Old 10-10-2005, 10:48 AM   #8236
Default Belt and pulley questions
The JRXs is my first belt drive car and I have a few questions related to the belts.
First, the belt tension (both front and rear) does not seem constant. Instead, as the pulleys turn, the belts get tighter and a bit looser. Is this normal?
Second, related to the varying belt tension, I have found that nasty, sticky black dirt seems to accumulate in the spaces between the teeth on the belt pulleys. The more that builds up, the more the belt tension seems to vary. I have tried both digging this dirt out with a very small blade screw driver and spraying it out with Buggy Blast. Buggy Blast seemed to work best, but I'm afraid that using this spray will also dissolve the grease in the diff, so I am reluctant to use it. What is the best way to clean these pulleys?
Do the belts themselves need any cleaning or maintenance?
TIA,
Ira
iblumberg is offline   Reply With Quote
Old 10-10-2005, 05:12 PM   #8237
Rob Phillips's Avatar
I would just remove the belts and clean them with WD-40 and use motor spray and a toothbrush to get the pulleys clean. Thats how I clean my nitro, I don't have that problem with my JRXS though, only ran it indoors.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 10-10-2005, 05:26 PM   #8238
POOKYT's Avatar
TIA,
Ira
Yes the belts do "pull" tighter when you move the pulleys. This is normal. As for the dirt, I use an old tooth brush along with a 1 1/2 inch wide paint brush to dust off the car between rounds. The tooth brush works well for those pulleys and also other tight areas. If I can keep the dirt from building up in the teeth of the pulley then cleaning it isn't really an issue. I went to a race 2 years ago and Jimmy Babcock plus Travis Amezcua were there. They both had these regular looking paint brushes and were constantly dusting off their buggy's. If I had the choice of cleaning methods, I would choose to have some compressed air at the track. Saves all of the brush strokes!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 10-10-2005, 09:16 PM   #8239
Still Bill's Avatar
Originally Posted by Buck Nasty
This my be old hat but has anyone had issues with the front 4dg hub carriers? My left one seems to be 0dg.
Send it to Todd Hodge at Losi.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 10-10-2005, 09:21 PM   #8240
POOKYT's Avatar
I don't know if Hodgimoto still has a job with Losi! I heard he PIMPED Gil Jr. in the main at the Nats and knocked him off the track! LMAO
Sorry Todd--Had to rib you a little.
Brant
Old 10-10-2005, 09:26 PM   #8241
Still Bill's Avatar
Gil is too nice. Probably needed a janitor anyway...
Old 10-10-2005, 09:31 PM   #8242
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Yes He did send him flying....but what was even better was when Gil suckered young Weylin Rose into thinking he was going to pass him in the chicane and Weylin NAILED the wall....It was great!!
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-10-2005, 10:43 PM   #8243
POOKYT's Avatar
Originally Posted by EAMotorsports
Yes He did send him flying....but what was even better was when Gil suckered yound Weylin Rose into thinking he was going to pass him in the chicane and Weylin NAILED the wall....It was great!!
EA
LMAO!!!!!!
Brant
Old 10-11-2005, 12:16 AM   #8244
Buck Nasty's Avatar
Thanks Bill.
I'll send the e-mail asap!!!!!!
Still seems like more guy should be having this issue.
I can't be the lucky one(LOL).
I bet they had a run of 0 or 2dg left spindle carriers and stamped them 4dg?
Time will tell...........
I think, therefore I'm single. Buck Nasty
Buck Nasty is offline   Reply With Quote
Old 10-11-2005, 12:54 PM   #8245
Default O* Front Hub Carrier
I had similar problem and posted it probably over 100 pages ago. basically did same cure as you did.
J Tronzano is offline   Reply With Quote
Old 10-11-2005, 02:32 PM   #8246
TheCoolCanFanMan's Avatar
Hi Bill
Well, finished building me JRX-S, It went together real nice except for one of the locating pins in the front wishbone retainer, the head broke on me even though I tapped out every hole
Just a couple of Q's
1) what is the spare front wish bone retainer for?
2) The car came up aroung 80 grams light. not to sure where to place the weigts?
3) Any body know where I can get one of those C l-Can -Fan thing's
TCCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 10-11-2005, 03:29 PM   #8247
Buck Nasty's Avatar
I'm sure more people have the problem but have not noticed it. There cars arnt quite right and they can't figure it out. I would suggest everyone check there 4dg front spindle carriers to make sure they are the same regardless of what the stamp said..............................................
Old 10-11-2005, 03:48 PM   #8248
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by Trakside Trucke
Hi Bill
TCCFM
Answer to Q 1
you get a 0degree & 1 degree in the kit for the front toe-in angle for hinge pins
1degree(kit)more agreesive seering then the 0degree one
this is diffrent then toe-in on wheels malc
this is to do with hinge angles & wishbones
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 10-11-2005, 04:11 PM   #8249
Originally Posted by MR JOLLY
Answer to Q 1
Cheers Lolly
by the way any news on that atlas motor? could with with it at the weekend if you know what i mean
TCCFM
Old 10-11-2005, 08:47 PM   #8250
Still Bill's Avatar
Hi Bill
TCCFM
Malc,
Guess that you already saw the answer to Question 1...he, he...
Mine was about 80 grams light too. Maybe a bit less with your double fan unit. I have my weights low (probably looked at Matt Francis' car); but, Josh Numan had his up on the upper decks. Believe Josh still has 2 or 3 of our 25 cent coins (US quarters) epoxied in place to act as the weight. Our quarters should be a bit heavier than your 10 pence coins...Must be the Exchange Rate or something. Or would you like me to send some quarters?
How about an upper deck with the 30mm fan(s)?
Cheers!
Bill
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
