Old 05-31-2005, 07:39 AM   #5641
Suspended
Originally Posted by W.E.D.Jim
403, true, but "I" would still get my point accross to the "restaurant" in a respectful, decent manner and keep my dignity while doing so.
It may go like this,"Excuse me waiter, but this meatloaf is Very over cooked, i'd like another".
That way the waiter and chef won't spit in my food..............makes sense, right?........, Jim
Depends on the severity of the burn. If the food is only slightly burned, then harsh words are not rot needed.
However, if a customer is served a rock hard burnt meatloaf, thats an insult. Harsh words are to be expected. I wouldn't even bother asking for a second meatloaf at that point.
Oh of course I would be nice to the waiter though, after all he/she simply serves the food. The fault lies with the cook.
403forbidden is offline   Reply With Quote
Old 05-31-2005, 08:39 AM   #5642
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Just wondering what everyone thinks of the body that comes with the JRXS? (Skoda) I have not seen it used anywhere, does it work or is it a "show" body only? I
DirtyDog3375 is offline   Reply With Quote
Old 05-31-2005, 08:42 AM   #5643
Nathan Parker's Avatar
HI Geoff,
I have emailed you with regards to a set up.
Any problems email me and I`ll do my best to help
Check out the results from West Londons memorial meeting car was flying
www.wlrc.co.uk
Nathan Parker
Team Losi (UK)
Nathan Parker is offline   Reply With Quote
Old 05-31-2005, 09:28 AM   #5644
I think it's better suited for carpet racing on foam tires!
It just don't have enough rear bite to be used on asphalt tracks, i've tried it last sunday but my old mazda 6 was much better.....
Fastfreddy74 is offline   Reply With Quote
Old 05-31-2005, 10:18 AM   #5645
Thanks for the reply fastfreddy. Is this the general concensus with everyone? I will be racing only on asphalt/concrete with rubber tires. I see that the Parma Alfa is very popular in the US. Here in Australia, the Protoform Madza 6 seems to be the body to have. What's the Parma Alfa like as far as hadling charateristics are concerned? And I have also seen a Nemesis body (what is it? what are it's characteristics?)
Old 05-31-2005, 10:29 AM   #5646
robk's Avatar
Trader Rating: 22 (100%+)
Parma Alfa is popular for carpet foam racing. It has a lot of steering, maybe less downforce than the Mazda 6.
Old 05-31-2005, 10:38 AM   #5647
When reference is made to shimming up front inner blocks, does this mean pivot block as well as rear ride height blocks?
J Tronzano is offline   Reply With Quote
Old 05-31-2005, 11:53 AM   #5648
Mike Haynes's Avatar
My best comparison of the bodies, as i have run them all is this. Mind you that this is on carpet as well as blacktop, but i did not get to try the skota on blacktop yet.
Mazda- Planted, lot of steering, a lot of tractio all around, my favorite for paved(rubbers)
Parma Alfa- loose, steers well, floaty all around, my favorite for carpet(foams), but when i ran it on blacktopit seemed to be way to floaty all around.
Skota- balenced well, steers well into corner but seemed to push out, med grip all around
Nemisis-seemed to me that it was very stable but pushed in the turns, i personally didnt like it.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-31-2005, 11:54 AM   #5649
I have always meant this as the small (inner) mounts only, but it would depend on who made the setup.
Old 05-31-2005, 12:15 PM   #5650
Mike
By raising the rear small inner blocks wouldn't you be dialing in anti-dive?
Old 05-31-2005, 12:27 PM   #5651
Skill's Avatar
Hi,
I've got a Pro 4 at the moment which is a brilliant car, but when I saw the JRX-S I just thought it looked right with the battery motor and servo positionings, but I've got a few concerns that I hope you can answer
First of all, I knew a couple of people who had a XXX-S G+ and they seemed to have nothing but problems with them, they seemed to break so easily and struggled on low grip surfaces, what's the durability like on the JRX-S?
Also, what are the kit springs like? Can you get a decent setup with them for foams on carpet?
And lastly, in general is there any mods or anything I should be doing to it if I get one?
Skill is offline   Reply With Quote
Old 05-31-2005, 12:34 PM   #5652
Mike
Assuming your talking about the front end, yes raising the 2 smaller inner mounts up in relation to the big front mount will give you anti dive.
From the losi site,
"Kickup/Anti-dive: This is the angle of the inner front hinge pins in relation to the chassis. The amount of kickup/anti-dive is controlled with shims (one .035 shim per degree) under the pivot blocks that mount the inner hinge pins and suspension arms to the chassis. For kickup, the shims will be placed under the pivot block in front of the arms. For anti-dive, the shims will be placed under the pivot blocks directly behind the front arms."
Old 05-31-2005, 12:48 PM   #5653
Mike,
Whenever reference was made to adding shims to the front, it always seemed to follow a cmment on high roll center in front. This is why I wasn't sure whether the whole front was to be raised to increase roll cenetr in general.
Old 05-31-2005, 01:25 PM   #5654
Send a message via Yahoo to GTIRACER
I saw some place in all of these pages that there was a solution to the rear toe issue. It appears I have more toe on the left rear also. Was it a hub? Im sure Losi will take care of it but i want to know what it is b4 I call them
GTIRACER is offline   Reply With Quote
Old 05-31-2005, 01:37 PM   #5655
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Its in the hubs. If you have a problem just email losi and they will take care of you.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
