Old 10-13-2005, 03:26 PM   #8281
So if I'm starting with Paul L.'s setup for mod, and I change from 45 to say 35 wt oil in the back, the car should rotate better? Cuz I'm having problems with it not wanting to rotate when the traction comes up high.
Stealth_RT is offline   Reply With Quote
Old 10-13-2005, 03:46 PM   #8282
robk's Avatar
Trader Rating: 22 (100%+)
Yes that sort of change worked for me. Give it a try.
Old 10-13-2005, 03:47 PM   #8283
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to W.E.D.Jim
Stealth, that will help, you can also remove washers from the rear hub camber link end. Or raise the inside of the rear camber link. An easy change would also be ride height, or static camber, .5 higher in back, or .5 less negative camber then you usually run, etc.................Jim
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 10-13-2005, 04:33 PM   #8284
geeunit1014's Avatar
Originally Posted by vic0280
gunit,
appreciate the feedback, i bought a ton of spares and springs, etc.. i was talking about aftermarket or anything like that.
i dont think that anybody makes aftermarket parts except the pdub bumper and the spur gear adaptor, possibly colored screws, but nothin major.
run a 128, same as stock
whats the part# for the prs spur gear adaptor?
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-13-2005, 04:41 PM   #8285
rayhuang's Avatar
Hey robk, you had me at hello You had me at hello.
Old 10-13-2005, 04:42 PM   #8286
Trader Rating: 24 (100%+)
i will post tommorow, i am at work now.
vic0280 is offline   Reply With Quote
Old 10-13-2005, 04:44 PM   #8287
anybody know the part# for the prs spur gear adaptor???
Mike Gee
Old 10-13-2005, 05:16 PM   #8288
TheCoolCanFanMan's Avatar
Hi
Any come accross this one.
When mounting the KO 2143 servo and having a 128 spur and a 41 pinion I have noticed that the thread on the ball stud which is attached to the horn, is rubbing on the Brood C2 motor, looks like I will have to reduce the plastic mounting blocks to move the servo fowards to the front of the car, is this right
TTCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 10-13-2005, 05:17 PM   #8289
POOKYT's Avatar
go to www.teameamotorsports.com
Eric has them.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 10-13-2005, 05:21 PM   #8290
Mike Haynes's Avatar
Originally Posted by Trakside Trucke
Hi
TTCFM
If you use the AE metal ones it will give a little more room, and look alot nicer also.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 10-13-2005, 05:26 PM   #8291
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
I used ae servo mounts on my hitec servo to move it forward. I did that with a 41 tooth pinion and 128 spur.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 10-13-2005, 05:36 PM   #8292
cheers guys, just find it a bit frustrating when getting to the end of the build and having to brake her down again
and nathan i was right they just made it worse
TCCFM
Old 10-13-2005, 06:00 PM   #8293
rayhuang's Avatar
Hi
TTCFM
Go to a 126, 124 or even a 118 spur and this will solve the problems of clearance.
Old 10-13-2005, 06:03 PM   #8294
I have the AE mounts and an airtronics 758 servo, i can fit a 128 / 45 no problem, with 44 i can fit a servo saver, but i don't use one.
Old 10-13-2005, 07:02 PM   #8295
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Do you know the part number of theservo mounts??? Also, have you had any problems because you haven't used a servo saver???
Anyone???
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
