Team Losi JRXS
#8777
Originally Posted by WD40
I posted this question a few pages back but I don't think I got a response. Why do people use AE hexes for the wheels on the front when running the Numan setup?
More steering.
#8778
Originally Posted by Tony Vega
Wow Matt what happened to Yokomo? Welcome to the team. Back from duty? Guess will see you in Stockton or Gilroy.
#8780
Originally Posted by bigdog xxx-s
If I shorten the rear of the car up, in other words don't shim the arm in the center shim it so it short in stead of long will that also give me more steering?
Gernerally a shorter wheelbase will react quicker and have the feeling of more steering but moving the rear arms forward will give the rear end more traction during acceleration and while coming off the corners. As a result it can cause an on-power push.
Moving the rear arms back will generally give you a smoother feeling car but from mid turn on out it can give you more on power steering.
#8782
yes-opposites
#8784
Originally Posted by Randy Caster
Congrats Matt, Im sure you'll be happy with the switch. You gonna run any off-road stuff?
#8785
R/C Tech Elite Member
Originally Posted by Matt Howard
I'll probably get something to run offroad with in the summer, not sure on a buggy, truck, or LST though. Maybe a xx4 if there's enough interest around here.
#8786
Originally Posted by tc3blue
Hey,
Just a quick question
are the front right and front left arms the same?
thanks
thanks
#8787
Originally Posted by Sokool
Actualy no.... If you look the front lower part of arm it has been routed out for clearance at full throw.
That is a great observation. I had forgotten that.
I believe that extra angle on the leading edge of the front arms is only there to create clearance with foam tire wheels; so, I freely interchange the front arms with the rubber tires I currently use (no clearance issue with rubber). For use with foams, I can just dremel away that small amount of material on a swapped arm to use it on the opposite side.
#8788
Originally Posted by JRX-S Bill
Sokool,
I got an itchy cut-off wheel! LOL
Brant
#8790
Originally Posted by lawtonlosi
There are medicine for that. btw I have not had time to send your box'o car. Been a busy week.
Brant
