Old 07-07-2005, 06:37 PM   #6496
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Doug D
I can vouch to this theory. I'll never forget when I saw you at B&B Billiards, pondering over your B3 while having a smoke and a cold one. I thought, man this dude must be out to lunch on the track...I was however sadly mistaken....lol
OUCH. Brutal.
Whut's up WEDJIMMY!?
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 07-07-2005, 06:51 PM   #6497
rayhuang's Avatar
Originally Posted by chicky03
Here is a good setup that I have been working on. http://www.parmapse.com/JRX.jpg
Paul
EricF,
This is the set-up that Chicky has Buddy and I running and its fast in stock and 19t and even modified with small chnages.
I have been running the 25lb rear spring leaned in one more hole. In modified I run the front shocks leaned in one more hole and make my turning circle about 10 clicks smaller on my Helios and run 2-deg toe in per wheel.
Its easy to drive in 19t and mod. IN stock-its got a lot of steering for me-but its been proven over and over that its fast.
Just pay attention to details. Keep the droop and ride height the same every run.
Ray
Old 07-07-2005, 08:05 PM   #6498
RBLove's Avatar
Trader Rating: 72 (100%+)
Paul
If you're running in a low bite situation try softer front springs and or lowering the front roll center. It will give you more front end bite. If your track is a Paragon track the set up should be close. If it's not you might have to make some small changes for more steering.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 07-07-2005, 08:06 PM   #6499
RBLove's Avatar
Originally Posted by rayhuang
HEY-Can we get back to just talking about cars on foam tires and carpet-lol EricF-working on it for ya!!
FFL
FOAMS FOR LIFE
Old 07-07-2005, 08:11 PM   #6500
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
I want one of these baby's! SOMEONE BUY MY RDX...
Roberto Falcon is offline   Reply With Quote
Old 07-07-2005, 11:29 PM   #6501
TLRacing
Todd Hodge's Avatar
Originally Posted by automator
Alright, I might be missing something here but what does this -1 rear pivot mean? -1 deg rear pivot with 1/2 deg rear hubs? does this mean you have 1/2 deg of toe out on the rear?? Like I said maybe I'm missing something here.
Yes you are correct. With that pivot and those hubs you would have 1/2 degree of toe-out in the rear.
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 07-07-2005, 11:30 PM   #6502
TLRacing
Todd Hodge's Avatar
Originally Posted by airbear87123
I think I've read somewhere in this thread that the PK brackets won't work with 28mm foams. I run 26mm foams currently and was wondering if the brackets would work with these. Also, do you guys just run the brackets on only the front arms or rear,too? Thanks
With 28mm tires the brackets will not work on the front of the car. However they will work on the rear. I am not sure if they will work with 26mm wheels...most likely not in the front.
Todd Hodge
Old 07-07-2005, 11:33 PM   #6503
TLRacing
Todd Hodge's Avatar
Originally Posted by tcdrvr
I've just got a used JRXS and the car has the brackets installed on it, I'm sure you have answered this before but what do they do (other than the obvious change in shock angle) in terms of handling or traction?
We have felt that they give the car a lot more consistency in its handling. Why? Since the shock is moved further out on the arm this allows the shock to control the arm movement of the car a lot better and since are a-arms are so short and we have a lot more arm movement compared to other TC's the brackets help with that as well.
Todd Hodge
Old 07-08-2005, 05:02 AM   #6504
Toe out on the rear, what does this do for handling? I always thought that was a no-no, that's why I was surprised to see this.
automator is offline   Reply With Quote
Old 07-08-2005, 09:16 AM   #6505
EricF's Avatar
BK Brackets...
Are you guys using these on carpet as well? I thought they were mainly an asphalt necessity.
Ray, JB, Paul, Thanks for the set up info.
E
EricF is offline   Reply With Quote
Old 07-08-2005, 10:35 AM   #6506
And how much are these brackets?
Old 07-08-2005, 12:16 PM   #6507
chicky03's Avatar
Send a message via AIM to chicky03
I messed up it should be a +1 degree pivot block. So with +1 deg block and 1/2 hubs you'll have 1.5 deg of toe in per side. We have since switched to 2 and 0 hubs or 1 hubs and 1 block to get 2 deg of toe in.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 07-08-2005, 12:18 PM   #6508
chicky03's Avatar
Originally Posted by EricF
BK Brackets...
E
I have some but have not tried it yet. Like Todd said you can only use it inthe rear for foams.
Paul
Old 07-08-2005, 12:47 PM   #6509
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Ok, time for a new car before the fall season starts.... I'm racing carpet, very tight track, the last layout the lap times were high 7's to low 8's.... What kind of luck is everyone having with the car? Like usual I'll probably be the only one running it since everyone else has Xray's and TC4's...
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 07-08-2005, 07:04 PM   #6510
TLRacing
Todd Hodge's Avatar
It would have no rear grip.
Todd Hodge
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
