Team Losi JRXS
Old 09-18-2005, 01:34 PM
  #7786
Tim Johnson's Avatar
try cutting up an old shock tower. That seams to work well....LOL
Tim Johnson is offline
Old 09-18-2005, 01:38 PM
  #7787
Originally Posted by T. Hodge
What are your feelings on the way we made the TC springs? Usually we would powder coat the springs however with the inconsistencies of powder coating we did something different this. I am curious to hear your thoughts on this.
Leave the springs just how they are....The Tags are great Who wants to pay extra from some color......LOL
Old 09-18-2005, 01:39 PM
  #7788
does Losi have a spring kit for the JRXSSFEDVSRGVDF ?
R/C Anonymous is offline
Old 09-18-2005, 03:52 PM
  #7789
rinkrat99's Avatar
Hi all
I have a concern that my rear droop screws do not touch the chassis and therefore are useless. The car is setup for carpet with 56.5mm tires, ride height 5mm and the shock tower is in position 2 with the arm position Outside.
With this setup, I get maybe 1.5mm droop if lucky but nothing more cause the shocks are fully extended. I treid moving to position 1 and still the same. How can i get more rear droop if needed?
rinkrat99 is offline
Old 09-18-2005, 04:00 PM
  #7790
HMMMMM...................
Old 09-18-2005, 04:01 PM
  #7791
lazyboy's Avatar
Originally Posted by rinkrat99
Hi all
using the shock ends(the eyelets)
lazyboy is offline
Old 09-18-2005, 05:08 PM
  #7792
Unscrew the shock ends about 2 turns. That makes the shocks longer and gives you more down travel.
Stealth_RT is offline
Old 09-18-2005, 05:51 PM
  #7793
Rob Phillips's Avatar
Hi all
Measure the lenth of your shocks and see what you come up with. Should be around 62mm. I'm assuming the position of your tower is in the lowest setting, if not put it there and that should take of the problem. I run tires down to about 52mm, yeah that's right, all the way down to the rim, and I still get about 2.5mm of droop.
Rob Phillips is offline
Old 09-18-2005, 06:01 PM
  #7794
Has anyone experimented with different size spurs? I run a 128 now and was wanting a little input on how the other spurs were performing. I know most Fk05 guys have found the 116 to be the best spur to run.
Old 09-18-2005, 08:39 PM
  #7795
itsjusme's Avatar
Hi all
Try running your ride height at 4mm for foam tires. That will give you the extra droop if you need it. Most racers run at 4mm of ride height to 4.5 with foam tires.
Also check on how you built the shocks, per the instructions. You do not want to screw the shock ends all the way in.
I am running tires at 55mm and still can get at least 5mm of droop if I want too.
itsjusme is offline
Old 09-18-2005, 10:12 PM
  #7796
rinkrat99's Avatar
Hi all
I reset the shock eyelet to give me a total length of 64mm. I can now get up to 4mm droop. I am going to run with a 1mm droop front and 1.5mm rear per the Carpet setup. I just wanted to make sure I had some room for adjustment.
Old 09-19-2005, 02:19 AM
  #7797
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by POOKYT
Must have been the brackets! LMAO
Brant
Yes of course it was the brackets... oh "Dremel Master"
2-Bad is offline
Old 09-19-2005, 06:46 AM
  #7798
tex1's Avatar
Talking Todd
I love the springs the way they are. The consistancy is top notch.
If you guys have a problem with your labels. Scotch tape one to your shock tower instead of your shock. It works great and you only use one per install.
Thanks,
TEX
tex1 is offline
Old 09-19-2005, 08:06 AM
  #7799
rinkrat99's Avatar
Default Team Trinity Pitbox files
Hi all
Does anyone have a copy of the old Trinity pitbox tool referencing the Foam tires? It has been lost since they changed the look of the website
Old 09-19-2005, 02:57 PM
  #7800
UNSTABLE's Avatar
Hi all
He he, bit late with this one.
I found that if you run a high roll centre, esp. at the front, you have to remove some material from the a-arm on the inside or the c-hub will hit the arm and you can't get enough ride height, let alone droop if you run real small foams (55-56mm). May be irrelevant here but might help someone
UNSTABLE is offline
