Old 05-18-2005, 04:05 PM   #5311
OSherman's Avatar
Default Re: Re: Re: Re: Re: Re: servos
Originally posted by Intelligentsia
Glad to hear it You gonna help me wet up my car? I have been out of the loop
What is the next race that you are going to attend? I noticed that you are not in for Reedy this year.
I have been out of the racing scene since December.. First race since then was 4Fun this past weekend..
Just been real busy lately. But getting back into the swing of things now. Gonna try and make LaMirada this sunday,... with the LOSI maybe. We'll see..
Once I get the LOSI going, feel free to come look me up..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 05-18-2005, 04:37 PM   #5312
Intelligentsia's Avatar
Are you going to be at Reedy at all to spectate? If so, I will see you there.
Intelligentsia is offline   Reply With Quote
Old 05-18-2005, 06:15 PM   #5313
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Default Thread Jack in Progress
Originally posted by OSherman
cool, thanks... btw, are you a KAWASAKI rider too (your avatar)... I just picked up a 636.. lots of fun..
Not a racer per-se, but I work part-time for a trackday company, so naturally, I hit the track whenever my schedule allows. And yes, that is the almighty 636 carving up asphalt in my avatar! Glad to hear Kawi has converted another rider!
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 05-18-2005, 07:10 PM   #5314
TLRacing
Todd Hodge's Avatar
Originally posted by brians11
Todd, On the setup you posted, I assume the upper shock mount is all the way in on both towers?
I always forget something It is #1 on the front tower and #2 on the rear tower.
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 05-18-2005, 07:32 PM   #5315
Ghostfit's Avatar
Default Re: Stuff to share
Originally posted by elijahbaley
Second time out with the car at our local track today in Singapore, South East Asia.
[/B][/QUOTE]
Thanks for sharing ! Just picked up mine from Winnie's Yesterday.
Think I'm the second JRXs in Singapore
Which series are you racing ? RCI or Tai Sing ?
Ghostfit is offline   Reply With Quote
Old 05-18-2005, 08:19 PM   #5316
P-DUB's Avatar
Hi Todd....I will be bringing some bumpers with me to the Reedy Race and was checkin to see if you need a freshy. I was told RB got you a bumper direct because of the delay we had for the Snowbirds.....Let me know
See ya next week!
Larry Pryor
P-DUB is offline   Reply With Quote
Old 05-18-2005, 09:28 PM   #5317
tc3blue's Avatar
Default stock setup
Hi again,
I haven't finished building my JRX-S yet , but I will be racing it on a tight, carpet track with foams in the stock class and kinda build it using Brian Kinwald's carpet setup, which isn't for the stock class.
Would I need to make any major changes(shock oil, springs, settings etc.) or should it be pretty much OK?
Also what pinion would you recommend (for 27turn stock)? I have no experience with 64p pinions, b/c I used 48p on my TC3.
Thank you!
tc3blue is offline   Reply With Quote
Old 05-18-2005, 09:29 PM   #5318
RBLove's Avatar
Trader Rating: 72 (100%+)
Carpet set up w/foams:
Front:
#57 piston - Losi 50 wt - 60lb spring
shocks laid in to third hole on tower
camber link in lowest position
.060 ackerman and .090 bump steer
1 degree pivot
6 degree caster
.035 anti-dive
low roll center
middle wheel base
droop (1mm above ride height)
4.5mm ride height
low diff
41 tooth pulley
Rear:
#56 piston - Losi 40 wt. - 25lb spring
shocks laid in to third hole on tower and out on arm
camber link in on hub and middle row and all the way in on tower
1 degree pivot
1 degree off set hubs
middle wheel base
.050 sway bar
droop (2mm above ride height)
4.5mm ride height
low diff
.020 pro-squat
low roll center
Parma Alfa
Parma Cyan front 2.25
Parma Magenta rear 2.25
DC Motorsports 7x1 Ti based
PRS gear adapter w/130 spur and 25 pinion
Front diff slightly tighter and than rear
This set up is really good in modifed. Turns on a dime and is NOT twitchy under power. This is not much different than some of the other set ups, but this has been the best for me. A couple of other racers at our local track tried the set up and went a two to three tenths faster......
I will be experimenting with wheel base next time out using the set up listed above.. I will report back my findings...
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 05-18-2005, 10:00 PM   #5319
tc3blue's Avatar
ok thanks
so this should be pretty much OK in STOCK class too right?
Old 05-18-2005, 10:20 PM   #5320
RBLove's Avatar
Originally posted by tc3blue
ok thanks
It should be perfect for stock. If you need to free the car up try going to 0 degree off set rear hubs. That will reduce your rear toe to 1 degree.
Old 05-18-2005, 11:21 PM   #5321
Tim Johnson's Avatar
Hey RBLove, can you use the JRXS setup sheet we have set up and we can repost the setup so people can view it nicer
Then people can print it out and take to the track with them
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 05-19-2005, 12:42 AM   #5322
Default Todd Hodge Asphalt SetUp
Hi Todd,
again on your setup, nothing is missing, but I am in doubt for the Front Roll Center: is it "high" because you added two .050" spacers to the blocks in "low" position, or you started from "high" position of blocks and furtherly added the spacers?
If so, this seems a big difference with the Rear "low" center, isn' t it?
The JRXS is great: when compared with this car, all the competitors look like old...
Thanks,
Eddi.
EddiRossi is offline   Reply With Quote
Old 05-19-2005, 12:54 AM   #5323
RBLove's Avatar
Oh yeahhh. If you want go ahead and do it. I can do it from work and have been super busy at home lately........
Old 05-19-2005, 03:53 AM   #5324
ok cool......Thanks
Airtronics|Kyosho|
Old 05-19-2005, 07:17 AM   #5325
RB Love,
How much front toe are you running and were you running o-rings above the bladders and how far were you in on the sway bar or was it mounted at the end?
SPC Racer is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
