Old 08-05-2005, 11:21 AM   #7156
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
For spool you guys use the 41t pulley right ?
Roberto Falcon is offline   Reply With Quote
Old 08-05-2005, 11:28 AM   #7157
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I think most everyone does, we even use it with the 1 way out here..
Old 08-05-2005, 11:28 AM   #7158
2-Bad's Avatar
Trader Rating: 24 (100%+)
yepp, the one with the black mark (pen marker) on the side of it......
2-Bad is offline   Reply With Quote
Old 08-05-2005, 11:29 AM   #7159
2-Bad's Avatar
bugger... beaten by Randy again......
Old 08-05-2005, 12:18 PM   #7160
Hey Randy do I only JB weld the diff rings to the pulley right ?
Old 08-05-2005, 12:51 PM   #7161
I actually notched the rings first, put balls in the pulley, and then used the JB weld to hold it all together. I think Josh just put the JB weld on the rings to secure them to the pulley, his thrust is also covered in JB as well.
Old 08-05-2005, 12:53 PM   #7162
Put balls in the pull? I did it the other way then I just JB weld the rings to the pully. Would that cause any problems ?
Old 08-05-2005, 01:20 PM   #7163
It seems to hold up fine, I dont think you'll have any problems as long as it cures completely before you run it.
Old 08-05-2005, 05:06 PM   #7164
Send a message via MSN to Bigger Brother
Hi everyone.
After much diliberating the car is on its way! Can anyone tell me the maximum diameter spur gear that fits in the car? - I'm getting the PRS adapter too so I can run 48 pitch gears (rather than buy a complete new range of pinions), and would like to check what size spur gear I can run.
Alternativly, could someone give me the diameter of the std Losi 128t 64dp gear so I can do soem matching up.
Thanks for any help .... I'll probably be back on here soon after some more tips!
Cheers
Oli
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 08-05-2005, 06:19 PM   #7165
POOKYT's Avatar
Oli--The 128 spur is 51.60 mm in diameter. A couple of carpet guys have run a 130 spur but it hangs a lil under the chassis. Hope this helps
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 08-05-2005, 07:03 PM   #7166
2-Bad's Avatar
Brant
That would look wicked .... got any photo's of that.... talk about cutting a rug....
Old 08-05-2005, 07:30 PM   #7167
Still Bill's Avatar
Randy,
We do??? Gonna have to try that one...
Just bought one built by our buddy James N to add to my collection. Maybe that one...he, he...
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-05-2005, 07:36 PM   #7168
Still Bill's Avatar
Asphalt guys,
I have been running a nicely trimmed piece of 3/4" wide electrical tape on the bottom side of the JRX-S chassis at the slots where the spur gear and pulleys are located. Keeps a lot of grit and grime out of the drivetrain.
Old 08-05-2005, 07:47 PM   #7169
Rob Phillips's Avatar
Are most of you guys running the Numan setup? I figured I woud give that a try first. Does anyone have Bobby Flack's carpet setup? I hear that his setup is dialed.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 08-05-2005, 07:48 PM   #7170
Originally Posted by JRX-S Bill
Randy,
I think everyone runs overdrive at SoCal, at least on all the cars Ive seen.
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
