Old 09-19-2005, 03:54 PM   #7801
tim fry's Avatar
I need a very low grip setup for rubber tyres has anyone got one. On my others cars I generaly run 30wt oil all round with really soft springs no roll bars and lots of droop. Would you recommend I use similar as grip is practically non existent.
tim fry is offline   Reply With Quote
Old 09-19-2005, 03:54 PM   #7802
drew85's Avatar
Does anyone have a pic of brians car???
drew85 is offline   Reply With Quote
Old 09-19-2005, 04:34 PM   #7803
Juan Valdez's Avatar
Got a question for all the BK bracket users out there. I remember reading that you need to cut the shock end shorter, by I believe 1/8" (correct me if I'm wrong). But how far are you threading the shock ends onto the shafts? All the way? Thanks for the info!
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05 | Exotek F1R3
Juan Valdez is offline   Reply With Quote
Old 09-19-2005, 04:36 PM   #7804
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
I got a new in the box kit in a trade that I need to move. I really don't need two cars right now. Comes with a P-Dub bumper and PRS gear adaptor. $300 shipped.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 09-19-2005, 04:46 PM   #7805
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Use the Josh Numan setup (updated version) and if it's as slippery as the track I race on, you can also change the rear hubs to 1/2 degree instead of 0 degree and the rear camber location to the B position on the hub, along with the 4 chassis posts taken out.
Just run the Numan setup and make one of the above mentioned adjustments at a time to see how the car performs on the track.
Hope this helps.
Leonard.
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 09-19-2005, 06:04 PM   #7806
Correct, you need to cut off 1/8". As far as the shock length is concerned I have made mine 62 mm on all 4 shocks.
Old 09-19-2005, 07:13 PM   #7807
Fatboy Joe's Avatar
Hope this helps.
Leonard.
Hi Leonard,
Where did you find the J. Numan Setup Updated Version? Thanks
Sonny
Fatboy Joe is offline   Reply With Quote
Old 09-19-2005, 07:28 PM   #7808
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I dont think there is an updated version to that setup, still the best one for outdoors. It is made for use without the posts.
Old 09-19-2005, 07:49 PM   #7809
With regards to the "updated" Numan setup, I am referring to the slight changes from the original one that is on the Team Losi site:
rear shock fluid from 40wt to 30wt
frt toe from 1' toe out to 0' toe
frt camber from 2' to 1'
frt hexes from tc3 ae to standard jrxs hex
frt and rr droop now set as 10mm total (droop plus ride height)
These are the "updates" I am referring to. The other changes are my suggestions only. (as I race on a very low bite asphalt track-during the day and at night the traction comes up and becomes a medium-high bite track) Go figure???
The actual setup sheet from Josh N. can be found here.
Leonard.
Old 09-19-2005, 10:04 PM   #7810
Fatboy Joe's Avatar
Leonard.
Hi Leonard,
Thanks for the info I'm going to try the Numan Setup this Saturday. Im am currently running the T.Hodge setup now.
Old 09-19-2005, 10:33 PM   #7811
Tim Johnson's Avatar
Newmans setup seam to run very well......Watch him whip up on some ASC boys..................his car is on rails!! HAVE A GOOD WEEK ALL THAT ARE GOING TO VEGAS!!!
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 09-19-2005, 10:37 PM   #7812
Fatboy Joe's Avatar
Gearhead3:Hi, how does the numan setup compare to Todge's? Have you tried both? What do you think? Thanks
Old 09-19-2005, 11:09 PM   #7813
More steering on the Numan setup. Very dialled!!!
Old 09-20-2005, 12:56 AM   #7814
Fatboy Joe's Avatar
Cool! Thanks, that's what I need for my setup. Im kinda getting used to the current setup and I tend to over drive it some how when I need to pick up the pace, most especially when I'm trying to make up for lost time due to errors.
Old 09-20-2005, 01:56 AM   #7815
2-Bad's Avatar
Trader Rating: 24 (100%+)
If you use the "B" position on the rear hubs, you'll need the plastic rod ends from the sway-bar to maintian clearance from the wheel rim.
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
