Old 08-12-2005, 04:55 AM   #7276
Doug D's Avatar
Trader Rating: 54 (100%+)
Originally Posted by Randy Caster
Just look up 3/32 x 3/16 on ebay and you can get em for a buck a piece.
Ahhhhh yes the money I could have saved
Doug D is offline   Reply With Quote
Old 08-12-2005, 07:16 AM   #7277
Does anyone have a photo of what bearing drives look like when installed on the LCD's ? . I couldnt find this info in the manual.
Cheers,
Rob
mass is offline   Reply With Quote
Old 08-12-2005, 07:21 AM   #7278
2-Bad's Avatar
Trader Rating: 24 (100%+)
Cheers,
Rob
Don't have a pic, but the miniature bearings fit over the pins of the dogbones. Then you fit them into the outdrive but using the large slots in the outdrive.
Regards,
Peter
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 08-12-2005, 07:32 AM   #7279
Drew_Cat's Avatar
E-Bay link 3/32 x 3/16 x 3/32" Metal Shielded Bearing
Items for sale:
TURBO GFX>>>> http://www.rctech.net/forum/showthread.php?p=4329165#post4329165
Tekin Battery Nurse >>>> http://www.rctech.net/forum/showthread.php?p=4329173#post4329173
Thanks for looking
Drew_Cat is offline   Reply With Quote
Old 08-12-2005, 07:52 AM   #7280
LOSIMANJRXS's Avatar
Trader Rating: 28 (100%+)
Here is a couple of pic. of the bearings on the outdrive pins. Hope it helps they are pretty hard to get on so be patient.
Fastlane Raceway
Hobbytown KCMO
LOSIMANJRXS is offline   Reply With Quote
Old 08-12-2005, 09:18 AM   #7281
rayhuang's Avatar
Originally Posted by Jammin'Trey
I am runnin' the center spool and f/r diffs...
I rebuilt my lcds and that didn't help much, but a little. What are bearing drives and where can i get them?
todd hodge told me those would help??
One thing I found-were the screws in my pulley were slowly working loose and that caused a clicking sound as well. Its the tiny screws on the layshaft pulley.
Old 08-12-2005, 10:13 AM   #7282
Thanks LOSIMANJRXS & Peter, That helped heaps. Now i just gotta find em locally
Rob
Old 08-12-2005, 10:56 AM   #7283
Precision Racing Systems 64 Pitch - JRX-S Spur Gear Assembly
http://www.precisionracingsystems.com/products/17
These look great, Would they be able to be used with the one way as well as the spool?
Cheers,
Rob
Old 08-12-2005, 11:02 AM   #7284
Tim Johnson's Avatar
Cheers,
Rob
Don't forget about the Good old JRXS Resource
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 08-12-2005, 11:04 AM   #7285
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Mass....The gear adapter works the same way as a stock spur gear. With the stock spur gear you can use it with a 1-way or spool pulley so the adapter is the same way it will work with both as well.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 08-12-2005, 11:23 AM   #7286
Thanks Kevin, I think I'll be ordering some then. Great picture Gearhead3 Thanks
Rob
Old 08-12-2005, 12:56 PM   #7287
gatrbite's Avatar
Send a message via AIM to gatrbite
www.kthobbies.com has the alum. battery trays in stock. Just got mine yesterday.
Jeff
Jeff Mohn
Studio 14 Photography www.studio14photos.com
Bumps and Jumps RC www.bumpsandjumpsrc.com
gatrbite is offline   Reply With Quote
Old 08-12-2005, 03:45 PM   #7288
Default servo problem
Hello
I have try use a futaba 9450 on my JRSX but don't fit better, have more interference whit sterring link.....
What servo mount without problem ?
dragonal is offline   Reply With Quote
Old 08-12-2005, 04:41 PM   #7289
2-Bad's Avatar
Originally Posted by dragonal
Hello
Airtronics I believe fit well. My Hitec sat on the servo posts too far towards the back of the car. Had to dremel (1mm) some of the post away to get better clearance for pinion/spur selections.
Are we allowed to use the word "file", or must we only use "dremel" on this thread )
Old 08-12-2005, 04:58 PM   #7290
Rockheadsguy's Avatar
Send a message via AIM to Rockheadsguy
As far as servos go, did I read here a while back that people had problems with the #23 servo horn? I just switched to a JR servo and the splines don't seem to fit well... I think it moved during my first run with it...
Rockheadsguy is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
