Old 10-15-2004, 03:45 PM   #871
Send a message via ICQ to Cobra81li200
Originally posted by Stealth_RT
I asked Andrew about the different colored belts. Evidently, they are different compounds, hence the different colors. Kinda like the green and blue center/front belts on the Street Weapon. I would guess that the rear belt is made to be stronger, while the front belt bends more easily to reduce drag.
Or they just are not the same length and it's just a matter of knowing easily which one is which.
Or both...
Cobra81li200 is offline   Reply With Quote
Old 10-15-2004, 03:49 PM   #872
cartmen34's Avatar
Someone.... we need an applause emoticon for SpeediPHATT..... he speaketh the truth!!
The only reason I hardwire is because I've had everytype of R/C style connector come apart in a hard enough hit, and usually the corner worker would just sit the car down instead of checking my connectors to see if the battery was still plugged in.
Those golden, "euro style" connectors are the worst IMO. Over time they become weak and loose their ability to stick. In more than one instance, I've come off the track to find those connectors half in, half out, or just about to fall out completely.
But hey....that's just what I've experienced...your results may vary.
So I just hardwire, keep my stuff clean and I have no problems.
cartmen34 is offline   Reply With Quote
Old 10-15-2004, 04:06 PM   #873
rod_b's Avatar
Send a message via AIM to rod_b
I'm sorry if this has been asked already but...are the batteries loaded into the car from below?
rod_b is offline   Reply With Quote
Old 10-15-2004, 04:10 PM   #874
POOKYT's Avatar
Originally posted by JimMcClure
Pooky,
My film is getting developed. I thought they were gonna call security on me when I started picking it up and snapping pics. Lots of stuff is still secret I guess. When some questions were asked about outdrives and diffs and such all I got was a big smile.
007 Jim on the hunt for Pics! I bet they were a lil weird when the camera appeared. Glad you were able to escape!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 10-15-2004, 04:12 PM   #875
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Originally posted by Keith Billanti
im sure they would physically go in the car,, but routing the pigtail may be an issue.... at one end you have a spinning diff and the other a layshaft...
Again, with the ideal that a pro level car is to be used with pro level equipment, fitting a stick pack most likely wasnt considered an essential feature for the already cramped quarters...
I could be wrong...
Perhaps Hodge could chime in here...
In Japan stick packs are the norm, pro level and every level in between. So whether stick packs fit or not was probably based on the most likely user not "level".
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 10-15-2004, 04:19 PM   #876
EricF's Avatar
Originally posted by SpeediePHATT
You dont really loose any efficiency using connectors over hardwireing. That is just a myth. The difference is so minimal its insignificant to our application... If ya think Im wrong go do the tests. I did and the numbers werent even worth writting down.
Personally I have not done any tests, but to me it's insignificant.
I use plugs because I grew tired of having a to have a hot iron ready all the time. In my statement I was only trying to point out a way that using plugs could still be accomplished.
E
EricF is offline   Reply With Quote
Old 10-15-2004, 04:22 PM   #877
EricF's Avatar
The link on page 27 or 28 there's a photo of the bottm of Hodges car with the battery tray removed.
Old 10-15-2004, 04:26 PM   #878
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Hmmmm....I bet Masami's competition at the World's in two weeks is hoping HE will be using stick packs!
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 10-15-2004, 04:37 PM   #879
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Man what planet are you talking about....the last time I saw a stick pack used at a Pro level event in Japan was for a set of tire warmers ... but really I have only seen stick packs used at a TCS race where the rules state you have to use them... other than that the "norm" in Japan in Bare cells..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 10-15-2004, 04:52 PM   #880
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
actually in japan stick packs are more common... i used to race with a guy a few years ago from japan.. he used to let me look at hios japan rc magizines... ( they read back to front.) anyway.. all i saw in it was stick packs.. why do u think when tamiya first made pro level cars they were in stick pqack form, with the option of saddle cells... now i think the side by side packs are getting to be more common there...
burbs is offline   Reply With Quote
Old 10-15-2004, 04:55 PM   #881
well, might as well add my comment, in the UK, most of the tracks (read 99.9%) of the tracks, you have to provide your own power source, so having a soldering iron on quite a bit of the race day would me one hell of a big 12V battery, so hard wiring in the UK is almost non-existant. I mean, most race meetings are held in the middle of nowhere.
In the US, a lot of the tracks do seem to have dedicated pit areas, with supplied mains level voltage, so you could have your temp controlled soldering iron sitting there all day and not to worry about your power source going flat.
I think, direct solder has some bennefits, like not losing a connector mid race (yes, as long as it is soldered correctly ), but then I do worry if you have a short, it is impossiblt to pull the connection apart. Whereas with connectors, if there is a problem, the cells are easily disconnected, but you do run a slightly higher risk of losing a connector mid race.
The fact the the JRXS means that you DO have to hard wire, or make a right dogs dinner of the wiring to run connectors is a genuine concern for a lot of racers, so it isn't something to be belitlled, remember, for this car to be a financial seuccess, it will eventual have to transcend all levels of racing. If the cell issue is real, then it might hit a problem with its mass market, the average joe racer at the club.
So, guys, take your girlies handbags back to their rightfull owners, and have constructive comments, I think we done the cell thing to death now don't you??
I am more interested in the way the anti-roll bar (sway bar) mounts personally.
DA_cookie_monst is offline   Reply With Quote
Old 10-15-2004, 05:05 PM   #882
burbs's Avatar
attached are links tobetter pics.. if u have not seen them
http://photos.hobbytalk.com/showphot...&cat=518&page=
http://photos.hobbytalk.com/showphot...cat=500&page=2
i dont understand hw u wont be able to use connectors.. just solder them to the battery bars.. itis the same as hard wiring a regular wire to it...
and connectors do have a greater difference in performance then most people think..... though it may not be able to be felt on the track, on the turbo it is a diference..... in order to feel something like that your car would have to be perfect.. same as higher voltage packs.. you wont feel it if the car doesnt let you..
Old 10-15-2004, 06:09 PM   #883
Default The car looks sweet and I think everyone should...
buy one. Is that better?
I was just asking a question EricF. I was not bad mouthing the car because it had two diffent colored belts. I just wanted to know the engineering reason. That's all. Does it really matter to you what I think of the new car? I feel special. I think there are many nice features on the car, but I just don't think it's for me.
Nightbreed is offline   Reply With Quote
Old 10-15-2004, 06:56 PM   #884
Send a message via AIM to dasupacat
Well I contacted my lhs and preordered mine.
As for wiring.....I normally use corally type connectors, so I might do the hardwire thing or just go with deans (no biggie). Got bout 2mo. to think about it.
Anybody hear what the internal ratio is going to be?
dasupacat is offline   Reply With Quote
Old 10-15-2004, 07:48 PM   #885
mashimaro's Avatar
that car looks sweet.. i want one!.. anyone got more pics from the show?
mashimaro is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
