Old 06-24-2005, 09:43 PM   #6256
Originally Posted by RBLove
Can you post a pic?
sorry no cam .. but ill see if i can get one up over the weekend ..
Mark Barden .
mb racer is offline   Reply With Quote
Old 06-24-2005, 09:47 PM   #6257
RBLove's Avatar
Trader Rating: 72 (100%+)
Thanks bro!
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 06-24-2005, 10:44 PM   #6258
Still Bill's Avatar
Originally Posted by STLNLST
you going to Ripon tomorrow?
19 turn is going to be a blast.
Certainly...Ripon is fav!
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 06-25-2005, 01:55 AM   #6259
POOKYT's Avatar
Originally Posted by W.E.D.Jim
If your trying to install the battery and tray as one assembly and it is giving you a tuff time, try instaling the battery first, then the tray after. Not sure if everyone is already doing this?
Earlier there were some posts regarding castor and camber change thru wheel movement/steering. Thought i'd chime in and drop the term SAI, or steering axis inclination. This is how castor works for both stability and feel, since it causes the tires to try and remain pointed straight ahead(more castor, more tendency to stay straight). For steering feel, it effects how much of the tire contacts the surface during turns/chassis roll thru SAI. There is also the weight jacking that occurs because of the axles change in inclination, etc.
The reason castor tuning seems elusive to some, is that it is directly effected by chassis roll stiffness. In other words, less roll in the chassis will like less castor, more roll will like more castor. This is because of tuning and not the surface itself, since tuning can reduce or add roll on any surface if desired......., Hope this helps?.....Jim
Very nice!!!!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 06-25-2005, 01:59 AM   #6260
BlackKat's Avatar
What are the grub screws on the sway-bar mounts there for. In the manual they are reffered to as "Uptravel Adjuster B" or something like that.
Someone really should pay more attention to matters like these
http://www2.towerhobbies.com/cgi-bin...?&I=LXJGX5&P=0
BlackKat is offline   Reply With Quote
Old 06-25-2005, 06:24 AM   #6261
Rick Worth's Avatar
LIke you said, they are up travel limiters. These adjust how far the arms move up, unlike the droop screw adjust how far they can move down. They are used to help control chassis roll in the corners.
Rick Worth is offline   Reply With Quote
Old 06-25-2005, 06:51 AM   #6262
Yet the setup sheets (at least the carpet setups) don't mention the setings at all. I've been playing with them on carpet and they seem to be a pretty cool tuning option.
DJG24 is offline   Reply With Quote
Old 06-25-2005, 09:55 AM   #6263
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Default Oneway setups???
Hi Todd,
I am chasing a setup to use with a oneway diff and centre pulley. I have tried your setup (spool)on both asphalt and concrete (with Sorex 36/40 rubbers) and its just dialled!!!!
I was wondering if any there are any setups for the car with a oneway using rubbers on asphalt or concrete? Or if you can give me any hints on what to change from your setup with the bk brackets?
Any help or advice would be greatly appreciated.
Thanks.
DirtyDog3375 is offline   Reply With Quote
Old 06-25-2005, 09:57 AM   #6264
Still Bill's Avatar
Excellent question...
Old 06-25-2005, 10:59 AM   #6265
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by BlackKat
Someone really should pay more attention to matters like these http://www2.towerhobbies.com/cgi-bin...?&I=LXJGX5&P=0
Product notes: "...lined with foam to keep your valued equipment secure"
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 06-25-2005, 11:38 AM   #6266
POOKYT's Avatar
Ditto
Brant
Old 06-25-2005, 03:03 PM   #6267
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Carpet Setup Question
On chicky's setup he says he has a -1 rear pivot. How is this obtained? He still shows 1.5 toe-in.
Thaks,
CRASH is offline   Reply With Quote
Old 06-25-2005, 08:07 PM   #6268
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to W.E.D.Jim
Well, my car was awesome using Josh Numans set up(or the version posted on the TL site anyhow). My car picked up alot of steering, but wasn't loose to get it, which is the way it should be! Corner speed was WAY up from the base set up with some tweaks I had been running. Even though I missed the A by .4 seconds, I have to take responsibility for the two bobbles early that cost me just over 4 seconds(TQ was about 5 seconds ahead of my final time), plus the time I wasted being nice to a driver with an overheated motor towards the end for almost 3 laps..........
It's nice to know my car is capable if I use it to it's potential!....next race is at Superior Hobbies(Corally home court). I'll run mod rather then expert 19T, HP won't be an issue with an Orion 7 turn, LOL!...............Jim
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 06-25-2005, 11:10 PM   #6269
2-Bad's Avatar
Trader Rating: 24 (100%+)
Yeah, Double Ditto....
Todd,
I've enjoyed your setup as well, but I'm interested in trying the 1-way diff, or 1-way pulley or both. The overall track layout that I race at is long and narrow in depth. I've attached a jpg for you as I thought this might help in producing a setup.
Regards,
Peter
2-Bad is offline   Reply With Quote
Old 06-25-2005, 11:57 PM   #6270
BlackKat's Avatar
I'm puzzled because they don't seem to hit against anything like the droop screws do...
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
