Team Losi JRXS
Old 10-07-2005, 02:35 PM
  #8176
Trader Rating: 24 (100%+)
Default jrxs
losi man, thanks for the setup sheet, but i cant get it to a size that is readable. how do i resize.
vic0280 is offline
Old 10-07-2005, 02:42 PM
  #8177
nevermind, i am retarded, just figured it out.,
vic0280 is offline
Old 10-07-2005, 02:43 PM
  #8178
LOSIMANJRXS's Avatar
Trader Rating: 28 (100%+)
when it comes up left click there should be a little symbol that comes up that enlarges it
LOSIMANJRXS is offline
  #8179
ok
Old 10-07-2005, 02:49 PM
  #8180
Rob Phillips's Avatar
It's legable to me, but standing on my head trying to read it sucks though
G-Unit, The setups in my Sig...
Rob Phillips is offline
Old 10-07-2005, 02:55 PM
  #8181
Trader Rating: 22 (100%+)
Originally Posted by WD40
Is Losi making these new brackets or is this a "home" adventure?
Flying solo on this one buddy... these are being made by a local CNC/Welding place that do lazer cutting. it is one of my resources from my real line of work. the original bracket was borrowed from a friend who attended the vegas race and gave me the inspiration to make these.
5thscaleracer is offline
Old 10-07-2005, 04:00 PM
  #8182
geeunit1014's Avatar
rob, have u driven this setup, is it a little lose or a little tight? also, whats the jaco equivalent of cyan/magentas, dont have parmas at my lhs
geeunit1014 is offline
Old 10-07-2005, 04:18 PM
  #8183
gee-dub's Avatar
anyone know if francis/easton running the rear-motor chassis at the nats? both have top 5 speed, whatever they are using is apparently working.
gee-dub is offline
Old 10-07-2005, 04:44 PM
  #8184
POOKYT's Avatar
I don't know about the chassis they are running yet but I did just look at the standings so far and the Man Gil Jr. busted out a 23 lapper!!!! Not bad for an " old timer" and part time racer! What ever chassis they are running its looking pretty good at the moment.
Brant
POOKYT is offline
Old 10-07-2005, 04:47 PM
  #8185
Juan Valdez's Avatar
In the Nats thread, there is a link to some pictures. If I remember correctly, there are pictures of the Losi team in the pits, and it looks like they are using the rear motored car. At least it looked like Hodge, Francis, and Junior are.
Juan Valdez is offline
Old 10-07-2005, 05:13 PM
  #8186
G - Unit
I think that the setup is fairly descent to start off with. I'm running 50 front spring and 20 rear spring with a .05 bar in the front and a .04 bar in the rear. I believe everything else is the same. Double pink is magenta, Double pink/orange is cyan. I have been tooling on the setup a little, but I can't imagine the car could get any better. I can't decide if I like it better with the sway bars or the stiffer springs. So far this is the best TC I have owned to date.
I forgot that Mimi's is in gathersburg, I new it sounded familar. I think a few of the guys from up there are coming down this weekend to run at DRCW. Debbies is a pretty sweet track, you'll have to try and make it down sometime. I'll be up at Mimi's next Sat. Hopefully, anyways
Old 10-07-2005, 05:45 PM
  #8187
UNSTABLE's Avatar
Originally Posted by huskerfreak
What do you mean by shorter bracket? center to center??
The hole spacing between the lower shock mount hole, and the hole to bolt the bracket to the arm. With a 0.25" centre to centre measurement and a 1/8" thick bracket you can fit a 26mm foam on and get full lock if required.
As RobK said, the new arms should address this and 28mm's should be no problem. But how long will we wait....
UNSTABLE is offline
Old 10-07-2005, 05:52 PM
  #8188
yull be there the 15th, huh ill be there as long as i can gewt out of work at my lhs (hobbytown in glen burnie ) thx 4 the setup sounds excellent. real name is mike gee, im 15, so dont look 4 an adult . do u know if it is pre-register, or show up n sign up?
Old 10-07-2005, 08:22 PM
  #8189
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i would bet it is the rear motored car....
Matt M. is offline
Old 10-08-2005, 06:24 AM
  #8190
Not sure if it's preregister or not. guess I should find out.
