Old 08-21-2005, 11:10 PM   #7396
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by bigdog
JRX-SBILL- Did you say Aaron Young????
Yeah...Aaron has all of James' stuff.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 08-21-2005, 11:28 PM   #7397
Still Bill's Avatar
Yep. He didn't have all the parts to put together his Corally; so, the JRX-S had to do for last night.
Aaron has already sold both JRX-S's that came from James...One to me.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-21-2005, 11:32 PM   #7398
Still Bill's Avatar
Originally Posted by miniracer
can you post this double one-way setup?
It appeared to be the standard JRX-S kit setup with middle and front one-ways. Aaron can drive anything fast...And certainly did.
Old 08-22-2005, 05:56 AM   #7399
Hi guys,
I was looking at Steve Weiss' asphalt setup and regarding droop he says 10mm. front (9mm. rear) above ride height.
Assuming ride height 5mm. as per his recommendations, this means the front wheels must lift when the car' s bottom is 10+5=15mm from the ground?
Also Bump steer: he put 5x.030" washers each spindle. I think this will give a lot of toe out when front suspension is compressed, is there any particular reason for this?
Thank you for helping,
Eddi.
EddiRossi is offline   Reply With Quote
Old 08-22-2005, 09:07 AM   #7400
The Evicerator
Hey Eddi,
Actually, when I wrote that down I guess I did not see how confusing it could be.
If you lift the car up the chassis should be 10 mm offthe ground when the tire comes off the surface
As far as the bumpsteer goes... it just changes some of the steering characteristics of the car... I recommend playing with different amounts of bump steer to see what you like...but I have been running anywhere between 2 and 5 of those washers lately.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 08-22-2005, 10:54 AM   #7401
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Default JrXs Spring rate chart
Does anyone have a sprigrate chart with p/n's for the complete selection of springs?
rinkrat99 is offline   Reply With Quote
Old 08-22-2005, 11:11 AM   #7402
WD40's Avatar
Default BK Brackets
I was wanting to try out the Numan setup and was wondering if anyone could post a picture for the BK brackets and how they are mounted on the car. I want to build some very soon. Thanks to all the people that help out on this forum....its great!!!
WD40 is offline   Reply With Quote
Old 08-22-2005, 11:32 AM   #7403
JRXS_chris's Avatar
Bad pics but here you go:
http://photobucket.com/albums/a141/TeamBomb/
JRXS_chris is offline   Reply With Quote
Old 08-22-2005, 11:58 AM   #7404
Rob Phillips's Avatar
JRXS.net has some sime I believe. I'll see if I can find them again.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 08-22-2005, 12:02 PM   #7405
Thank you Steve!
It' s nice to get the answer directly from you, the author of the setup.
We only have to be happy for your help in dialing the Losi cars and if something is not that clear for us, ok we ask, that' s all!
Since when copying someone' s setup it must be done 100%, I have still a couple of questions:
- front camber link in between #1 and #2: you had to make a sort of new hole in stock shock tower?
- TC3 rear hub carriers: do they provide a specific camber link position not possible with Losi stock part?
Thank you again,
Eddi.
Old 08-22-2005, 12:14 PM   #7406
The Evicerator
Eddi,
Yes, I drilled a new hole in the front shock tower directly in between the middle and bottom hole.
And I used the inside position on the tc3 camberlink which is not available on the losi link
Steve Weiss
Old 08-22-2005, 12:55 PM   #7407
Thanks Steve,
I am working now on my JRXS to make all the modifications, I can' t wait for testing on the track!
Old 08-22-2005, 03:04 PM   #7408
Trader Rating: 76 (100%+)
Hey guys, I've been running my JRXS for a couple of months now with foam tires on a medium bite asphalt indoor track. I've been wanting to switch to rubber tires, and I was wondering if anyone has some suggestions on a set-up to start with. Any help would be appreciated, and if you like, you could e-mail some set-up sheets here [email protected] . Thanks.
MUDVAYNE is offline   Reply With Quote
Old 08-22-2005, 03:38 PM   #7409
Jammin'Trey's Avatar
Send a message via ICQ to Jammin'Trey
MUDVAYNE are you at any cooralation with the band?
Jammin'Trey is offline   Reply With Quote
Old 08-22-2005, 06:09 PM   #7410
Are you guys runnign the BK mount with foams? It rubbs the front wheels a bit at full lock with TRC 28mm.
Does anyone have Craig Xaviers regional setup from Mimi's? I heard he was dialed that day.
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
