Old 07-19-2005, 08:17 PM   #6706
RBLove's Avatar
Trader Rating: 72 (100%+)
Originally Posted by papadocks
has anyone had a problem with their ball cups poping off
Losi is now selling the ball cups used on the sway bar mounts. They're the only way to go. I do not have the part number handy. I will look around for it.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 07-19-2005, 08:23 PM   #6707
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to W.E.D.Jim
As far as ballcups, I have timbled my car, cartwheeled it, etc. and not for R&D either, LOL. The only ballcup popping off on me is the molded link for the servo to the steering rack. I replaced it with a threaded rod for sway bars and two cut down ballcups and the problem is now gone.
TeamLosi is also making H.D. ballcups that are really tuff, in fact the next likely failuire will probably be the titanium turnbuckles or ballstuds if you crash hard enough......Jim
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 07-19-2005, 08:28 PM   #6708
airbear87123's Avatar
Hi! I know a lot you configure your own homemade spools, but does anyone have an idea if Losi will sell one and, if so, when? Thanks
airbear87123 is offline   Reply With Quote
Old 07-19-2005, 08:30 PM   #6709
POOKYT's Avatar
They are testing and refining a set of pads that go in to either replace or in with the diff rings to make a spool. Not sure when they will be availible.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 07-19-2005, 08:36 PM   #6710
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
2 other racers that I know had the same issue with the stock ones. I have been having an issue with them bending and breaking....but Im not using the stock ball cups Im using the yellow Losi ones. I think with the tie rod so short and the ball cup so short that there is no room to really flex and the result of a wreck is a popped off cup or in my case one thats all bent out of shape.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-19-2005, 08:54 PM   #6711
Brant
Thanks! I will have to keep an eye on those pads!
Old 07-19-2005, 09:00 PM   #6712
rayhuang's Avatar
Kevin-get the sway bar ballcups like RB recommended. They are tough and stay put. And as an added bonus-they are super low profile so they dont hit the rims if you raise your rear ballstud on the hub.
Old 07-19-2005, 09:07 PM   #6713
Kevin K's Avatar
Ray....Yeah Im looking into getting some and seeing how they work out.
Old 07-19-2005, 09:36 PM   #6714
Still Bill's Avatar
Good posts guys...I learned something.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 07-19-2005, 09:43 PM   #6715
W.E.D.Jim's Avatar
Kevin, I think the yellow ballcups may be slightly softer then the included ballcups, not positive though. I have heard the coloring process casues this, and that is the reason for the pure white ones. This may be the popping off problem if that is the case.
The XXXS spool pads(sandpaper) have served me well, just biuld the diff like normal with NO diff balls and the diff rings will slip on the smooth side of the discs after assembly. Tighten for desired feel to help save outdrives, but prevent excess slipping......Jim
Old 07-19-2005, 10:42 PM   #6716
Kevin K's Avatar
Jim....I follow what you are saying but on the XXXS I ran the yellow cups with out an issue....I actually like them over the white ones as far as fit and everything. I think with the tie-rods so small they dont give at all and end up taking it out on the ball cup. Like if you take a longer ti-tie rod its easier to bend then say a shorter one like on the JRXS and as a result the ball cups take more of the abuse I think. Either way its not a big deal Im going to try the sway bar parts and see how well they hold up.
Old 07-19-2005, 11:37 PM   #6717
RBLove's Avatar
Something else that helped me (prior to the sway bar cups) is using AE cups. The smaller one's that are used on the TC3/4.
Old 07-20-2005, 01:47 AM   #6718
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Got my JRXS out on the track for the first time at SoCal today, gotta say I was really impressed. Ran BK's setup from the losi site and it was great, I did switch from 1/2 degree hub carriers to 1 degree hub carriers for a total of 2 degrees toe, just made it a little easier to drive. I've never driven a car that had so much on power traction, this thing is a missile out of the hairpins.
Old 07-20-2005, 07:34 AM   #6719
LOSA4253
Tony Vega is offline   Reply With Quote
Old 07-20-2005, 08:24 AM   #6720
rayhuang's Avatar
Default dykem red
Well-this is what you get when your track is down for two weeks......
My Red losi....
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
