Team Losi JRXS
#5806
Originally Posted by DirtyDog3375
Just a question to Todd Hodge or any other losi rep/team driver, are losi going to make available as a separate part the ball ends that come with the sway bar kits? (for camber links - so I can run Todd's setu without having to grind away the standard ballcups/ends)
If so, when and what is the part number?
Or, if anyone has any other products that are similiar and fit, I am open to suggestions.
Thanks.
Thanks.
i assume for the titanium balls? Just take an exacto and chopp the top off.. works fine
#5807
Thanks.
Thanks.
Yes-those ballcups will be available on there own part number soon. I will get the part number for you shortly.
THey are not available yet. Todd also told me they make awesome ballcups for the steering links too!! Super tight-no slop.
#5809
I just finished building my car but I am having some trouble. I am running a front spool and when I try to launch the car, the rear differential seems to be slipping no matter how tight it is set. I tightened it as much as I could and there is some slip. I can't figure out what it is... any ideas? This is really bugging me.
#5810
#5811
has anyone tried the front one way, how did it perform?
#5812
#5815
#5816
One way has been working awesome in my car.
#5817
The one-way that I bought only had one outdrive. No biggy, I'm waiting on an email from losi to see if they'll send me another one. Just something to look out for if you buy yours in a store and can see it as opposed to ordering online.
#5818
#5820
Originally Posted by brians11
Maybe its just me, but it looks like my caster blocks are not the same either... I can look at the material around the arm and see a difference in the amount of material on each side...
Not just you, me to. I posted the exact problem several pages back but got no input from others. Must be a sparadic issue. But anyway upon checking the blocks from my car i found that one side was actually a 2* block and the other 4. Replaced it and everything fine.
Goof Luck
