Old 05-13-2005, 07:23 AM   #5161
1. Take your time.
2. Take your time.
3. Take your time.
All kidding aside, you must properly prepare the chassis before you go bonzai on the assembly. Otherwise you will just end up taking it appart when your batteries dont fit or you splinter your chassis when you hit a dot. Take your time on the rear battery slot.
Tony Vega is offline   Reply With Quote
Old 05-13-2005, 08:17 AM   #5162
stormperson's Avatar
Send a message via AIM to stormperson
todd/andrew- What have you guys noticed between the accord and the mazda 6?
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 05-13-2005, 08:38 AM   #5163
TLRacing
Todd Hodge's Avatar
The Accord has more steering. I also have ran the new PF 3.0 and it works great too. Very close between the PF 3.0 and Accord.
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 05-13-2005, 08:41 AM   #5164
TLRacing
Todd Hodge's Avatar
Default Re: JRX-S new kit
Originally posted by WD40
I am getting a new Team Losi JRX-S in about a week and was wondering what everyone thinks is the top 3 things I should know about this kit when building it. I guess I want to know the top 3 building tips for the JRX-S......any responses would be very helpful
1. Glue the edges of your chassis for protection. Only do the chassis and not the front and rear top brace.The problem with doing the top braces is that it may tweak your car when you go to put it together. The added glue will cause the tight fitting parts to not sit properly on the bulkheads.
2.Like Tony said, make sure you file the cell slot enough. This is critical with the fitting of 3700 cells.
3.Enjoy!!
Todd Hodge
Old 05-13-2005, 08:47 AM   #5165
TLRacing
Todd Hodge's Avatar
A few things I forgot to mention.
Rear camber link- 3/A
Front Camber Link- Middle
BK Brackets-You will need to cut about 1/8" off the shock end to get the correct uptravel since you are moving the shock up on the arm.
Todd Hodge
Old 05-13-2005, 09:16 AM   #5166
rbboy's Avatar
Send a message via MSN to rbboy Send a message via Yahoo to rbboy
todd: hello! i ran my jrxs today for the first time and it was good except that my car would spin out on a right turn... i tried setting the throttle exponential on
-30 on my 3pk and adjusted the dual rate to 80% it somehow fixed the problem till it rained a friend of mine "FBJ" gave me some sand paper pads for the front diffs, he told me to use it for a front spool. what does it do? and how do i turn my diff into a spool.. do i just remove the diff balls? the jrxs had so much initial turn-in WOW anyways, FBJ told me to set the rear suspensions to the outermost hole and the fronts to the innermost hole, will try out my car tomorrow at the track
www.xtremerchobbiesph.net
rbboy is offline   Reply With Quote
Old 05-13-2005, 09:18 AM   #5167
FWR
Originally posted by seanyblaze
it is critical that you tap the spots where the locating pins go....or youll probably be buying a new 050 driver...
So, when I walk into Home Depo, what tap do I need to buy for the locating pins?
This logon is no longer being monitored.
FWR is offline   Reply With Quote
Old 05-13-2005, 09:26 AM   #5168
4-40 Tap.
Old 05-13-2005, 09:56 AM   #5169
Regional Moderator
Darkseid's Avatar
Originally posted by T. Hodge
The battery trays are being made as I type this. We should have them ready in a few weeks. After they are machined they will be off to the anodizer then to packaging.
So they are going to be alloy? Wow thought that was just going to be for your test units!
Any idea how much those anodized puppies will cost us? I've been impressed with the low cost of parts for the Losi, I hope you guys continue to impress by having the new tray be affoardable.
Oh, and thanks for the quick answer.
TLR 22...Tamiya F104...
Old 05-13-2005, 10:08 AM   #5170
Doug D's Avatar
Trader Rating: 54 (100%+)
Todd - Will drilling additional holes in the F/R arms accomplish the same effect that the BK Brackets have? What are the part numbers for the brackets?
Thanks.
Doug D is offline   Reply With Quote
Old 05-13-2005, 10:17 AM   #5171
Thanks.
There isnt enough material on the arm to drill an tap a hole further out on the arm. The BK brackets are very easy to make. 1 side has a thru hole and the other has a tapped 4-40 hole. Use a longer screw on the shock bottom and thread it into the thread side of the bracket and let the excess rest on top of the arm. Just make sure your brackets are even.
Old 05-13-2005, 10:44 AM   #5172
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Originally posted by P-DUB
Hey Filipow...Hows that bumper working out for ya
YO....it's PW! I don't know, as I haven't hit anything yet! BRAAAAAAAA...(I'll keep you posted and get you some photos!)
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 05-13-2005, 01:41 PM   #5173
WD40's Avatar
Todd, is it really necessary to tap the spots where the locating pins go.....will it really break your driver if you don't do that?
WD40 is offline   Reply With Quote
Old 05-13-2005, 03:02 PM   #5174
FWR
Default Re: TH Current Asphalt Setup
What kind of asphalt track is this setup for. Our track is usually setup open and flowing, only a couple corners that you have to go all the way down to half throtle. It is also sealed asphalt with traction added (grape pop). Just courious about the front tow out.
Old 05-13-2005, 03:06 PM   #5175
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Re: Re: TH Current Asphalt Setup
I have been running Kinwalds setup from So-Cal on a very similar track to what you just described and the car is awesome.
Later,
CRASH is offline   Reply With Quote
Team Losi JRXS Fast XXXS Australia For Sale/Trade 6 11-19-2007 03:34 PM
F-S Team losi JRXS as new mcskoda Australia For Sale/Trade 6 10-31-2006 02:15 AM
FS:Team Losi JRXS BiggAlz R/C Items: For Sale/Trade 21 03-25-2006 05:47 PM
Team Losi JRXS FS JRXSBear R/C Items: For Sale/Trade 9 01-19-2006 03:57 PM
Team Losi JRXS Jon Carlson R/C Items: For Sale/Trade 3 01-18-2006 08:28 PM
