Old 09-25-2005, 03:39 PM   #7906
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
If you can afford a new v7.1. Just get a Q2.
Dasupacat1 is offline   Reply With Quote
Old 09-25-2005, 04:55 PM   #7907
Send a message via AIM to GatesRacing Send a message via MSN to GatesRacing
any one know where i can find the josh newman setup for carpet
GatesRacing is offline   Reply With Quote
Old 09-25-2005, 05:20 PM   #7908
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
I ran a v7.1 in Memphis in mine and it worked just fine. Its a lil cramped and hangs off the edge a bit, but worked.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 09-25-2005, 06:16 PM   #7909
losi-xxxs's Avatar
Originally Posted by 2-Bad
Several months ago, Brain Kinwald added small brackets to all the bottom shock ballends. They raised and pushed the mounting point of the shock further out toward the wheel on the suspension arm. It makes the car more consistent. As the modification (known as "BK Brackets") has been so successful, Team Losi are planning on producing them moulded into the original arms.
Hope this explains it properly.....
Thanks 2-Bad that does explain it properly
losi-xxxs is offline   Reply With Quote
Old 09-25-2005, 06:17 PM   #7910
airbear87123's Avatar
POOKYT,
Well, you have convinced me to run the spool, but there is one more item of concern. We run foam tires at our track, and I'm running 26mm on all fours. Will I be able to run your brackets or not? Thanks.
airbear87123 is offline   Reply With Quote
Old 09-25-2005, 07:42 PM   #7911
POOKYT's Avatar
Originally Posted by airbear87123
POOKYT,
With 26mm you might be able to run the fronts. The rears will be no problem. I know 28 and 30 mm fronts are a No Go with the brackets. On the spool, I was not aware you are running foams so if you hate the spool just build the front diff with some of the old ( I mean old original JRX2) purple diff lube. I think the Trinity purple stuff is very close to the same. This diff lube is UBER thick and will be better than the stock stuff for the front diff. Don't give up on the spool if it feels weird at first. With a spool you drive that sucker into the corner hard and just let off enough for the car to set for the turn then pull the trigger to make it come off the corner like a bullet. Hope this helps. Good Luck.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 09-26-2005, 10:55 AM   #7912
TLRacing
Todd Hodge's Avatar
Brant
This weekend we learned that the new molded arms that have the bk brackets do allow you to use a 28mm tire on the front of the JRXS
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 09-26-2005, 10:58 AM   #7913
Rob Phillips's Avatar
manage to qualify third this weekend and I didn't do well in the main, because of a bad pinion choice. The car is dialed, can't wait to run it again.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 09-26-2005, 01:33 PM   #7914
forty6's Avatar
POOKYT,
Nice avatar airbear87123, I wonder where you got it? btw, that is Valentino Rossi when he was still running for Repsol Honda thus # 46.
Anyway, what happened to BK? Wasn't he suppose to go to the IIC?
forty6 is offline   Reply With Quote
Old 09-26-2005, 02:55 PM   #7915
Never mind I found it.
Old 09-26-2005, 03:34 PM   #7916
Dasupacat1's Avatar
Cool? Part #? When will they be out?
Old 09-26-2005, 03:55 PM   #7917
POOKYT,
Thanks for the advice. I will be sure to get those new molded arms as soon as they come out. I will be creating a spool some time soon and was wondering what you meant by how to drive the car through a corner. Since, your description matches how I drive normally. How are you supposed drive without a spool? Thanks again.
Old 09-26-2005, 03:56 PM   #7918
Forty6,
Wow, your avatar looks familiar. I guess were twins now.
Old 09-26-2005, 04:12 PM   #7919
forty6's Avatar
Forty6,
haha, because you got it from me. I photoshoped it. I have the wallpaper size original, let me know if you want a copy.
Old 09-26-2005, 04:27 PM   #7920
tim fry's Avatar
Hi guys
Do I really need the BK brackets to make the car work? It seems most people are using them does it make that much difference?
Tim
tim fry is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
