Old 08-20-2005, 12:44 AM   #7366
Still Bill's Avatar
Today I did some testing on carpet using Takeoff 27/22 (f/r) rubber tires at Gilroy.
Easiest to drive was Todd Hodge's Stockton carpet setup...However, my car was lacking the front spool in its setup.
My other JRX-S had the Josh Numan Reedy asphalt setup on it and turned the fastest times.
Has anyone else tried driving their JRX-S on carpet with rubber tires and the BK shock brackets? What did you think?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-20-2005, 05:19 AM   #7367
TCR
bill you should be able to read that set, I havent seen a computer it looked bad on, it's huge, maybe try printing it out
TCR is offline   Reply With Quote
Old 08-20-2005, 06:10 AM   #7368
JRXS_chris's Avatar
Yup, I had my car setup for an outdoor race last weekend, but it rained so I had to race indoors. The car was setup using Josh Numan's asphalt setup and I couldn't be bothered to change it!
The only things I have changed from that setup is to put the diff back in (42 pulley). The car is dialled on CS22s (GLs) using Jack the Gripper additive.
JRXS_chris is offline   Reply With Quote
Old 08-20-2005, 06:15 AM   #7369
Yeti35's Avatar
So you two are saying the Numan setup will work on carpet with rubber? That is comforting to know since I had no idea where to even start with a setup in LV. I just put the setup on my car and will try it out today for the first time on asphalt. If it works well on carpet to then I am set for LV then till someone down there comes up with something better.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-20-2005, 06:17 AM   #7370
JRXS_chris's Avatar
Take the spool out though as it will not give you enough turn in. Turn out is incredible with a spool though. Diff is better all round.
Tell us how you get on!
Old 08-20-2005, 09:25 AM   #7371
Still Bill's Avatar
Chris,
Spool with the overdrive pulley (41T) has plenty of turn in. Car rockets out of corners with the spool too.
In my mind, an issue remains that there may be too much grip with Josh's asphalt setup when the traction comes up at a major event like the Las Vegas race.
The really good news is that we should be getting some great rubber and foam carpet setups for our JRX-S's after the Las Vegas race.
Need some Team Losi input...Ohhhhhhhhh, Todd?!?
Old 08-20-2005, 09:58 AM   #7372
racer-oZ's Avatar
R/C Tech Charter Subscriber
Well it started out as a tough night for my first race with the JRXS, but it smoothed out. I had some severe glitching problems at first and had to re-route some wiring and triple the servo tape underneath my receiver and it went away. Anyone else have that problem? Once I got the glitch solved the car rand very well, incredibly stable during cornering.
PookyT, I think I had your brackets on correct, but they rubbed a little on the front rims. There are two sets of brackets, and the meatier ones (more material) go on the front correct?
Thanks!
racer-oZ is offline   Reply With Quote
Old 08-20-2005, 10:14 AM   #7373
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Thanks!
Yea, you got them on correct
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 08-20-2005, 10:19 AM   #7374
Still Bill's Avatar
Racer,
Did you use cap head type screws to affix the bottom of the front shocks to the PT bracket? That is the only conflict I had between the wheels and the new shock positions.
Old 08-20-2005, 01:38 PM   #7375
As far as carpet set ups go, I built a new car for the Las Vegas race and consulted Todd before I started about the set-up. His advise was to build it with the Newman set-up to start with and adjust from there.
Todd is in Canada this weekend so that may be the reason he is not able to give an answer at this time.
I have been using button head screws when running the BK brackets so they clear the wheel.
-TLR-Spektrum-Horizon Hobby-AKA-Orion
Scott Welte is offline   Reply With Quote
Old 08-20-2005, 02:24 PM   #7376
Still Bill's Avatar
Thanks for that info Scott.
Old 08-20-2005, 02:29 PM   #7377
racer-oZ's Avatar
bill, yep i did use button head screws... the metal was rubbing on the rim during suspension compression... i am going to dremel off some material to make them clear the wheel. You know how it goes when you put a brand new car on the track... gotta get used to how things go together.
racer-oZ
Old 08-20-2005, 02:58 PM   #7378
No problem Bill. So are you getting your car dailed for Vegas? Must be nice to have a Carpet track close by . I was hoping to make it to Gilroy prior to Vegas to practice for a couple days, but i don't know if my schedule will permit. Plus with the price of gas, damn it .
Old 08-20-2005, 05:49 PM   #7379
racer-oZ's Avatar
what aftermarket wheel hex adapters fit the jrxs... i heard the dynamite ones i used to run on the xxx-s don't fit.
Old 08-20-2005, 08:32 PM   #7380
Yeti35's Avatar
I ran the Numan setup today for the first time on asphalt and I think it is DIALED!! Only issues I had was the front wheels rubbing the screw for the BK bracket but I will make some adjustments for that. Yes I was running button head screws as well. It ran great in my qualifiers but I probably should have went to a hotter tire for the main. It was a little loose, but still managable. If this setup works on carpet I will be happy!! I will just need to make another set of brackets for my other JRXS for LV and replace the abused bottom chassis on my current car.
JRXS Bill, you are gonna be in LV, right? Would be cool to meet you in person. If you catch a glimpse of my cars it will have my screename on the side of them, minus the 35!!
22 3.0SR
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
