If you put the Numan on it and you need more center out steering then run the 6 deg. blocks. If then you need more turn in go from the .100 shims to .80 under the front roll center blocks. Try that and you should be very close. Good Luck
Thanks for the info Brant!! I'll be sure and try those things out after I get my brackets in the mail. I really hope they come in tomorrow
WD40 is offline   Reply With Quote
Old 11-06-2005, 10:41 PM   #8839
POOKYT's Avatar
Your welcome! I hope it works for you as good as it does for me.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 11-07-2005, 06:59 AM   #8840
jland's Avatar
Trader Rating: 74 (100%+)
Originally Posted by tim fry
Any chance you could send it to me?
Tim
Tim PM'ed it to you,
Justin
jland is offline   Reply With Quote
Old 11-07-2005, 09:39 AM   #8841
promatchracer's Avatar
Send a message via Yahoo to promatchracer
I have kind of a stupid ?
We are running a huge Oval trophy race this weekend and I ran it Sat on the Oval which has a 205' drive line with 85' straights
The car ran great I did 5.6 sec laps but after we where done for the day I looked at the car and it has a lot of black on the left of the chassis
I know this is from rubbing the carpet My ? is can I just lower the shock collars and compress the srping more to help it
What will that do to the rest of the car for handling
promatchracer is offline   Reply With Quote
Old 11-07-2005, 12:50 PM   #8842
Randy Caster's Avatar
Trader Rating: 46 (100%+)
You guys are running a right handed oval? If it's scrubbing the chassis I would go with stiffer springs or even swaybars to try to take some of the roll out of the chassis.
Old 11-07-2005, 01:02 PM   #8843
RobertV's Avatar
Originally Posted by jland
One more thing. Does any-one really know the concept and thought about going to a rear mounted motor design?
Someone asked Matt Francis that exact question this weekend and his answer was that the different location had to do with the gyro effect of the motor. Having the motor in the forward section of the car would tend to make the car push, while having it mounted in the rear would promote oversteer.
RobertV is offline   Reply With Quote
Old 11-07-2005, 01:40 PM   #8844
rayhuang's Avatar
weliin-I dont think anyone is cutting teeth on the belts. For sure I wouldnt cut any teeth on the grey belt. If you did the white belt-unlike on the Xray 04's or the XXXS's-I dont think youd feel a difference as drivetrain efficiency appears to be excellent already.
Old 11-07-2005, 02:09 PM   #8845
weliin's Avatar
That's what I was leaning towards but was just wondering if anyone tired it. I've never had a belt car run this efficently.
Old 11-07-2005, 02:12 PM   #8846
Josh Numan's Avatar
I believe J Filipow was running cut belts with no problems mainly in 19 turn, dont know of anyone doing it for mod, but I dont think it would be any problem.
Josh Numan is offline   Reply With Quote
Old 11-07-2005, 03:55 PM   #8847
TheCoolCanFanMan's Avatar
Do you guy's remember Isaid I had a rather large tweak when I built my new JRX-S !!!!!!!!!!! well
My car was great on rug, well it was until I decided to re-build it that is, you see, When I first built it there was a massive tweak in the car when I first built it! the left rear shock collar was wound down at least 3mm more than the right rear shock, and the front right shock was wound down 2mm more than the left front so as to balance it out on the tweak station (frustrating or what ) so ran it like that for the first meeting, and was built to stock. The back end was real lose, so I put some 1 degrees rear hub carriers on tuned over the rear wishbone retainer, and front rear wishbone retainers, so as to lower the centre of gravity at the rear and reduced the rear droop from 4 to 3mm and was bang on the money. Then I decided to re-build it so as to get rid of the tweak (not that I was in a hurry when I first built it as im not like that with my builds) I stripped it right back and re-built it checking on a flat plate as I mounted each individual part, but low and behold, come to checking the car on the tweak station, it had the same bloody tweak, I could not believe it. So i took it with me Friday to our club night and showed one of the guys that has been racing for arns, and sussed it in 2 minutes, the rear bulk head set are of different heights by 1.5mm and same with the fronts GGRRRRRRRRRRRRRRR!!!!!!!!!! Anyone else come across this? im gutted now i have to mess about shimming the bulk heads to equal hieghts
Malc TCCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 11-07-2005, 04:02 PM   #8848
Originally Posted by POOKYT
Thank You Sir! Yes on my birthday flags will Fly! And there will be a Parade downtown! You are all invited! No RSVP just hang out by the curb and I will toss you some candy as we parade by.
Now Bill! You get over in Matt or Todd's pitts and get me a set of those new arms for my B-day! LOL
Brant
Yo POOKYT
Happy B/day (when was it?) mines on the 8th
TCCFM
Old 11-07-2005, 05:39 PM   #8849
POOKYT's Avatar
Originally Posted by Trakside Trucke
Yo POOKYT
TCCFM
Thank You Sir!! Actually it is on Friday. Happy B-Day to you as well.
We sure are getting along better in here than on the DC Motorsports thread! LOL That was cool to read.
Brant
Old 11-07-2005, 06:47 PM   #8850
itsjusme's Avatar
Default Web Site
Why is the JRX-S website gone???
itsjusme is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
