Old 10-20-2005, 08:04 AM   #8431
Trader Rating: 24 (100%+)
Default jrxs
alright guys, now assembling my jrxs, questions about the pivot blocks.
i am using the paul c, stock setup and on it says; for front, to flip the front block and put .065spacer on it, the rear block have it flipped high for a .035anti dive.
the rear, do i run the pivot blocks, low or high?? doesnt say on setup sheet.
talking to a couple guys at local track i am getting mixed answers, with no clarification, either run low or high.
i am running foam carpet.
vic0280 is offline   Reply With Quote
Old 10-20-2005, 09:21 AM   #8432
weliin's Avatar
Originally Posted by JRX-S Bill
What class? Rubber or foam?
Sorry, foam. I live in the midwest..when you say carpet...it's 99% always foam, or was like that a year or so ago.
weliin is offline   Reply With Quote
Old 10-20-2005, 10:39 AM   #8433
geeunit1014's Avatar
it means the rear of the front are high, and the front of the front is low and has spacers under it, both of the rear are low (if this makes any sense)
hey it worked for me
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-20-2005, 01:35 PM   #8434
Default JRXS
MAKES PERFECT SENSE, THANKS.
Old 10-20-2005, 01:57 PM   #8435
Trader Rating: 14 (100%+)
hey vic, try kinwalds set up if that one doesn't work for you. I have it on my jrxs and it works pretty good.
With the pivot blocks, I found that running them all low works best for carpet.
Are you coming out to Larry's friday?
o.s. power is offline   Reply With Quote
Old 10-20-2005, 02:04 PM   #8436
actually i want to try paul c's setup for it first and then go from there. as for larry's, wont have the car built by then.
who is this?
Old 10-20-2005, 02:06 PM   #8437
Jammin'Trey's Avatar
Send a message via ICQ to Jammin'Trey
Originally Posted by T. Hodge
I have personally have not seen any tweaked cars out of the box. I can see this happening if you do not make sure the top plates are pushed down on the bulkheads correctly or the front plate being put on upside down.
Definatly, I think every one should just practice and stop moaning about the car...90% driver right???!!
Jammin'Trey is offline   Reply With Quote
Old 10-20-2005, 02:09 PM   #8438
EddieO's Avatar
R/C Tech Charter Subscriber
andrew gray gave me a pretty good tip on how to make sure the plates go on straight....
He said to installed them to the motor mounts FIRST....as they are keyed up top, then install as one whole unit.....the problem can arise from the fact that only one of those aluminum pieces is keyed to the chassis, the other is not....this way insures it will be perfectly straight when you tighten it down to the chassis...
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 10-20-2005, 02:30 PM   #8439
TheCoolCanFanMan's Avatar
Who's moaning just stating a fact. that's not to say after the car has been de-tweaked the car was bloody awsome
TCCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 10-20-2005, 02:35 PM   #8440
Later EddieO
Cheer's for that EddeiO, Iwill do that when I re-build her next week.
I have also been told that you can hold down the chassis on flat plate glass and get someone else to tighten the screws up on the top decks, but Ilke the idea of what you have mentioned EddieO
Cheers TCCFM
Old 10-20-2005, 07:44 PM   #8441
Smile
Later EddieO
hmmmmm thats somethin diffrent. ill keep it in mind next time i tear the car down(6 months )
ROB phillips if u get a chance u should come up to mimis. i will be there on saturday, hopefully i dont stay too good friends w/ the wall like i was on sunday , but i only broke an arm, only the second part to break
Mike Gee
Old 10-20-2005, 09:02 PM   #8442
Send a message via AIM to R/C Anonymous
i stated this "tweak" problem like 20 pages ago now it comes up again
R/C Anonymous is offline   Reply With Quote
Old 10-20-2005, 10:02 PM   #8443
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
I've had my car disassembled in every way possible, and the thing is super stiff when assembled, and is never out of tweak on the setup board..... not sure what to tell you guys having these tweak issues.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 10-21-2005, 05:55 AM   #8444
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Anybody have a good setup for carpet using 19t and cs27's?
Dasupacat1 is offline   Reply With Quote
Old 10-21-2005, 06:45 AM   #8445
Yeti35's Avatar
Try the Numan setup, that is what I used in LV at IIC. Only thing I did not use was the spool, just ran a diff up front. It will give you some place to start at least.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
