Old 10-09-2005, 06:47 PM   #8221
Fatboy Joe's Avatar
Originally Posted by POOKYT
Gareth--In the front two thick shims. On the rear 0 shims. If you need more steering and have tried shock angle adjusments and not gotten enough, then remove 1 thick shim and go to the thin one. If you still need more then run the one thick spacer. This is just my history on my car. I will try camber links and shock angles and small spring adjustments first and if I need more I then go to the roll center. Hope this helps Gareth.
Brant
Hi Brant,
I am a little bit confused about the front roll center shims. I'm running the Numan Setup now. The 2 shims in front now are .1" total, do you mean to say that if I make them .075", this will increase my steering overall or just the turn in? I am also looking for a little bit of more steering and corner speed, that's why I think the 6deg casters are the way to go. Thanks
Sonny
Fatboy Joe is offline   Reply With Quote
Old 10-09-2005, 07:02 PM   #8222
Mike Haynes's Avatar
6 caster is definetly worth a try, i will never go back. Feels a lot better i think.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 10-09-2005, 07:15 PM   #8223
POOKYT's Avatar
Originally Posted by Fatboy Joe
Hi Brant,
Sonny
Sup Joe!!! On my car about 2 weeks ago we ran a course with 2 180's and several rolling corners. I was trying to get into the corner harder and i did it by stiffining up the rear suspension. Then it was too hooked up off the corners. I then put in the 6 deg. carriers and it was great 1/3 into the corner untill the last 1/3 coming off. So, I softened back up the rear and took out one of the large front shims. I drove the car for half a battery at intermission and the car now had TOO much total steering. High speed and low speed and it was just a bit twitchy as well. I then went back and put in the thinner shim with the thick shim and all was well. After that race, on my way home, I was thinking that I wished I had had the time to leave the 1 thick shim in the front and try putting 1 thin shim in the rear( to tighten it up) and see how that would have affected the car. My biggest problem is we run in a parking lot and practice time is at a minimum. So far to me the car feels like if you are running the roll center at a given point ,then, you can from there fine tune its feel. If you make a change in roll center then you have like a whole new set of adjustments again. Hope this makes sense.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 10-09-2005, 07:16 PM   #8224
Still Bill's Avatar
Brant
Gareth,
My JRX-S kit came with 4 thick (.050") and 4 thin (.035") shims and I assume that yours did too. This is enough to raise the front end pivot blocks (4 locations) to .085" as opposed to .100". If you don't have additional .050" shims, you might want to try .085" until you get (or make) more shims.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 10-09-2005, 07:18 PM   #8225
POOKYT's Avatar
DITTO !!!!!
At least on asphalt any way. I have not had the JRXS on carpet yet.
Brant
Old 10-09-2005, 07:21 PM   #8226
Still Bill's Avatar
PookyT,
Nice post to Joe.
Sounds like you can notice more subtle suspension changes than I do. Should consider writing a book on JRX-S settings...No joke!
Maybe between stints of dremeling...Joke!
Old 10-09-2005, 08:09 PM   #8227
DITTO !!!!!
Brant
I get to run carpet all year , i did ashault a few times over the summer.
Old 10-09-2005, 08:22 PM   #8228
Fatboy Joe's Avatar
Thanks POOKYT, got it No wonder I had more steering with my previous setup (Hodge Asphalt) when I had the shims to just .085". Thanks for the tip
Old 10-09-2005, 08:30 PM   #8229
Still Bill's Avatar
PT is a mountain of information these days...
Old 10-09-2005, 09:47 PM   #8230
Thanks guys, youve been very helpful.
Gareth
Floss_LUC is offline   Reply With Quote
Old 10-09-2005, 10:36 PM   #8231
POOKYT's Avatar
If I don't hit the tread mill or get SOME exercise the mountain part is feeling familiar! LOL
Bill--the Dremel as of late is in its happy place and resting comfortably. I'm saving up my energy ( and cut-off wheels) untill I start making my own rear motor chassis! LOL
Brant
Old 10-10-2005, 01:17 AM   #8232
Buck Nasty's Avatar
This my be old hat but has anyone had issues with the front 4dg hub carriers? My left one seems to be 0dg.
I think, therefore I'm single. Buck Nasty
Buck Nasty is offline   Reply With Quote
Old 10-10-2005, 01:20 AM   #8233
POOKYT's Avatar
This is the first I have heard of any issues with the front carriers.
Brant
Old 10-10-2005, 01:31 AM   #8234
Buck Nasty's Avatar
Brant
I have not put it in the set-up station yet but you can see from the top looking down that the left camber link is more angled toward the front of the car. The right one is alot more laid back.
Old 10-10-2005, 03:59 AM   #8235
Buck Nasty's Avatar
All better. I took one off my XXX-SG+.
A little grinding and it fit like a charm.
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
