Old 09-07-2005, 08:17 PM   #7651
TLRacing
Todd Hodge's Avatar
Originally Posted by Bob Barry
Todd that is an awesome quote. I knew Senna was a great driver but that just shows how you have to think in order to succeed.
I got that quote from Greg Hodapp's website. Click on Senna and watch the video....it is awesome....absolutely awesome!!
www.radiocontrolcarracing.com
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 09-07-2005, 08:18 PM   #7652
TLRacing
Todd Hodge's Avatar
Originally Posted by rinkrat99
Hi Todd and Bill
I looked up the p/n for the Losi rear 2 degree hubs and found this A9854. Are you saying these will no longer be made?
We have not made them yet.
Todd Hodge
Old 09-07-2005, 08:55 PM   #7653
A first on a JRXS? Made a, well not really a tensioner, more a 'lift limiter'. Keeps the rear belt from skipping on the drive pulley, while allowing me to run the belt really loose. Haven't tried it on the track yet. We'll see how it holds up this Sunday.
Stealth_RT is offline   Reply With Quote
Old 09-07-2005, 10:13 PM   #7654
Rob Phillips's Avatar
Ray,
Thanks for the hooking me up with the Paul Ciccarello's setup. It's dialed. I pretty much ran the setup the same as yours. Thanks again.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 09-07-2005, 10:19 PM   #7655
I'll repost the setup. Paul Ciccarello's setup
I must say, if your looking for a good starting carpet setup, try this one. One thing I will add, if the rear end is a lttle loose, try running a thinner sway bar.
Old 09-08-2005, 06:38 AM   #7656
2-Bad's Avatar
Trader Rating: 24 (100%+)
Todd,
Any chance that the new chassis design will allow more access to the motor?
1/ Installing the Muchmore motor cooler without removing the motor from the car?
2/ Installing cooling fans on the motor?
Thanks,
Peter
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 09-08-2005, 06:42 AM   #7657
rayhuang's Avatar
Originally Posted by Rob Phillips
Ray,
NO problem. I am glad I could help. 20lb spring into 2nd hole is a bit tamer than 25#lb spring laid into third hole as well.
Old 09-08-2005, 03:43 PM   #7658
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Hi All
I tried running Paul Lemieux's carpet setup and had trouble getting the front shocks from touching the outdrives. He was using the #1 on the front shock mount and I tried a thocker spacer on the shock mount with no luck.
Whats the secret of using position #1?
rinkrat99 is offline   Reply With Quote
Old 09-08-2005, 03:47 PM   #7659
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Rinkrat....you need to space out the top and the bottom. I think the top is spaced out .090 and the bottom is spaced out .060 to clear the outdrive.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 09-08-2005, 03:56 PM   #7660
TheCoolCanFanMan's Avatar
Originally Posted by 2-Bad
Todd,
Thanks,
Peter
Hey 2-bad
Why dont you take a look at the cool-can-fan website with regards to your plight with the fan situation. We have Integrated JRX-S CCF Top Deck so there is no need to worry about the fan senario, great prices for you guys in the US.
www.coolcanfan.com
Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 09-08-2005, 06:02 PM   #7661
Trader Rating: 76 (100%+)
Hey guys, I ran the Lemeux set-up for asphalt, and the car pushed really bad. Is there anything I could have overlooked when I changed the set-up?
MUDVAYNE is offline   Reply With Quote
Old 09-08-2005, 06:28 PM   #7662
alb
Trader Rating: 19 (100%+)
So, I got a pile of 3700's today. I have one question, How much widdling did everyone else have to do to the plastic tray? Can't find the alu one ANYWHERE!
alb is offline   Reply With Quote
Old 09-08-2005, 06:32 PM   #7663
Fatboy Joe's Avatar
Todd,
Thanks,
Peter
Peter: You can actually still use the MM Motor Cooler with a little modification. you need to cut a portion of the clips so the motor (while installed in the chassis) will just rest on it. You also need to install 4 "pegs" on the fan to give it some space to clear the table and give it some air gap.
Here's what I did with my motor cooling fans, I bought a couple of Much More Cooling Fans and some .030 Lexan from Parma, some nice FRP plate (for spacers) but if you have a bigger budget and want a neater looking setup, you can always get the cooling fans with CF topdeck from www.coolcanfan.com
Fatboy Joe is offline   Reply With Quote
Old 09-08-2005, 06:47 PM   #7664
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Hi Fatboy Joe,
Just wondering if you could put up some pics of how this is done? As I too am sick of having to take the motor out to use the MM motor cooler.
Thanks,
Leonard.
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 09-08-2005, 08:55 PM   #7665
rayhuang's Avatar
Hack it to nothing to make the GP3700's fit. Its what i did to mine and it works fine with 3800, 3600, 3300. So I am sure 3700 will be just fine. I have an unmolested tray for 3300 and 3600's but I never use it. Just my dremeled one!!
NO WORRIES Mate.
Ray
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
