Old 06-13-2005, 12:32 PM   #5971
TLRacing
Todd Hodge's Avatar
Hey Guys,
I just want to let you know that we now sell the ball cups(rod ends) for the sway bar ends so you can use them on your car. The part # is LOSA4253 with a retail of $3.00. The kit comes with 4 ball ends and two sway bar mounts. These rod ends work great on the camber links and have minimal slop.
Also Aluminum battery trays are in stock here at Horizon West and they are on their way to Horizon Central. Part number is LOSA4309 with a retail of $19.99.
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 06-13-2005, 12:44 PM   #5972
1fastdude's Avatar
Trader Rating: 15 (100%+)
Default Battery Tray
I received mine Friday and used it Saturday. It is absolutely awesome. No need to do any dremeling on the bulkheads or anything like that. The IB3800's dropped right in. Note I did shoe goo them together, but made sure they were tight against each other. Do not shrink wrap on the cell's either.
★RCAmerica •Xray •Hudy •BSR/Jaco •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is offline   Reply With Quote
Old 06-13-2005, 03:05 PM   #5973
TimmyMontoya's Avatar
Can Anyone help me out? I have 56mm foams and I cant seem to get a good 4 or 5mm ride hight because the shock springs are compressing to much... I hope that makes sence... thanks for any help in advance!!!
Tim
DiscountRCstore.com new distributor of Xray and Hudy
Xray, Hudy, Schumacher, Fantom, Orca
TimmyMontoya is offline   Reply With Quote
Old 06-13-2005, 03:22 PM   #5974
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Carpet Track
Originally Posted by Doug Gaut
Crash, please let me know when the track is done!!! I wanna bring my new hot rod up there to play.
This car rocks on the carpet with foams OR rubber tires!!!!
Will do. The dirt is out the wall is down and carpet is being ordered. So from what I have heard we are going to have an all night test and tune night. Shane wants to have it all going in around 3 weeks.
Thanks RBLove, have been running asphalt but with the new bigger carpet track we will be running alot of mod and 19T.
Later,
CRASH is offline   Reply With Quote
Old 06-13-2005, 03:26 PM   #5975
wannabee's Avatar
Tim
Check your droop screws, sounds like you have them cranked down too much...
wannabee is offline   Reply With Quote
Old 06-13-2005, 03:37 PM   #5976
Wanabee... no the droop screws are basicly out and the arms are touching the chassis...
Old 06-13-2005, 03:39 PM   #5977
2-Bad's Avatar
Trader Rating: 24 (100%+)
As the tray is aluminium, do you have any concern that the cells would/could short out in the tray? Maybe I worry too much, but electricity just loves metal bites
2-Bad is offline   Reply With Quote
Old 06-13-2005, 03:43 PM   #5978
2-Bad's Avatar
Tim
Tim,
I haven't run foams on my car yet, but on some cars I've had in the past I needed to unscrew the shock end a turn or two to give me enough travel to maintain ride height. Just a thought......
Old 06-13-2005, 03:56 PM   #5979
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Check to make sure that your shock towers are in the "low" location. I have had 55mm foams on my car with no issues getting to 5+mm of ride height.....this was one of the first things I checked when I built the car to see how small of tires I can run. If your droop screws are not the issue make sure that the uptravle screws are not hitting the chassis maybe or the sway bar arm is installed the correct way. You should have no problems getting to 5mm with 56mm foams.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 06-13-2005, 04:26 PM   #5980
kevin K... Yes the tower is in the low position... maybe someone would tell me how long there shocks are like 2- Bad has suggested. And for giggles I pulled all up and downstop screws out. Im very miffed as to my problem....
Old 06-13-2005, 04:39 PM   #5981
Kevin K's Avatar
What’s the problem exactly? Are you not getting enough ride height or are you putting to much pre-load on the springs and the more pre-load you add is the car's ride height getting not getting higher? When the car was designed I think they looked at this as it was an issue with the XXXS and for me it looks like they fixed it but I’m baffled as to your issue here. I’m here at work and I don’t know how long my shocks are I can get that info later if someone doesn’t supply it sooner.
Old 06-13-2005, 04:45 PM   #5982
Kevin K.....Yes to get 5mm ride hight I have to preload the springs and they actually compress. I dont believe they should have to be that way.
Old 06-13-2005, 04:47 PM   #5983
gatrbite's Avatar
Send a message via AIM to gatrbite
The shocks should be about 62mm on carpet.
gatrbite is offline   Reply With Quote
Old 06-13-2005, 04:50 PM   #5984
Kevin K's Avatar
Timmy....if you are using softer springs they might take some pre-load to bring the car up to ride-height. What pound springs are you using. I know with my car and 50lb fronts and 20lb rear springs I have to compress them some to get to 5mm ride-height. I dont know how much you are having to crank down on the adjuster to get 5mm but you do need to add a little to them. You dont really want any free play in the springs when running foam tires....when you run rubber tires you can get away with that.
Old 06-13-2005, 05:00 PM   #5985
Kevin K.... yes I belive its 55lb. up front and 25lb. in the rear. Im using Kinwalds set-up from the losi web-site. So then my next question is are you using the "droop screws".....mine are totaly out???
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
