Old 10-13-2005, 07:42 PM   #8296
Mike Haynes's Avatar
Originally Posted by DirtyDog3375
Do you know the part number of theservo mounts??? Also, have you had any problems because you haven't used a servo saver???
Anyone???
ASC1779
http://www.horizonhobby.com/Search/D...&OverallCatID=
Nope, i have only broken 1 steering link so far, and thats with racing 2x a week since June.
Id use the airtronic plastic or ofna aluminum arm, they are much stronger then the stock link.
http://www.horizonhobby.com/Shop/ByC...rodID=OFN10731
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 10-13-2005, 08:25 PM   #8297
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to W.E.D.Jim
The problem with the servo clearance is when you try to run the fullsize saw blade spur with an almost equally humongous pinion. Go to a 118 and an equivelant pinion rather then the two larger, heavier, higher rotating mass gears......You'll also be moving the weight and rotating mass of the motor back a little which may help handling as well......., Jim
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 10-13-2005, 08:59 PM   #8298
Still Bill's Avatar
Originally Posted by vic0280
whos using the prs gear on the jrxs and what size are y'all using?
I bought one thinking it would be a good performance item; however, I found it was an all-show-and-no-go option. Slightly moves the spur gear outward which made it align poorly with my pinions. Had a heck of a time getting it on and off which was likely due to the anodizing inside the center hole. Just setting in my box these days. Looks good there!
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 10-13-2005, 09:27 PM   #8299
I am running on carpet with rubber tires and the "Newman" setup is what I am starting with. I see on his setup that he is using "2" .050" shims to add to the roll center in the front and he also is not using any kickup or anti-dive. so I assume that he is rasing both front and inner pivots .100" ? is this correct?
if that is the case then what are people using for shims the ones that came with the kit are .050" but only one set came with my kit so do I buy all the pivots to get more shims or is there other shims that are used?
things would be much better if I could get these guy's to run foam tires
Traceyf is offline   Reply With Quote
Old 10-13-2005, 09:37 PM   #8300
Still Bill's Avatar
Yes, the Numan setup uses two .050" shims under each of the four pivot block locations on the front end for a total of .100".
The kit comes with four each .050" and four each .035" shims. If you use one each under each location, you will be close enough at .085". Actually, I like .085" over .100" for most conditions.
Old 10-13-2005, 09:49 PM   #8301
JRX-S Bill; thanks I will try that. do you know if we can buy the shims without the pivots I can't see needing the pivots or is that something that I should carry as spares
-Tracey
Old 10-13-2005, 10:31 PM   #8302
Still Bill's Avatar
-Tracey
See my PM.
Old 10-13-2005, 10:45 PM   #8303
Rob Phillips's Avatar
-Tracey
You may want to pick up a set of extra pivot blocks, I broke one inner and one outer block so far. The outer was broken from a rear end collision. And the inner one, I brushed the wall on the straight and found a opening in the boards to snatch the rear arm off breaking the pivot block.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 10-13-2005, 10:51 PM   #8304
As Pooky said, EaMotorsports has the PRS gear adapter and PRS spur and pinion gears. The adapter I got didn't have any anodizing on it, so I didn't have any fitment issues. What ae servo mounts are you guys using, the ones fo the tc3? I use a Futaba 9550 servo and don't have any issues so far.
Old 10-14-2005, 05:01 AM   #8305
geeunit1014's Avatar
rob, if u go to mimi's on sat. could u tell me how pual c's setup works, if possible, i cant go have to work
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-14-2005, 06:29 AM   #8306
No problem. I was hoping to have another losi guy coming up with me, but he has to work.
Old 10-14-2005, 06:32 AM   #8307
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I'm interested in that to. I will be going to Mimi's to later in the year and since I don't carpet but once or twice a year a close setup would be helpful.
ST Racing Concepts (STRC)
Old 10-14-2005, 06:53 AM   #8308
T. Thomas's Avatar
Has the Losi JRX-S changed? I saw how the Losi crew was running the rear engine version at the nats. Is this a better set-up for the car?
T. Thomas is offline   Reply With Quote
Old 10-14-2005, 09:05 AM   #8309
rayhuang's Avatar
It is just a prototype. Wo knows if it will ever make production. Its based on the 4wd offroad cars layout-adapted to onroad.
Old 10-14-2005, 12:55 PM   #8310
i will be there on sun. (16)for the heck of it maybe race if anyone else shows up, and i will be there next sat.(22) if u come up again. also, if you could, post lap times for stock class, so i have something to shoot for next week
Mike Gee
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
