Old 09-10-2005, 10:33 AM   #7681
TLRacing
Todd Hodge's Avatar
Originally Posted by GatesRacing
New to rc cars my first car I bought a jrxs. So here is my ? I bought a lrp 7.1 speed control and its a little big to fit on the side where I see many mounted. Do you think it would be a problem with over heating if I mount it on the crossmember above the batteries. I already looked and made sure the wires wouldnt get in the way of the belts or gear. The only thing Iam worried about is a issue with over heating my esc. Any help would be great.
That will only raise your center of graivty. I think you would be fine mounting it on the side of the chassis as per other JRXS owners. Even if it does hang over atleast your car will be balanced right to left.
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 09-10-2005, 10:46 AM   #7682
Send a message via AIM to GatesRacing Send a message via MSN to GatesRacing
Thanks I never thought about that. I was just worried about it getting hit and getting cracked.
GatesRacing is offline   Reply With Quote
Old 09-10-2005, 11:38 AM   #7683
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Hey Todge
When wil the alum. pivot blocks be out? 2deg. rear hubs?
I'm running carpet this winter and my track is doing both foams and spec rubber during the same week. I plan on doing both. Any tips on how much I should change between setups. Right now the car is setup for foams to run in stock. How much should i change when putting on rubbers?
Thanx
Dasupacat1 is offline   Reply With Quote
Old 09-10-2005, 08:02 PM   #7684
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to W.E.D.Jim
Gates, Todd is right(as you might expect), a little overhang will be fine, the speedo will be safe since it is tucked in between the tires and the center of gravity is more important for handling.....If you have to raise anything, the receiver is the lightest component, but it all should fit.....Jim
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 09-10-2005, 11:23 PM   #7685
WD40's Avatar
I would start off with a 30 if your track doesn't have a very long staright-a-way. I run a 29-120 set-up on my car. I have the spur gear adaptor and it is sweeeeeettttttt! I run a binary also, and thats what it seems to like.
What does the spur gear adaptor do? Also there is a problem with my spur gear sort of. It wobbles side to side b/c it is not true. Does the spur gear adaptor help that?
WD40 is offline   Reply With Quote
Old 09-10-2005, 11:32 PM   #7686
POOKYT's Avatar
The PRS spur adapter allows you to run standard type spur gears. It also allows you to use many different sizes or even change to 48 pitch if you want. If your spur is a little wobbley then it should still be fine. If its very wobbley or warpped then replace it. Hope this helps.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 09-11-2005, 02:42 AM   #7687
2-Bad's Avatar
Trader Rating: 24 (100%+)
The standard 64p, 128 tooth spur that comes with the car is very, very good. If you don't wish to run 64p, then the spur adapter is your solution.
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 09-11-2005, 01:12 PM   #7688
kylehirano's Avatar
Trader Rating: 14 (100%+)
Hello, does anybody know where I might be able to buy BK bones for the JRXS, or just aftermarket and spare parts for the car. Please help me.
Kyle
kylehirano is offline   Reply With Quote
Old 09-11-2005, 05:57 PM   #7689
TLRacing
Todd Hodge's Avatar
Kyle
Team Losi sells the bearings that are put on the cvd and lcd's. The part number is LOSA6932. The bearings are easily pressed on the CVD's with a small vice. The lcd's need the pin ground down a bit so the bearing fits. I use a round stone wheel to take the diameter down and then press the bearing on.
Todd Hodge
Old 09-11-2005, 06:02 PM   #7690
TLRacing
Todd Hodge's Avatar
Originally Posted by Dasupacat1
Hey Todge
Thanx
We are working on finishing the aluminum blocks. They should be out in 3-4weeks by the time they are packaged and into Horizon's inventory. The hubs...I am not sure. I will check.
As for a setup change, you are looking at quite a bit. With rubber tires, I used the BK Mounts where on foam tires I use stanard arm/shock position. There is a lot to change. You really need to commit to one class or get an additional car for the rubber spec class.
Todd Hodge
Old 09-11-2005, 06:03 PM   #7691
POOKYT's Avatar
Kyle
The only 3 aftermaket items that I know of or recomend are the P-Dub bumper, the PRS spur gear adapter( stock spur gear is fine but if you want different spurs then you may want this), and the BK shock brackets. Other than these items the kit has everything you need. For replacement parts try KT Hobbies or Horizon Hobby. Hope this helps.
Brant
Old 09-11-2005, 06:21 PM   #7692
TLRacing
Todd Hodge's Avatar
Default Diff Assembly Tip-LOSA3018 Thrust Assembly
Using the LOSA3018 Thrust Assembly-His a key note on building your diffs on your JRXS. On the thrust assembly you will want to measure the outer diameter of the thrust assembly. You will notice that one of the thrust washers is larger in diameter. You will want to place this washer onto the diff screw first. Then put the caged ball assembly on the diff screw then slightly more lube around the caged bearing. Apply the next thrust washer (smaller diameter) next. Now you will want to use your 5 concaved washers in the opposite direction on the diff screw. You will want them in this orientation
instead of
Assemble the diff accordingly and you will notice a smoother diff.
Todd Hodge
Old 09-11-2005, 06:58 PM   #7693
Fatboy Joe's Avatar
Originally Posted by DirtyDog3375
Hi Fatboy Joe,
Just wondering if you could put up some pics of how this is done? As I too am sick of having to take the motor out to use the MM motor cooler.
Thanks,
Leonard.
Hi Leonard,
Here are the pics, you will need patience in doing this. It will be worth it
Fatboy Joe is offline   Reply With Quote
Old 09-11-2005, 08:17 PM   #7694
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Originally Posted by Fatboy Joe
Hi Leonard,
Thanks for the photos Fatboy Joe. Much appreciated.
Leonard.
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 09-11-2005, 08:23 PM   #7695
Still Bill's Avatar
Is that identical to the Much More cooler?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
