Team Losi JRXS
#5776
Originally Posted by rayhuang
Paul Ciccarello has been laying it down here on carpet. Stock, 19t and mod. We thought that the mark had been set in stock and no one was ging to eclipse it-but Paul and his JRXS just reset the mark. Then he did it again in 19t. In mod he has no one to run against, but I think hes got it dialed in there too.
Like I said earlier-the cars as tune-inable as it is tune-outable. I have certainley found ways to make it push badly and made it steer so hard I could run a 1' off the boards all the way around the track wide open-lol. But isnt that what this car is designed for? Ultimate tueability. I certainley didnt buy it because the battteries were easy to solder in-lol
#5778
Im back!!!LOL
#5779
Just wondering how many people who have the jrxs run a servo saver? I have just about finish building and wiring up my car and was curious. I have a kimborough servo saver, but since losi includes servo horns in the kit, I was wondering was it necessary to a servo saver? (I have a Airtronics digital 97458 -think that's the right number)
#5780
Brant
#5781
Originally Posted by POOKYT
Just make sure you can use the servo saver and run the correct gear ratio. The space between the servo arm and the motor can get really close!
Brant
Brant
And changing over to the PRS spur gear adaptor will lead to other optional ratios too.
Bill
#5782
hi everyone. you have probly all heard this a thousand times before so if u have i apologise. i am thinking of running a jrxs with a trf415 so i was wondering if it is possible to use batteries wired with corally plugs in the jrxs or will they hit pulleys/spurs? has anyone found a way to connect batteries in this car without having to hardwire? even if the corally plugs were mounted sideways would they fit without interfearing with anything???
#5783
You can use the corally plugs, but you mount them horizontally with a spare battery bar bent at 90 deg in the valley between the battery cells 1 & 2 for the pos+, and cells 5 & 6 for the neg-. There are some photo's if memory serves me right pages 96, 97, 98 (I think).
Peter
#5784
peter-
thanks for the info mate you have now given me all i need to buy a jrxs
#5785
Paul is one of the reasons I bought the car. He has been a great help over the years while I was racing slot cars. His attention to detail when working with slot car chassis and bodies is exceptional as will be the work on the sedan. Look at the Parma Alfa, its still the base carpet body! When I heard he was running the JRXS I knew we would have some fantastic help.
#5786
Originally Posted by EricF
Todd,
Thanks for the E-clips for the spur gear and the spool pads, and letting me look over your shoulder and ask stupid questions.
Numans' car looked the best, It seemed as if it were on rails. Are you guys going to post RROC setups?
Thanks,
E
Thanks,
E
#5787
Well my skeptisism is gone.
I drove my car yesterday on carpet, using most of the lemeuix setup on the losi site and it was pretty dialed to start. I made a few changes and every time= I could actually FEEL the change. It is also very snappy off the corner compared to my XXXS...
the only things different on my setup is that I am running non offset -.5 degree hubs, my diffs are high.. and I added the second thinnest rear bar.. it steers so well.. carrys speed.. and the down travel stops are a nice addition as they kept the chassis from scrubbing speed in the corner..
hopefully asphalt this weekend
This car will go fast.
//KBpower
//KBpower
#5788
Battery hole
I just got around to building my JRXS. Pretty excited. Is it really necessary to file down the battery hole in the chassis? I was going to leave it alone but decided to check here first. WIll the batteries not fit? I am running 3300 from promatch. Thanks everyone.
#5789
Im not sure if it will fit or not, im pretty sure that you need to chamfer that last slot for the battery, or it will sit too high.
-Buddy
-Buddy
#5790
The Evicerator
You need to file the edges of that one slot for proper battery fit.
