Old 06-11-2005, 09:37 AM   #5926
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to W.E.D.Jim
P-Dub, so how much of a factor were those P Dub bumpers at the Reedy in your Invitational 11th place finish ahead of some of the best in the world? .
Btw, need any bodies painted?lmk,......ttyl, Jim
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 06-11-2005, 05:02 PM   #5927
airbear87123's Avatar
airbear87123- What kind of racing do you do? Ceramics are very expensive and won't last forever. I think you might be better off spending your money elsewhere- tires, brushes, spare parts, etc.[/QUOTE]
I mainly just do club racing but am looking to attend some bigger events in the future. It sounds as if ceramic bearings are very pricey and don't provide very noticeable results. Thanks for your input!
airbear87123 is offline   Reply With Quote
Old 06-11-2005, 05:50 PM   #5928
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Originally Posted by 2-Bad
Todd,
Thanks for the setup... used it for the first time today, it really was enjoyable to drive. Thank-you....
Do you have anymore tucked away worth sharing... I promise I won't tell anyone where I got it from
I too agree with 2bad. However, I was wondering what can be done to this setup to increase on power steering without having to sacrifice rear end traction. (running on asphalt with sorex rubbers 32R with B inserts). Any help or advice would be appreciated.
DirtyDog3375 is offline   Reply With Quote
Old 06-11-2005, 05:50 PM   #5929
Buck Nasty's Avatar
I don't think $15.00 for twelve ceramic 3/32 diff balls is to bad.
Buck Nasty is offline   Reply With Quote
Old 06-11-2005, 06:12 PM   #5930
W.E.D.Jim's Avatar
Diff balls in carbide are good, for about $10-11. For ceramic bearings, expect to pay $120-150+, depending on your supplier.
One bump of the pipe and any benefit is gone, since it is such a slight improvement........I prefer to leave the crazy expensive stuff to the world and national level guys. For the rest of us, it's more about how many mistakes you make, then how much money you spent, the money only makes you feel like you swung the odds your way, but it rarely actually pays off.......for a bowling trophy......, Jim
Old 06-11-2005, 06:28 PM   #5931
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Ya totaly agree. Thats almost how I see it. Bearings can be expensive on what kind you get. I have only redone my diffs. once and i spent over $100 just buying new bearings and diff balls. If you keep them in good shape and cleaned and oiled often you will be fine with whatever bearigns you get. How i see it is; If i beat guys that have spent twice as much money on the hobby as i have I say i did good. I laugh when that happens
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 06-12-2005, 01:18 AM   #5932
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Ball Cup Issues
Has anyone had a problem with ball cups popping off? Tonight was terrible, car was ultra fast but tap a board and off would pop a ball cup. It was ridiculous tonight.
Later,
CRASH is offline   Reply With Quote
Old 06-12-2005, 03:27 AM   #5933
POOKYT's Avatar
Later,
Crash--My rule of thumb on ball cups would be if it pops once then I pop it back on--If it pops a second time then in the trash it goes and gets replaced.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 06-12-2005, 03:31 AM   #5934
2-Bad's Avatar
Trader Rating: 24 (100%+)
Later,
Was it on the steering linkages? If so, what about installing a servo saver. Might soak up the occasional impact and keep them on. If not, then see above for Pook's reply (that man never sleeps, ).
2-Bad is offline   Reply With Quote
Old 06-12-2005, 05:26 AM   #5935
Timmy_G's Avatar
Send a message via MSN to Timmy_G
I had huge problems with my JRX-S with steering linkages, was terrible. I'd only need a tap from a competitor or to glance a board and they'd pop off. I replaced them with blue RPM ones that look very nice and are super tight. I used a scalpel to shorten them too.
Losi, JR Propo ,Spektrum, Novarossi, AT Racing Fuels
Timmy_G is offline   Reply With Quote
Old 06-12-2005, 06:57 AM   #5936
POOKYT's Avatar
Sleep is for Wussies!!!!!! (I'm going to take a nap now!)
Brant
Old 06-12-2005, 08:13 AM   #5937
2-Bad's Avatar
Brant
Make sure you say your prays......
Old 06-12-2005, 11:05 AM   #5938
I am going to be getting a JRX-S very soon and was looking to use Todd Hodge's setup on around page 172 of this thread. I run on a very technical, medium-bite asphalt track and was wondering what rubber tires you guys would recommend. Also, we only race stock motors, if that changes the tire choice. We just moved from an indoor track using foam tires, so I don't know much about rubber tires. Thanks!
Old 06-12-2005, 11:06 AM   #5939
Regional Moderator
Darkseid's Avatar
Originally Posted by JRX-S Bill
FWR,
Mine were bad (visually obvious) and Todd Hodge of Losi already gave me replacements. If your rear hubs are not right, contact Team Losi. Otherwise, per the posts on this forum, the actual number of people with the "0 deg" rear hub issue seem to be fairly limited.
Bill
Well I finally got a new set of wheels mounted up, and its pretty obvious now that my rear hubs are pretty far off.(amazing that the car handles so well with this being like that)
So now, how do I go about contacting Losi. I looked for their info in the manual and on the back cover(where I usually find company's info) but didn't see anything.
TLR 22...Tamiya F104...
Old 06-12-2005, 11:10 AM   #5940
Regional Moderator
Darkseid's Avatar
It will be availible in 2 Weeks!!!!! It will be worth the wait!!!! Be Patient!!!!LMAO
" Its like Dejavu all over again!" Sorry man I just had to do it!
Brant
See...see....see....
Now thats just wrong man!
Here I am, enjoying a good handling car, and you got to bring up those ugly memories!
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
