Team Losi JRXS
#5431
Originally Posted by Kwikvdub
Does anyone know the part# to the decal sheet of the Skoda Body that comes with the kit or any other way to get it?
Thanks,
Thanks,
#5432
Regional Moderator
Originally Posted by W.E.D.Jim
Darkseid, the smallest sway bars will work, but you need to run the set screw all the way and then back out before trying to install in on the bar end. The threads are cut, but the threads are a little rough in the end of the hole, so a pre-threading is needed to avoid tweaking the bar.
I guess I can go back and try it the next time I'm thinking of running the thinnest bar.
#5435
Originally Posted by OSherman
Anyone know where I can get the swaybars/mounts??..
Also, i happened to be looking at the LHS yesterday and the JRX-S rear hubs 'appear' to be the same as the XXX-S rear hubs.. Is this true?.. can XXX-S hubs (front and rear) fit the JRX-S ??
-O
-O
YOu can make your own sway bar by rebending an old xxxs sway bar and using the XXXS sway bar mounts (grey plastic ones). I also made my own mounts from TC3 sway bar mounts, threaded rod and any 4-40 ball-cup.
And yes-the old XXXS rear hubs-both the standard and offset work perfectly on the JRXS. At some point they added a lot of material around the bottom hingepin mount which has made them a LOT stronger.
#5436
-O
-O
E
#5437
Regional Moderator
Originally Posted by J.Filipow
Darkseid- Swaybars: 0.030, 0.040, 0.050. 0.060...if you look closely on the molded sway bar mounts, you will see the sizes listed.
So going by your listing, the 0.030 is the thinnest going all way up to the 0.060 which is the thickest. I thought that was the way it went, but just wanted to be sure before I started marking stuff on setup sheets.
#5438
Originally Posted by Darkseid
Yeah, I saw those, but because the numbers are put right next to each other, and not "top" and "bottom" next to the corresponding sway bar slot, it still left me guessing. Mainly, I've been using metric cars for so long, I only see in mm! So I know when I see a 1.2mm sway bar, that its thicker than a 1mm sway bar. So because I usually don't use it, all this .030 and .060 threw me as to what was thickest.
Regards,
Peter
#5439
well the cars diled atfirst i was having some problems but josh cyrul took it for a ride and ajusted my radio and it was amazing i was in 2nd just off the tq time taped the board and ripped the ballstud out i forgot to put the longer ball stud after putting in bump steer
#5441
Regional Moderator
Originally Posted by 2-Bad
Darkseid, you probably already know this but if you don't then hear goes. The .030, .040, .050, and .060, are imperial thousands of an inch, so .030 is "30 thousands of an inch" is the thinest to "60 thousands of an inch" that is the thickest.
Regards,
Peter
Regards,
Peter
#5442
Thanks,
Thanks,
Brant
#5444
Originally Posted by Rick Worth
Where can you get the PRS adaptor? Thnaks. R.W.
#5445
Team EAM
I have more adapters on order. I think there are two left right now. They went FAST!!! I put mine on the losi I have here. It was hard to get on the shaft but once on there it came off ok. I think they didnt take into account the thickness of the anadize. But it spins TRUE. No wobble with these babies.
I will be gone to the Reedy race. I will have some with me if anyone there needs more. Im having my order shipped out there.
EA
EA
